In previous versions of STAAD Pro (in particular v8i Series 5 and 6) you could undertake a buckling analysis and view the buckled shapes.
On STAAD Pro Connect Edition I am able to undertake a buckling analysis and identify the eigenvalue but I am not able to view the buckled shape associated with that eigenvalue. Please could someone give me some guidance as to how I can view the buckled shape on STAAD Pro Connect Edition. If I can't view the buckled shape I cannot have confidence that the eigenvalues are representing a buckling mode which can occur in reality.
H
Hi Henry,
In CONNECT Edition versions, one needs to use the following input to get the Buckling modes in Postprocessing:
PERFORM BUCKLING EIGEN
See details in STAAD.Pro Help manual chapter TR.37.4.
PERFORM BUCKLING EIGEN does not solve the issue unfortunately. PERFORM BUCKLING EIGEN is not a command that is recognised. Can you please give an example of the syntax that I should be adding to the below.
I am using the STAAD Pro Connect Edition with the advanced solver.
STAAD SPACESTART JOB INFORMATIONENGINEER DATE 11-Apr-19END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES2 0.837 0 0; 3 0.824284 0 -0.145344; 4 0.786523 0 -0.286271;5 0.724863 0 -0.4185; 6 0.641179 0 -0.538013; 7 0.538013 0 -0.641179;8 0.4185 0 -0.724863; 9 0.286271 0 -0.786523; 10 0.145344 0 -0.824284;11 5.12498e-17 0 -0.837; 12 -0.145344 0 -0.824284; 13 -0.286271 0 -0.786523;14 -0.4185 0 -0.724863; 15 -0.538013 0 -0.641179; 16 -0.641179 0 -0.538013;17 -0.724863 0 -0.4185; 18 -0.786523 0 -0.286271; 19 -0.824284 0 -0.145344;20 -0.837 0 -1.025e-16; 21 -0.824284 0 0.145344; 22 -0.786523 0 0.286271;23 -0.724863 0 0.4185; 24 -0.641179 0 0.538013; 25 -0.538013 0 0.641179;26 -0.4185 0 0.724863; 27 -0.286271 0 0.786523; 28 -0.145344 0 0.824284;29 -1.53749e-16 0 0.837; 30 0.145344 0 0.824284; 31 0.286271 0 0.786523;32 0.4185 0 0.724863; 33 0.538013 0 0.641179; 34 0.641179 0 0.538013;35 0.724863 0 0.4185; 36 0.786523 0 0.286271; 37 0.824284 0 0.145344;39 0.837 0.15 0; 40 0.824284 0.15 -0.145344; 41 0.786523 0.15 -0.286271;42 0.724863 0.15 -0.4185; 43 0.641179 0.15 -0.538013;44 0.538013 0.15 -0.641179; 45 0.4185 0.15 -0.724863;46 0.286271 0.15 -0.786523; 47 0.145344 0.15 -0.824284;48 5.12498e-17 0.15 -0.837; 49 -0.145344 0.15 -0.824284;50 -0.286271 0.15 -0.786523; 51 -0.4185 0.15 -0.724863;52 -0.538013 0.15 -0.641179; 53 -0.641179 0.15 -0.538013;54 -0.724863 0.15 -0.4185; 55 -0.786523 0.15 -0.286271;56 -0.824284 0.15 -0.145344; 57 -0.837 0.15 -1.025e-16;58 -0.824284 0.15 0.145344; 59 -0.786523 0.15 0.286271;60 -0.724863 0.15 0.4185; 61 -0.641179 0.15 0.538013;62 -0.538013 0.15 0.641179; 63 -0.4185 0.15 0.724863;64 -0.286271 0.15 0.786523; 65 -0.145344 0.15 0.824284;66 -1.53749e-16 0.15 0.837; 67 0.145344 0.15 0.824284;68 0.286271 0.15 0.786523; 69 0.4185 0.15 0.724863; 70 0.538013 0.15 0.641179;71 0.641179 0.15 0.538013; 72 0.724863 0.15 0.4185; 