Hi, instead of exporting entire model and analysis data and use it directly on RCDC, I decided to use the method specified in documentation for ETABS 15 & 16 and I got this error. I even copied the ETABS tlb and dll files in root directory of installation and it still wouldn't work. Have you added support for ETABS 18? If yes, please tell me the procedure.
Would recommend you to download the latest version of Staad RCDC in which we have incorporated the latest feature of Etab 18. Please click on the link to download the latest version for your ready reference. Kindly install the same and check if you face the same issue again.
https://softwaredownloads.bentley.com/en/ProductDetails/2303
Hi, it says I don't have access to download the file. Can you please provide an alternative?
Hello Sachin,
Can you raise Service Request to assist you further in this case .Or else can you please tell me which version of RCDC you are using currently.
Hello, I have latest RCDC version 10. I am linking it with etabs 19 file. It says the same error. Can you please clarify??
HI Vineeth,
Please note that we have incorporated Etabs 18 into the current versions of RCDC . Integration of the etabs 19 is still under process by our development team for the upcoming version of RCDC .
