Hello Guys,at work I have to import static models from STAAD into other calculation software. I would like to copy all information into excel and then from excel into final software.I’m sure that there are some openSTAAD experts on this forum who solved similar problems in the past.I would like to export from STAAD all information about geometry, material and loads.
Can I get example of openSTAAD code to implement it in excel myself?
Best regards,Tomasz
Hi guys I found part of required example here: https://www.civilnstructural.com/soft-tools/openstaad-how-to-get-the-geometry-of-staad-into-excel-sheet/
Is this possible to select all members with openSTAAD function?
regards
yes, you can get all the model information of your STAAD file from on using various OpenSTAAD functions.
All the documented functions are available in the Open STAAD help manual.
