RAM Frame: Dynamic Mass Offset
I have a model in which the periods and effective mass modal participation is different for each of these dynamic load cases:
1. Modal Analysis ( Dynamic with No Ecc)
2. Dynamic with + Eccentricity (5%)
3. Dynamic with - Eccentricity (5%)
Does RAM shift the center of mass to alternate points offset ( eccentric locations) from the original calculated center of mass and modifying the mass moment of inertia?
Also, if that is the case, then per Section 12.9.5 of ASCE 7-10 we would not need to apply "Ax" i.e. Amplification of Accidental torsion. My question is why do you mention here in this post ( link below) about Ax?
 https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/2980/ram-frame-seismic-loads-faq
Please let me know. Thanks!
