Dear sir,
In staad pro how we can camber a beam . stad file also attached.I want to camber this beam 20mm .Is it possible in staad?
6472.Str1.std
Yes, it can be done in STAAD. You can define camber through beam specification.
Specifications> Beam > Imperfection.
Also refer help file for more details.
C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\Help\std_dlg_Member_Specification.html
sir,
I am putting the value 750 (length/offset =30000mm/40mm(we need to camber it 40 mm)) and respect value 1.6 but results are still same with deflection 50mm .Why deflection is not decreasing? Kindly also guide me on how to calculate respect value.file is attached. 3835.Str1.std
Gentle reminder
Hello User,
Your issue needs special investigation. Please create a service request at https://apps.bentley.com/srmanager/ProductSupport
SIR this link is showing that You do not have sufficient privileges for this operation
