I work in IT for my company and one of my users has started getting the error below after updating Staad.Pro to V22030028:
"SPC Server Path not found. Please check the SPC Server Installation."
Hoping for a quicker fix than complete re-install, or to check if this is a known issue.
EDIT: Turns out a re-install was already done before this issue was brought to my attention, with no changes to the error. Out of several users who installed this same update, only one is having this problem.
This does not seem familiar. I think the first thing to try is to reinstall STAAD.Pro by running the installation as administrator.
A re-install was actually tried before this was brought to my attention, so this didn't fix the issue.
Is Bentley SPC Server available in the Programs and Features? If yes, what version of it?
Yes, it's listed as SPC Server v8i SS4, version 08.11.11.21
Please uninstall the Bentley SPC Server v8i SS4 using the Add/Remove Programs. Try starting STAAD.Pro and see if you still get the message.
Answer Verified By: Tristen Wilson
