Hello all, wish you a happy new year.
I am new to RAM Concept , and recently I have started watching the learning paths available in Bentley learning server. Unfortunately the Project Workbook and the Data set links is broken for the RAM Concept learning paths. could you provide me with the Project Workbook and the Data set(RAM Concept files) for these topics in the Designing Concrete Slabs in RAM Concept learning path ( https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=109542 ) -Evaluating Punching shear - Designing Concrete slabs - Calculating load history deflections - Designing soil supported mat foundations - Performing Vibration analysis .
Thank you for your message. Unfortunately, it does appear that the links to the RAM Concept datasets are broken and we are working on fixing that. While we get this issue resolved, I have sent you the dataset files directly via email. Please let me know if you need anything else and I thank you for your patience.
Answer Verified By: Saed Al-Halteh
I am sorry I have meant RAM Connection learning path.https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=108517
Designing Shear Connections in RAM Connection Standalone
Designing Moment, Gusset, and Base Plate Connections in RAM Connection Standalone
Customizing the Connections Database in RAM Connection StandaloneMany thanks in advance for your help, Much appreciated.
Thank you for your message. I have sent you the dataset files for the RAM Connection courses. Please let me know if you need anything else.
