i am designing using RC design module on staad pro CE and i got this warning
"At least one span of this beam has length < 3 times depth. Deep Beams are not included in this implementation."
is there anything that can be done to it
This message says that this beam should be designed as a deep beam, but this is not implemented in the program.RC Designer was deprecated from the latest STAAD.Pro CE version, so I would recommend you in using the Advanced Concrete Design workflow (RCDC) which has far more capabilities in designing the concrete structures.
I tried using a friend’s rcdc 9.4 but eurocode 2 was giving me null error in my deep beam design
