Plate Stress Interpretation using Von Mise and/or with Master Slave Command
Can anyone help me interpret the result of analysis where I modelled group of plates to resist a certain Pipe Load.
Loads are acted on Node 340 then Slaved to the point where the bolt of the U-type pipe support will be located.
My question is I am getting high values of plate stresses where I think it is too big for the load.
Maybe I am wrong and please enlighten me If my staad  model is correct.
Thank you in advance.
Attached below is my Staad file
HPR-S03.STD