73 0.786523 0.15 0.286271;74 0.824284 0.15 0.145344; 76 0.837 0.3 0; 77 0.824284 0.3 -0.145344;78 0.786523 0.3 -0.286271; 79 0.724863 0.3 -0.4185; 80 0.641179 0.3 -0.538013;81 0.538013 0.3 -0.641179; 82 0.4185 0.3 -0.724863; 83 0.286271 0.3 -0.786523;84 0.145344 0.3 -0.824284; 85 5.12498e-17 0.3 -0.837;86 -0.145344 0.3 -0.824284; 87 -0.286271 0.3 -0.786523;88 -0.4185 0.3 -0.724863; 89 -0.538013 0.3 -0.641179;90 -0.641179 0.3 -0.538013; 91 -0.724863 0.3 -0.4185;92 -0.786523 0.3 -0.286271; 93 -0.824284 0.3 -0.145344;94 -0.837 0.3 -1.025e-16; 95 -0.824284 0.3 0.145344; 96 -0.786523 0.3 0.286271;97 -0.724863 0.3 0.4185; 98 -0.641179 0.3 0.538013; 99 -0.538013 0.3 0.641179;100 -0.4185 0.3 0.724863; 101 -0.286271 0.3 0.786523;102 -0.145344 0.3 0.824284; 103 -1.53749e-16 0.3 0.837;104 0.145344 0.3 0.824284; 105 0.286271 0.3 0.786523; 106 0.4185 0.3 0.724863;107 0.538013 0.3 0.641179; 108 0.641179 0.3 0.538013; 109 0.724863 0.3 0.4185;110 0.786523 0.3 0.286271; 111 0.824284 0.3 0.145344; 113 0.837 0.45 0;114 0.824284 0.45 -0.145344; 115 0.786523 0.45 -0.286271;116 0.724863 0.45 -0.4185; 117 0.641179 0.45 -0.538013;118 0.538013 0.45 -0.641179; 119 0.4185 0.45 -0.724863;120 0.286271 0.45 -0.786523; 121 0.145344 0.45 -0.824284;122 5.12498e-17 0.45 -0.837; 123 -0.145344 0.45 -0.824284;124 -0.286271 0.45 -0.786523; 125 -0.4185 0.45 -0.724863;126 -0.538013 0.45 -0.641179; 127 -0.641179 0.45 -0.538013;128 -0.724863 0.45 -0.4185; 129 -0.786523 0.45 -0.286271;130 -0.824284 0.45 -0.145344; 131 -0.837 0.45 -1.025e-16;132 -0.824284 0.45 0.145344; 133 -0.786523 0.45 0.286271;134 -0.724863 0.45 0.4185; 135 -0.641179 0.45 0.538013;136 -0.538013 0.45 0.641179; 137 -0.4185 0.45 0.724863;138 -0.286271 0.45 0.786523; 139 -0.145344 0.45 0.824284;140 -1.53749e-16 0.45 0.837; 141 0.145344 0.45 0.824284;142 0.286271 0.45 0.786523; 143 0.4185 0.45 0.724863;144 0.538013 0.45 0.641179; 145 0.641179 0.45 0.538013;146 0.724863 0.45 0.4185; 147 0.786523 0.45 0.286271;148 0.824284 0.45 0.145344; 150 0.837 0.6 0; 151 0.824284 0.6 -0.145344;152 0.786523 0.6 -0.286271; 153 0.724863 0.6 -0.4185;154 0.641179 0.6 -0.538013; 155 0.538013 0.6 -0.641179;156 0.4185 0.6 -0.724863; 157 0.286271 0.6 -0.786523;158 0.145344 0.6 -0.824284; 159 5.12498e-17 0.6 -0.837;160 -0.145344 0.6 -0.824284; 161 -0.286271 0.6 -0.786523;162 -0.4185 0.6 -0.724863; 163 -0.538013 0.6 -0.641179;164 -0.641179 0.6 -0.538013; 165 -0.724863 0.6 -0.4185;166 -0.786523 0.6 -0.286271; 167 -0.824284 0.6 -0.145344;168 -0.837 0.6 -1.025e-16; 169 -0.824284 0.6 0.145344;170 -0.786523 0.6 0.286271; 171 -0.724863 0.6 0.4185;172 -0.641179 0.6 0.538013; 173 -0.538013 0.6 0.641179;174 -0.4185 0.6 0.724863; 175 -0.286271 0.6 0.786523;176 -0.145344 0.6 0.824284; 177 -1.53749e-16 0.6 0.837;178 0.145344 0.6 0.824284; 179 0.286271 0.6 0.786523; 180 0.4185 0.6 0.724863;181 0.538013 0.6 0.641179; 182 0.641179 0.6 0.538013; 183 0.724863 0.6 0.4185;184 0.786523 