I am facing issue while importing .MDB file in RCDC. Please suggest.
Following is screenshot
Can you please share your accdb file to check the issue from end. Meanwhile can you repair the access run time driver in control panel.
can you please raise a SR. Meanwhile i am checking your file at my end.
SR means a Service Request on Bentley portal in order to address your query and get connected to you for the same.
