Hi there,
Im unable to install staad pro connect. It keep giving me the error code 0x80070643.
Below are the log file for the error.
[31D8:307C][2019-12-09T10:14:42]i001: Burn v3.11.1.2318, Windows v6.1 (Build 7601: Service Pack 1), path: C:\Users\22564\AppData\Local\Temp\{704BCED5-7765-4D65-BFCD-3603300B958E}\.cr\stpst22020026en.exe[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeBundleProductName' to value 'STAAD.Pro CONNECT Edition V22 Update 2'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\Engineering\STAAD.Pro CONNECT Edition\'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'SamplesDirectory' to value ''[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BentleyClientPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeBundleCulture' to value 'en'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeBuildType' to value 'Release'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeBundleShortName' to value 'StaadPro'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BundleHelpDocument' to value 'STAAD.Pro_Readme.zip'[31D8:307C][2019-12-09T10:14:42]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'[31D8:307C][2019-12-09T10:14:42]i009: Command Line: '-burn.clean.room=C:\Users\22564\Desktop\stpst22020026en.exe -burn.filehandle.attached=188 -burn.filehandle.self=196'[31D8:307C][2019-12-09T10:14:42]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\22564\Desktop\stpst22020026en.exe'[31D8:307C][2019-12-09T10:14:42]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\22564\Desktop\'[31D8:307C][2019-12-09T10:14:43]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443.log'[31D8:307C][2019-12-09T10:14:43]i052: Condition 'VersionNT >= v6.1' evaluates to true.[31D8:307C][2019-12-09T10:14:43]i000: Setting string variable 'WixBundleName' to value 'STAAD.Pro CONNECT Edition V22 Update 2'[31D8:307C][2019-12-09T10:14:43]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'[31D8:307C][2019-12-09T10:14:43]i000: Loading managed bootstrapper application.[31D8:307C][2019-12-09T10:14:43]i000: Creating BA thread to run asynchronously.[31D8:31DC][2019-12-09T10:14:43]i000: Setting Culture Info to en[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'BeSelectedLanguage' to value 'en'[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''[31D8:31DC][2019-12-09T10:14:43]i000: BentleyBundle Version 12.00.00.13[31D8:31DC][2019-12-09T10:14:43]i000: TRY Set TLS 1.2[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\22564\AppData\Local\Temp\{0D2F043B-DF0F-4B5A-A7ED-67928F97B5B8}\.ba'[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\22564\AppData\Local\Temp\{704BCED5-7765-4D65-BFCD-3603300B958E}\.cr'[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Users\22564\Desktop\'[31D8:31DC][2019-12-09T10:14:43]e000: Using Layout File : C:\Users\22564\AppData\Local\Temp\{0D2F043B-DF0F-4B5A-A7ED-67928F97B5B8}\.ba\Setup.lyt[31D8:31DC][2019-12-09T10:14:43]i000: Setting DotNet462Full InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting VC14RedistX64 InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting VC14RedistX86 InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting BentleyConnectClient InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting BentleyConnectAdvisor InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting SqlCE35SP2_x86 InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting SqlCE35SP2_x64 InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting SpcCatalog InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting SpcServer InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting StaadProPackage InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'StaadProPackage.AddLocal' to value 'DefaultFeature,StaadProDesktopShortcut,StaadProShortcuts,StaadProStartMenuShortcut,StaadProSampleModels'[31D8:31DC][2019-12-09T10:14:43]i000: Setting RCDC InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting VC10RedistX86 InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting BuildingPlanner InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]i000: Setting STAADFoundationAdvanced_x86 InstallLevel to 1[31D8:31DC][2019-12-09T10:14:43]e000: LoadTestAutomationApp(): Failed to load test dll with error Object reference not set to an instance of an object.