Hello Everyone,
Can I change the Reference name of the user defined section in STAAD ? I tried defining a pipe and Reference name is "user defined pipe". Can i change it through editor?
Also, I tried once it was giving some error as name already in library but it was not.
Any input will be highly appreciated. Thanks alot
Yes, you can do that. you need to change the name in editor in 2 places. First is the place where user table has been defined i.e. in between Start user table and End command. After changing the name there, you need to change the name where it has been assigned against member numbers in member property block. Now if you try to run the file it should run ok. If you still face any issue please upload the file here.
Thanks Abhisek. Much appreciated.
