Hi, Dear All,
I came across a potential bug in STAAD.Pro CE V22 Update 3.
I tried to perform Circular Repeat on certain elements. First, I picked the elements using beam cursor in the display window. Then I used the circular repeat button in the tool ribbon. This gave me no problem. Then I tried another way to do the same operation. I selected the elements using beam table. Once I did that, the translation repeat, mirror and circular repeat buttons are all muted in the ribbon so I could not circular repeat the elements I selected in the beam table. Could you please verify and fix this issue? Thank you so much for the help.
Dong
After selecting the beams from beam table please click on the geometry tab as shown below. Then all the options will be available. Please check and let me know if it helps.
Answer Verified By: Dong Wang
Hi, Dear Abhisek,
Thank you so much for the help. It works for me. Still I hope we do not have to go through re-click the geometry since I am already in this tab. Anyway, thanks a lot.
