I am attempting to find a way to export shear and moment information of particular beams to perform additional opening through beam and torsional checks outside of RAM concept. Besides cutting sections in the max Mx or Max Vy views is there a way to export the bending and shear diagrams for a beam design strip?
You can plot the desired diagrams (e,g for a specific load combo or rule set, then use File - Export drawing to export the plot to cad (DWG or DXF format) It will be to scale with peak values noted. Or you can use Tables - Strip forces to get the values at each section.
