I imported a model form Structural system into elements to design a cmu wall and I am getting an access violation error when running it in the module. Any ideas?
Try another model to make sure it's not a general issue. If it is, then reinstall. It might be a problem with the mechanical cover, so check the shell material and cover closely. Also make sure the analysis results look OK (i.e. review deflected shape).
