can i run mutiple analysis for a load combination?
i difined some basic load case, and then combined. Can i run mutiple analysis for the load combination.
I difined two sets of support, one for support on the ground and the other on a transportation lorry. I hope i can run both in a model.
thanks
Yes you can. Just ensure that you combine the loads using REPEAT LOADs. The first support condition should be followed by the first set of loads and/or REPEAT LOADs. Subsequently add the analysis command followed by CHANGE. Define the second set of supports. Add second set of loads and/or REPEAT LOADs. Add a second analysis command and CHANGE.
thanks a lot. can you give me a sample?
Shawn