[31D8:31DC][2019-12-09T10:14:43]i000: Setting string variable 'BePrimaryProductName' to value 'STAAD.Pro CONNECT Edition V22 Update 2 (22.02.00.026)'[31D8:31DC][2019-12-09T10:14:47]i000: Running with UI[31D8:31DC][2019-12-09T10:14:47]i000: Display is set to Full[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/BasicInstallDirectorySelectionUserControl.xaml[31D8:31DC][2019-12-09T10:14:47]i000: Setting string variable 'BeSelectedLanguage' to value ''[31D8:31DC][2019-12-09T10:14:47]i000: Value for WixBundleSourceProcessPath is C:\Users\22564\Desktop\stpst22020026en.exe[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml[31D8:31DC][2019-12-09T10:14:47]i000: Register callbak=ProxySettingsPage[31D8:31DC][2019-12-09T10:14:47]i000: Display Page=ProxySettingsPage[31D8:31DC][2019-12-09T10:14:47]i000: Cannot Display Page=ProxySettingsPage[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml[31D8:31DC][2019-12-09T10:14:47]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml[31D8:307C][2019-12-09T10:14:48]i100: Detect begin, 14 packages[31D8:307C][2019-12-09T10:14:48]i000: KBDetectBegin: Current Image is not running from a Deployment Image.[31D8:307C][2019-12-09T10:14:48]i000: KBDetectBegin: Current action is allowed to executed for KB check. ActionName=Install[31D8:307C][2019-12-09T10:14:48]i000: KBDetectBegin: Variable BeSkipKBCheck is not set to a value, hence, continuing with KB check.[31D8:307C][2019-12-09T10:14:48]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1[31D8:307C][2019-12-09T10:14:49]e000: WaitForProxyAuthentication: Waiting for proxy authentication[31D8:307C][2019-12-09T10:14:49]i000: Fetch BUDDI Key, RetryCount = 0[31D8:307C][2019-12-09T10:14:49]e000: SetHeaders (): Added bootstrapper id in header, {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}[31D8:307C][2019-12-09T10:14:49]i000: Resolving Buddi Key. Attempt: 1[31D8:307C][2019-12-09T10:14:52]i000: Failed to check for Windows Updates with error The server committed a protocol violation. Section=ResponseHeader Detail=CR must be followed by LF[31D8:307C][2019-12-09T10:14:52]i000: BeSkipKBCheck : [31D8:307C][2019-12-09T10:14:52]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent[31D8:307C][2019-12-09T10:14:52]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[31D8:307C][2019-12-09T10:14:52]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[31D8:307C][2019-12-09T10:14:52]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[31D8:307C][2019-12-09T10:14:52]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[31D8:307C][2019-12-09T10:14:52]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[31D8:307C][2019-12-09T10:14:52]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[31D8:307C][2019-12-09T10:14:52]i000: DetectBegin: Installed State of Package DetectedAbsent[31D8:307C][2019-12-09T10:14:52]i000: Setting version variable 'ConnectAdvisorInstalledVersion' to value '10.1.0.179'[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'ConnectClient_InstalledVersion_x64' to value '10.00.18.013'[31D8:307C][2019-12-09T10:14:52]i000: Registry key not found. Key = 'SOFTWARE\Bentley\Installed_LanguagePacks\{2CE036A7-3141-4D84-ADF0-8C13CD58F8C1}'[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'NetFramework46_InstalledVersion' to value '461814'[31D8:31DC][2019-12-09T10:14:52]i000: ErrorPage Code: 0[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'SqlCE35SP2_x64InstalledVersion' to value '3.5.8080.0'[31D8:307C][2019-12-09T10:14:52]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\D30CF9A3586C138449FCE4FD3D474979\InstallProperties'[31D8:307C][2019-12-09T10:14:52]i000: Product or related product not found: {D398D8CF-A4F2-4385-8B8C-648C541046DB}[31D8:307C][2019-12-09T10:14:52]i000: Setting version variable 'STAADAdvancedConcreteDesignRCDCVersion' to value '0.0.0.0'[31D8:307C][2019-12-09T10:14:52]i000: Product or related product not found: {F52A2A12-4E1F-43FD-8847-914B6C4F2BB3}[31D8:307C][2019-12-09T10:14:52]i000: Setting version variable 'STAADFoundationAdvancedInstalledVersion' to value '0.0.0.0'[31D8:307C][2019-12-09T10:14:52]i000: Product or related product not found: {74322187-0D4D-4B4E-948B-EF61E96691DA}[31D8:307C][2019-12-09T10:14:52]i000: Setting numeric variable 'STAADPro_QAnR_Build_Install_State' to value 2[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'VC10Runtime_InstalledVersion_x86' to value 'v10.0.40219.325'[31D8:307C][2019-12-09T10:14:52]i000: Setting version variable 'VCRedist2017x64' to value '14.16.27024.0'[31D8:307C][2019-12-09T10:14:52]i000: Setting version variable 'VCRedist2017x86' to value '14.16.27024.0'[31D8:307C][2019-12-09T10:14:52]i052: Condition 'NetFramework46_InstalledVersion >= 394802' evaluates to true.[31D8:307C][2019-12-09T10:14:52]i052: Condition '(VCRedist2017x64 >= v14.16.27027.1)' evaluates to false.[31D8:307C][2019-12-09T10:14:52]i052: Condition '(VCRedist2017x86 >= v14.16.27027.1)' evaluates to false.[31D8:307C][2019-12-09T10:14:52]i052: Condition '(ConnectClient_InstalledVersion_x64 >= v10.0.15.012)' evaluates to true.