STAAD Pro Advanced CONNECT v22 Update 3 - No Steel Design Results
I have a large model which in the normal STAAD Pro CONNECT v22 Update 2 took over 11 hours to run.  I made some minor updates by adding some plan bracing and updated the effective lengths to try and remove some failures.  I then updated to v22 Update 3 prior to rerunning the model overnight.  When I came into the office in the morning expecting to have some results to work with I found that it had time out after 10 hours with an error about the solver,  on looking ion this forum it suggests that it is possible due to lack of available memory which I find hard to believe as there is plenty of available memory on my machine and the result file should only be about 100MB.  Also on the forum it suggested that I use the Advanced solver licence.
l turned on the Advanced solver module using "configuration" and now the model runs in 10 minutes.  However there are limited results to work with, an in particular there are no steel design results and member Usage Factors.  Why is this?  How do I run the model with the Advanced solver and still get the full results?
The std file is attached
Richard MIcklewright18.45 MM7 2020.02.20 WIND (TENSION ONLY) - NEW BRACING BY RM - UPDATED X-BRACING.STD
Parents Reply Children
