Is there a way to display whether each member is in compression or tension after running the analysis? Such as an option that turns all members in compression blue and all members in tension red?
Yes you can do that. Ensure that the plot of axial forces is turned on and then right click inside the window and choose Labels and use the setting below
Answer Verified By: Kris Lajambe