[31D8:307C][2019-12-09T10:14:52]i052: Condition '(ConnectAdvisorInstalledVersion >= v10.1.0.179)' evaluates to true.[31D8:307C][2019-12-09T10:14:52]i103: Detected related package: {C88234D5-2327-4B3D-9D75-9F2749930B04}, scope: PerMachine, version: 8.11.11.14, language: 0 operation: MajorUpgrade[31D8:307C][2019-12-09T10:14:52]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[31D8:307C][2019-12-09T10:14:52]i103: Detected related package: {C88234D5-2327-4B3D-9D75-9F2749930B04}, scope: PerMachine, version: 8.11.11.14, language: 0 operation: MajorUpgrade[31D8:307C][2019-12-09T10:14:52]i000: DetectRelatedMsiPackage: Operation=MajorUpgrade[31D8:307C][2019-12-09T10:14:52]i052: Condition '(STAADAdvancedConcreteDesignRCDCVersion >= v09.00.00.021)' evaluates to false.[31D8:307C][2019-12-09T10:14:52]i052: Condition '"10.0.40219.1" <= VC10Runtime_InstalledVersion_x86' evaluates to true.[31D8:307C][2019-12-09T10:14:52]i052: Condition '(STAADFoundationAdvancedInstalledVersion >= v09.01.00.014)' evaluates to false.[31D8:307C][2019-12-09T10:14:52]i101: Detected package: DotNet462Full, state: Present, cached: None[31D8:307C][2019-12-09T10:14:52]i101: Detected package: VC14RedistX64, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: VC14RedistX86, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: BentleyConnectClient, state: Present, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: BentleyConnectAdvisor, state: Present, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: SqlCE35SP2_x86, state: Present, cached: None[31D8:307C][2019-12-09T10:14:52]i101: Detected package: SqlCE35SP2_x64, state: Present, cached: None[31D8:307C][2019-12-09T10:14:52]i101: Detected package: SpcCatalog, state: Absent, cached: None[31D8:307C][2019-12-09T10:14:52]i101: Detected package: SpcServer, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: StaadProPackage, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i104: Detected package: StaadProPackage, feature: DefaultFeature, state: Absent[31D8:307C][2019-12-09T10:14:52]i104: Detected package: StaadProPackage, feature: StaadProDesktopShortcut, state: Absent[31D8:307C][2019-12-09T10:14:52]i104: Detected package: StaadProPackage, feature: StaadProShortcuts, state: Absent[31D8:307C][2019-12-09T10:14:52]i104: Detected package: StaadProPackage, feature: StaadProStartMenuShortcut, state: Absent[31D8:307C][2019-12-09T10:14:52]i104: Detected package: StaadProPackage, feature: StaadProSampleModels, state: Absent[31D8:307C][2019-12-09T10:14:52]i101: Detected package: RCDC, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: VC10RedistX86, state: Present, cached: None[31D8:307C][2019-12-09T10:14:52]i101: Detected package: BuildingPlanner, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i101: Detected package: STAADFoundationAdvanced_x86, state: Absent, cached: Complete[31D8:307C][2019-12-09T10:14:52]i000: Detect complete Start[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'BePlannedAction' to value 'Install'[31D8:307C][2019-12-09T10:14:52]i000: DotNet462Full AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: DotNet462Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: DotNet462Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: VC14RedistX64 AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: VC14RedistX64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: VC14RedistX64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: VC14RedistX86 AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: VC14RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: VC14RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: BentleyConnectAdvisor AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: BentleyConnectAdvisor AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: BentleyConnectAdvisor AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SpcCatalog AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: SpcCatalog AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SpcCatalog AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SpcServer AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: SpcServer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: SpcServer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[31D8:307C][2019-12-09T10:14:52]i000: RCDC AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: RCDC AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: RCDC AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: BuildingPlanner AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: BuildingPlanner AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: BuildingPlanner AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: VC10RedistX86 AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: VC10RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: VC10RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: LaunchAction=Install[31D8:307C][2019-12-09T10:14:52]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[31D8:307C][2019-12-09T10:14:52]i000: Detection complete planned action: Install[31D8:307C][2019-12-09T10:14:52]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle[31D8:307C][2019-12-09T10:14:52]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0[31D8:307C][2019-12-09T10:14:52]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles[31D8:307C][2019-12-09T10:14:52]i052: Condition 'Privileged OR BePlannedAction~="Layout" OR SkipPrivilegeCheck' evaluates to true.[31D8:307C][2019-12-09T10:14:52]i052: Condition 'STAADPro_QAnR_Build_Install_State <> 5' evaluates to true.[31D8:307C][2019-12-09T10:14:52]i000: SessionMutex: Creating new SessionMutex[31D8:307C][2019-12-09T10:14:52]i000: SessionMutex: Creating Mutex with Name={1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}-InstallMutex[31D8:307C][2019-12-09T10:14:52]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'BeBundleVersion' to value '[WixBundleVersion]'[31D8:307C][2019-12-09T10:14:52]i000: Setting string variable 'BeBundleProviderKey' to value '[WixBundleProviderKey]'[31D8:307C][2019-12-09T10:14:52]i000: WixInstallBA::SilentPlan[31D8:307C][2019-12-09T10:14:52]i000: [31D8:307C][2019-12-09T10:14:52]i000: Checking ADDLOCAL and REMOVE...[31D8:307C][2019-12-09T10:14:52]i199: Detect complete, result: 0x0[31D8:31DC][2019-12-09T10:14:56]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true.[31D8:31DC][2019-12-09T10:15:00]i000: WixInstallBA::Plan[31D8:31DC][2019-12-09T10:15:00]i000: WixInstallBA::SetupModel Plan[31D8:31DC][2019-12-09T10:15:00]i000: SetupModel::Before Plan[31D8:1008][2019-12-09T10:15:00]i000: Before Plan Async[31D8:1008][2019-12-09T10:15:00]i000: SetupViewModel::Before Plan[31D8:1008][2019-12-09T10:15:00]i000: FeatureNodeMachineState.Present True[31D8:1008][2019-12-09T10:15:00]i000: IsAnythingToDownload: Demanded by VC14RedistX64[31D8:1008][2019-12-09T10:15:00]i000: WixInstallBA::Before Plan Complete[31D8:1008][2019-12-09T10:15:00]i000: WixInstallBA::Engine Plan[31D8:307C][2019-12-09T10:15:00]i200: Plan begin, 14 packages, action: Install[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: DotNet462Full[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: VC14RedistX64[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleLog_VC14RedistX64' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_000_VC14RedistX64.log'[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: VC14RedistX86[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleLog_VC14RedistX86' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_001_VC14RedistX86.log'[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectAdvisor[31D8:307C][2019-12-09T10:15:00]i052: Condition 'NOT SqlCE35SP2_x86InstalledVersion >= v3.5.8080.0' evaluates to true.[31D8:307C][2019-12-09T10:15:00]i052: Condition 'NOT SqlCE35SP2_x64InstalledVersion >= v3.5.8080.0' evaluates to false.[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleLog_SpcCatalog' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_002_SpcCatalog.log'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleLog_SpcServer' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_003_SpcServer.log'[31D8:307C][2019-12-09T10:15:00]i204: Plan 5 msi features for package: StaadProPackage[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_DefaultFeature_IsInstalling' to value '1'[31D8:307C][2019-12-09T10:15:00]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProDesktopShortcut_IsInstalling' to value '1'[31D8:307C][2019-12-09T10:15:00]i203: Planned feature: StaadProDesktopShortcut, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProShortcuts_IsInstalling' to value '1'[31D8:307C][2019-12-09T10:15:00]i203: Planned feature: StaadProShortcuts, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProStartMenuShortcut_IsInstalling' to value '1'[31D8:307C][2019-12-09T10:15:00]i203: Planned feature: StaadProStartMenuShortcut, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProSampleModels_IsInstalling' to value '1'[31D8:307C][2019-12-09T10:15:00]i203: Planned feature: StaadProSampleModels, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleRollbackLog_StaadProPackage' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_004_StaadProPackage_rollback.log'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleLog_StaadProPackage' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_004_StaadProPackage.log'[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: