Hi everyone
I have created some sections and after assigning while analysis the structure errors are coming related to section properties, reading memeber properties, you can see in the attachment .
can you pls help me how to resolve this issue.
Please attach the STAAD model
2X30-20Deg.STD
Sure, please check the attachment
Also, you are using IS801 code here, so you need to assign member property as cold form section
Dear User,
If you are trying to use IS 801 code, then you should take the properties available in cold formed database. No user provided data is currently supported by the program. IS 811 provides some shapes which are supported in the program. As you are trying to use user defined tube section, design is not supported for that profile. You may analyze the structure and use the forces and moments for further manual calculation.
can you please tell how to resolve this issue, if i will assign tube section from hot rolled tube section which available in Indian standard or tube section available in American cold form and design as per IS 801 still facing issue.
else how to design structure as per IS801 from tube section?
