CONCRETE SLAB DESIGN OUTPUT UNIT OF MEASURE
Good evening,
I’d like to ask if it possible to change the unit of measure relating to STAAD concrete slab design, in particular, relating to longitudinal an transversal reinforcements as indicated below:
In the previous figure, the program gives the minimum steel reinforcement required expressed in mm^2 /mm. For convenience, I prefer to obtain results in mm^/m. Is there a command or a function to set in order to change output unit of measure?
Thank you, regard
Silvia
