Regarded Staad pro connect edition
Hello Everyone.
Can anyone provide the solution don't know what happend with connect version 20.00.00.28 update 3.
When i analysis the model in series 6 model is work fine but when i m going to import it connect edition it will breakdown the entire model into so many part.
I attached my model here you can see in property tab and loading tab.
As i m going to project ASAP but project will delay with that problem than if this is happend everytime than why i m going to work with that version??
If again i want to open same model in Series 6 than having Same problem. In that case u need to do whole process again.
Error like to may exposure entries.
Provide me Solution ASAP.
Please.CH123.std