RCDC[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'WixBundleLog_RCDC' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443_005_RCDC.log'[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: VC10RedistX86[31D8:307C][2019-12-09T10:15:00]w321: Skipping dependency registration on package with no dependency providers: STAADFoundationAdvanced_x86[31D8:307C][2019-12-09T10:15:00]i201: Planned package: DotNet462Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: VC14RedistX64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: Yes, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: VC14RedistX86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: Yes, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: BentleyConnectClient, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: BentleyConnectAdvisor, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: SqlCE35SP2_x86, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[31D8:307C][2019-12-09T10:15:00]i201: Planned package: SqlCE35SP2_x64, state: Present, default requested: Absent, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register[31D8:307C][2019-12-09T10:15:00]i201: Planned package: SpcCatalog, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: Register[31D8:307C][2019-12-09T10:15:00]i201: Planned package: SpcServer, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[31D8:307C][2019-12-09T10:15:00]i201: Planned package: StaadProPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register[31D8:307C][2019-12-09T10:15:00]i201: Planned package: RCDC, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: VC10RedistX86, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: BuildingPlanner, state: Absent, default requested: Present, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: Yes, dependency: None[31D8:307C][2019-12-09T10:15:00]i201: Planned package: STAADFoundationAdvanced_x86, state: Absent, default requested: Present, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: Yes, dependency: None[31D8:307C][2019-12-09T10:15:00]i000: GetWindowsRootDriveName (): winRoot=C:\[31D8:307C][2019-12-09T10:15:00]i000: IsPathRooted (C:\): true[31D8:307C][2019-12-09T10:15:00]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=3099144, FileName=C:\Users\22564\Desktop\stpst22020026en.exe[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.6.2. Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3099144[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=15338176, NewSize=18437320[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=18437320[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=14656504, NewSize=33093824[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley CONNECT Client (10.00.15.012). Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature already installed = Bentley CONNECT Advisor (10.01.00.179). Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft SQL Server Compact 3.5 SP2 English (x86). Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft SQL Server Compact 3.5 SP2 English (x64). Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=33093824[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=40199526, NewSize=73293350[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=73293350[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=97539630, NewSize=170832980[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=170832980[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1868668309, NewSize=2039501289[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature is not a package = Shortcuts. Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature is not a package = Desktop Shortcuts. Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature is not a package = Start Menu Shortcuts. Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature is not a package = Sample and Verification Models. Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=2039501289[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=667652824, NewSize=2707154113[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=2707154113[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=44892819, NewSize=2752046932[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft Visual C++ Redistributable 2010 (x86). Next[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=2752046932[31D8:307C][2019-12-09T10:15:00]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=694116168, NewSize=3446163100[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive C:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Requested Drive-List contains drive C:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive D:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive E:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive L:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive M:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive P:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive R:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive X:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive Y:\[31D8:307C][2019-12-09T10:15:00]i000: checkInstallSize (): Checking for drive Z:\[31D8:307C][2019-12-09T10:15:00]i000: validateInstallSize (): Result=True[31D8:307C][2019-12-09T10:15:00]i000: PlanComplete: Called[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'DotNet462Full_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'VC14RedistX64_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'VC14RedistX86_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'BentleyConnectAdvisor_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'SqlCE35SP2_x86_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'SqlCE35SP2_x64_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'SpcCatalog_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'SpcServer_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProShortcuts_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProDesktopShortcut_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProStartMenuShortcut_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'StaadProPackage_StaadProSampleModels_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'RCDC_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: Setting string variable 'VC10RedistX86_RequestedState' to value '1'[31D8:307C][2019-12-09T10:15:00]i000: WixInstallBA::Apply[31D8:307C][2019-12-09T10:15:00]i000: WixInstallBA::Engine Apply[31D8:307C][2019-12-09T10:15:00]i299: Plan complete, result: 0x0[31D8:307C][2019-12-09T10:15:00]i300: Apply begin[31D8:31DC][2019-12-09T10:15:00]i000: ErrorPage Code: 0[31D8:307C][2019-12-09T10:15:00]i010: Launching elevated engine process.[31D8:307C][2019-12-09T10:15:03]i011: Launched elevated engine process.[31D8:307C][2019-12-09T10:15:03]i012: Connected to elevated engine.[2998:32B8][2019-12-09T10:15:03]i358: Pausing automatic updates.[2998:32B8][2019-12-09T10:15:03]i359: Paused automatic updates.[2998:32B8][2019-12-09T10:15:03]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}, options: 0x7, disable resume: No[2998:32B8][2019-12-09T10:15:03]i000: Caching bundle from: 'C:\Users\22564\AppData\Local\Temp\{0D2F043B-DF0F-4B5A-A7ED-67928F97B5B8}\.be\Setup_StaadProx64_22.02.00.026.exe' to: 'C:\ProgramData\Package Cache\{1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}\Setup_StaadProx64_22.02.00.026.exe'[2998:32B8][2019-12-09T10:15:03]i320: Registering bundle dependency provider: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}, version: 22.2.0.26[2998:32B8][2019-12-09T10:15:03]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}, resume: Active, restart initiated: No, disable resume: No[31D8:307C][2019-12-09T10:15:03]i000: Installation chain initiated package from [2998:2BC4][2019-12-09T10:15:03]i304: Verified existing payload: VC14RedistX64 at path: C:\ProgramData\Package Cache\7ECF5797BC24EDED2454AAE6F3CA95C4F6EAB807\vc_redist.x64.exe.[31D8:307C][2019-12-09T10:15:03]i000: Installing VC14RedistX64[31D8:307C][2019-12-09T10:15:03]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64'[2998:32B8][2019-12-09T10:15:03]i301: Applying execute package: VC14RedistX64, action: Install, path: C:\ProgramData\Package Cache\7ECF5797BC24EDED2454AAE6F3CA95C4F6EAB807\vc_redist.x64.exe, arguments: '"C:\ProgramData\Package Cache\7ECF5797BC24EDED2454AAE6F3CA95C4F6EAB807\vc_redist.x64.exe" /install /quiet /norestart'[2998:2BC4][2019-12-09T10:15:03]i304: Verified existing payload: VC14RedistX86 at path: C:\ProgramData\Package Cache\71370C923679EA07E38B4E7BACC52B23E5EF9652\vc_redist.x86.exe.[31D8:288C][2019-12-09T10:15:03]w343: Prompt for source of package: SpcCatalog, payload: SpcCatalog, path: C:\Users\22564\Desktop\SPCSetup.3.1.4.5.msi[31D8:288C][2019-12-09T10:15:03]i000: ResolveSource: Retries value 1[31D8:288C][2019-12-09T10:15:03]i000: ResolveSource: Checking with PayloadService package SpcCatalog[31D8:288C][2019-12-09T10:15:03]e000: WaitForProxyAuthentication: Waiting for proxy authentication[31D8:288C][2019-12-09T10:15:03]i000: Opening the mapping file at C:\Users\22564\AppData\Local\Temp\{0D2F043B-DF0F-4B5A-A7ED-67928F97B5B8}\.ba\extRes.bin[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for DotNet462Full=a70f856b-da33-545a-90a8-ad035f730924[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for