I'm using STAAD.Pro CE and when I run analysis of my structure I get the following error:
213. MEMBER 214. _GIRDERS 126 128 130 132 134 136 138 140 142 144 193 TO 240 257 TO 288 333 - 215. 334 TO 428 216. _BEAMS 29 TO 39 41 TO 43 52 TO 57 67 TO 72 82 TO 87 145 TO 192 241 TO 256 - 217. 289 TO 304 218. _STRINGERS 45 TO 51 60 TO 66 75 TO 81 90 TO 96 219. END GROUP DEFINITION 220. START USER TABLE 221. TABLE 1 C:\USERS\PROYECTISTA_AED\DESKTOP\PC\STAADPRO PROYECTOS\VETA -
*** ERROR : FILE NOT FOUND C:\USERS\PROYECTISTA_AED\DESKTOP\PC\STAADPRO PROYE
*********** END OF THE STAAD.Pro RUN ***********
I ensured that the upt file is in the same folder as the model, I deleted the section upt and cns files and created new ones but the error persists.
I spent a lot of time in the model so i cannot create a new one to solve the problem.
Can someone provide me some guidance? Thanks
Can you please upload the file here along with upt files?
If you are using an older version of STAAD.Pro, please upgrade it to the latest version (22.02.00.26). Hope this issue will not be there in the newer version
Please move the UPT file in the same folder where your STAAD file is located, in this way when will be adding a user table, only UPT file name will be added instead of path of the UPT file.
Please try to use a shorter path of the UPT file so that the line 221 ends in a single line
that worked thanks!
Is this above method working in update 5 of connect edition?
Divya
