How does RAM calculate the Moment of Inertia of a composite section (AISC)
Looking at the reports for a typical composite beam in RAM Structural System, I am seeing that RAM outputs I-effective (Ieff) and I-transformed (Itr) that are different from those listed in AISC Table 3-20 (Lower Bound Elastic Moment of Inertia for Plastic Composite Sections). I understand that this is because AISC presents lower-bound values and that this is due to a simplification made while producing an equivalent concrete area in their methodology.
RAM is clearly using a different method that produces a stiffer assembly. I'd like to know if their is a supporting calculation somewhere that details the exact methodology RAM is using to get numbers for Ieff and Itr. Also, can the methodology behind composite beam stiffness be changed somewhere per user preferences?