VC14RedistX64=7ecf5797-bc24-5ded-a454-aae6f3ca95c4[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for VC14RedistX86=71370c92-3679-5a07-a38b-4e7bacc52b23[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for BentleyConnectClient=3347b2f1-f5b6-4424-b077-41c07706bb75[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for BentleyConnectAdvisor=43430266-52c5-45b0-bf24-0f2db12403b6[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for SqlCE35SP2_x86=84395861-2117-43ce-9029-6d1a73f6929a[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for SqlCE35SP2_x64=a8561516-5654-439f-a50c-2e84b389c11d[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for SpcCatalog=03aca56a-bc74-4bb2-8113-8a4416cee37d[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for SpcServer=73e5adf1-07ab-4833-971a-dde685350455[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for StaadProPackage=acfce33f-a209-4c69-878c-9c95226d7991[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for RCDC=58b1d7e9-bf5c-4065-bc51-2304f479e11f[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for VC10RedistX86=b84b83a8-a674-5a17-bfb5-f3578b983c1d[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for BuildingPlanner=73c8b29d-3ea5-46f8-883d-571b23917027[31D8:288C][2019-12-09T10:15:03]i000: Parsing ExtPayloadId for STAADFoundationAdvanced_x86=df2b4370-ee77-43cf-8544-1095b3a5222e[31D8:288C][2019-12-09T10:15:03]i000: UserDomainName: OPUS[31D8:288C][2019-12-09T10:15:03]i000: Fetch Download URL for PayloadId = 03aca56a-bc74-4bb2-8113-8a4416cee37d, Resolver = , RetryCount = 0[31D8:288C][2019-12-09T10:15:03]e000: SetHeaders (): Added bootstrapper id in header, {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}[31D8:288C][2019-12-09T10:15:03]i000: Getting resolver URL. Attempt: 1[31D8:288C][2019-12-09T10:15:03]i000: Resolving from URL: payloadresolvesvc.bentley.com/.../[31D8:288C][2019-12-09T10:15:03]i000: Resolving from URL: payloadresolvesvc.bentley.com/.../[31D8:288C][2019-12-09T10:15:04]i000: Payload DownloadString = {"Status":0,"PayloadPath":""ErrorMessage":null}">cdnllnw.bentley.com/.../spcsetup.msi[31D8:288C][2019-12-09T10:15:04]i000: Payload Response.PayloadPath = cdnllnw.bentley.com/.../spcsetup.msi[31D8:288C][2019-12-09T10:15:04]e000: SpcCatalog is an OnDemand Package, downloaded path is cdnllnw.bentley.com/.../spcsetup.msi[31D8:288C][2019-12-09T10:15:04]i338: Acquiring package: SpcCatalog, payload: SpcCatalog, download from: cdnllnw.bentley.com/.../spcsetup.msi[31D8:307C][2019-12-09T10:15:15]i000: Installed package VC14RedistX64[31D8:307C][2019-12-09T10:15:15]i319: Applied execute package: VC14RedistX64, result: 0x0, restart: None[31D8:307C][2019-12-09T10:15:15]i000: Installing VC14RedistX86[31D8:307C][2019-12-09T10:15:15]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86'[2998:32B8][2019-12-09T10:15:15]i301: Applying execute package: VC14RedistX86, action: Install, path: C:\ProgramData\Package Cache\71370C923679EA07E38B4E7BACC52B23E5EF9652\vc_redist.x86.exe, arguments: '"C:\ProgramData\Package Cache\71370C923679EA07E38B4E7BACC52B23E5EF9652\vc_redist.x86.exe" /install /quiet /norestart'[2998:2BC4][2019-12-09T10:15:16]i305: Verified acquired payload: SpcCatalog at path: C:\ProgramData\Package Cache\.unverified\SpcCatalog, moving to: C:\ProgramData\Package Cache\{D6F32D32-986F-4A51-8992-B83F18009F32}v3.1.4.5\SPCSetup.3.1.4.5.msi.[2998:2BC4][2019-12-09T10:15:16]i304: Verified existing payload: SpcServer at path: C:\ProgramData\Package Cache\{D7682AA0-B2CC-4FF0-BFCA-54AD6FD744FF}v08.11.11.21\SPCServerSetup.08.11.11.21.msi.[2998:2BC4][2019-12-09T10:15:17]i304: Verified existing payload: StaadProPackage at path: C:\ProgramData\Package Cache\{2B7ABC9B-E668-3C11-A7CB-80250500C6DC}v22.02.00.026\StaadProx64.msi.[2998:2BC4][2019-12-09T10:15:19]i304: Verified existing payload: RCDC at path: C:\ProgramData\Package Cache\620458712EB8DF936F223ECBB6AD54CF6F8B0E5B\Setup_RCDCx64_09.00.00.021.exe.[31D8:307C][2019-12-09T10:15:43]i000: Installed package VC14RedistX86[31D8:307C][2019-12-09T10:15:43]i319: Applied execute package: VC14RedistX86, result: 0x0, restart: None[2998:32B8][2019-12-09T10:15:43]i323: Registering package dependency provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, version: 3.5.8080.0, package: SqlCE35SP2_x86[2998:32B8][2019-12-09T10:15:43]i325: Registering dependency: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3} on package provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, package: SqlCE35SP2_x86[2998:32B8][2019-12-09T10:15:43]i323: Registering package dependency provider: {D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}, version: 3.5.8080.0, package: SqlCE35SP2_x64[2998:32B8][2019-12-09T10:15:43]i325: Registering dependency: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3} on package provider: {D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}, package: SqlCE35SP2_x64[2998:32B8][2019-12-09T10:15:43]i323: Registering package dependency provider: {D6F32D32-986F-4A51-8992-B83F18009F32}, version: 3.1.4.5, package: SpcCatalog[31D8:307C][2019-12-09T10:15:43]i000: Installing SpcCatalog[31D8:307C][2019-12-09T10:15:43]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;spccatalog'[2998:32B8][2019-12-09T10:15:43]i301: Applying execute package: SpcCatalog, action: Install, path: C:\ProgramData\Package Cache\{D6F32D32-986F-4A51-8992-B83F18009F32}v3.1.4.5\SPCSetup.3.1.4.5.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7"'[2998:32B8][2019-12-09T10:15:44]e000: Error 0x80070643: Failed to install MSI package.[2998:32B8][2019-12-09T10:15:44]e000: Error 0x80070643: Failed to execute MSI package.[31D8:307C][2019-12-09T10:15:44]e000: Error 0x80070643: Failed to configure per-machine MSI package.[31D8:307C][2019-12-09T10:15:44]i000: Installed package SpcCatalog[31D8:307C][2019-12-09T10:15:44]i319: Applied execute package: SpcCatalog, result: 0x80070643, restart: None[31D8:307C][2019-12-09T10:15:44]e000: Error 0x80070643: Failed to execute MSI package.[2998:32B8][2019-12-09T10:15:44]i329: Removed package dependency provider: {D6F32D32-986F-4A51-8992-B83F18009F32}, package: SpcCatalog[2998:32B8][2019-12-09T10:15:44]i351: Removing cached package: SpcCatalog, from path: C:\ProgramData\Package Cache\{D6F32D32-986F-4A51-8992-B83F18009F32}v3.1.4.5\[31D8:31DC][2019-12-09T10:15:44]i000: ErrorPage Code: -2147023293[2998:32B8][2019-12-09T10:15:44]i326: Removed dependency: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3} on package provider: {D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}, package SqlCE35SP2_x64[2998:32B8][2019-12-09T10:15:44]i329: Removed package dependency provider: {D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}, package: SqlCE35SP2_x64[2998:32B8][2019-12-09T10:15:44]i326: Removed dependency: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3} on package provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, package SqlCE35SP2_x86[2998:32B8][2019-12-09T10:15:44]i329: Removed package dependency provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, package: SqlCE35SP2_x86[31D8:307C][2019-12-09T10:15:44]i000: Installation chain finished package from [2998:32B8][2019-12-09T10:15:44]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}, resume: None, restart: None, disable resume: No[2998:32B8][2019-12-09T10:15:44]i330: Removed bundle dependency provider: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}[2998:32B8][2019-12-09T10:15:44]i352: Removing cached bundle: {1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}, from path: C:\ProgramData\Package Cache\{1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}\[2998:32B8][2019-12-09T10:15:44]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1b3e46f9-12d8-4e17-bee7-55b0b2a511c3}, resume: None, restart initiated: No, disable resume: No[31D8:307C][2019-12-09T10:15:44]i000: No application is set for launch after installation[31D8:307C][2019-12-09T10:15:44]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\22564\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_2_20191209101443.zip'[31D8:307C][2019-12-09T10:15:44]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
The log file seems to indicate that you are using Windows v6.1. I think that may be causing the whole problem.
The following operating systems are supported.
You may try following the possible solutions explained here: https://www.drivereasy.com/knowledge/fix-error-0x80070643-on-windows/
I helped a RAM Connection user who ran into this problem when updating RAM Connection today. The exact same error codes were identified in his log file. Here is what we did to resolve the problem and get the current version installed:
1. Uninstalled all previous versions of the program. In the other user's case, we found that the previous version of RAM Connection would not uninstall manually. We downloaded the Microsoft uninstall/install utility from the web page below to remove it:
https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
2. Proceeded with install with current version. In the other case, we downloaded the installation file from the Software Download page, right clicked on the file after downloading, and ran it as an administrator. I am not sure if running as an administrator was required, but thought I should mention that with these steps.
Thank Sye...
I managed to install.. just need to update my window.
Thank Modestas...