0.6 0.286271; 185 0.824284 0.6 0.145344; 187 0.837 0.75 0;188 0.824284 0.75 -0.145344; 189 0.786523 0.75 -0.286271;190 0.724863 0.75 -0.4185; 191 0.641179 0.75 -0.538013;192 0.538013 0.75 -0.641179; 193 0.4185 0.75 -0.724863;194 0.286271 0.75 -0.786523; 195 0.145344 0.75 -0.824284;196 5.12498e-17 0.75 -0.837; 197 -0.145344 0.75 -0.824284;198 -0.286271 0.75 -0.786523; 199 -0.4185 0.75 -0.724863;200 -0.538013 0.75 -0.641179; 201 -0.641179 0.75 -0.538013;202 -0.724863 0.75 -0.4185; 203 -0.786523 0.75 -0.286271;204 -0.824284 0.75 -0.145344; 205 -0.837 0.75 -1.025e-16;206 -0.824284 0.75 0.145344; 207 -0.786523 0.75 0.286271;208 -0.724863 0.75 0.4185; 209 -0.641179 0.75 0.538013;210 -0.538013 0.75 0.641179; 211 -0.4185 0.75 0.724863;212 -0.286271 0.75 0.786523; 213 -0.145344 0.75 0.824284;214 -1.53749e-16 0.75 0.837; 215 0.145344 0.75 0.824284;216 0.286271 0.75 0.786523; 217 0.4185 0.75 0.724863;218 0.538013 0.75 0.641179; 219 0.641179 0.75 0.538013;220 0.724863 0.75 0.4185; 221 0.786523 0.75 0.286271;222 0.824284 0.75 0.145344; 224 0.837 0.9 0; 225 0.824284 0.9 -0.145344;226 0.786523 0.9 -0.286271; 227 0.724863 0.9 -0.4185;228 0.641179 0.9 -0.538013; 229 0.538013 0.9 -0.641179;230 0.4185 0.9 -0.724863; 231 0.286271 0.9 -0.786523;232 0.145344 0.9 -0.824284; 233 5.12498e-17 0.9 -0.837;234 -0.145344 0.9 -0.824284; 235 -0.286271 0.9 -0.786523;236 -0.4185 0.9 -0.724863; 237 -0.538013 0.9 -0.641179;238 -0.641179 0.9 -0.538013; 239 -0.724863 0.9 -0.4185;240 -0.786523 0.9 -0.286271; 241 -0.824284 0.9 -0.145344;242 -0.837 0.9 -1.025e-16; 243 -0.824284 0.9 0.145344;244 -0.786523 0.9 0.286271; 245 -0.724863 0.9 0.4185;246 -0.641179 0.9 0.538013; 247 -0.538013 0.9 0.641179;248 -0.4185 0.9 0.724863; 249 -0.286271 0.9 0.786523;250 -0.145344 0.9 0.824284; 251 -1.53749e-16 0.9 0.837;252 0.145344 0.9 0.824284; 253 0.286271 0.9 0.786523; 254 0.4185 0.9 0.724863;255 0.538013 0.9 0.641179; 256 0.641179 0.9 0.538013; 257 0.724863 0.9 0.4185;258 0.786523 0.9 0.286271; 259 0.824284 0.9 0.145344; 261 0.837 1.05 0;262 0.824284 1.05 -0.145344; 263 0.786523 1.05 -0.286271;264 0.724863 1.05 -0.4185; 265 0.641179 1.05 -0.538013;266 0.538013 1.05 -0.641179; 267 0.4185 1.05 -0.724863;268 0.286271 1.05 -0.786523; 269 0.145344 1.05 -0.824284;270 5.12498e-17 1.05 -0.837; 271 -0.145344 1.05 -0.824284;272 -0.286271 1.05 -0.786523; 273 -0.4185 1.05 -0.724863;274 -0.538013 1.05 -0.641179; 275 -0.641179 1.05 -0.538013;276 -0.724863 1.05 -0.4185; 277 -0.786523 1.05 -0.286271;278 -0.824284 1.05 -0.145344; 279 -0.837 1.05 -1.025e-16;280 -0.824284 1.05 0.145344; 281 -0.786523 1.05 0.286271;282 -0.724863 1.05 0.4185; 283 -0.641179 1.05 0.538013;284 -0.538013 1.05 0.641179; 285 -0.4185 1.05 0.724863;286 -0.286271 1.05 0.786523; 287 -0.145344 1.05 0.824284;288 -1.53749e-16 1.05 0.837; 289 0.145344 1.05 0.824284;290 0.286271 1.05 0.786523; 291 0.4185 1.05 0.724863;292 0.538013 1.05 0.641179; 293 0.641179 1.05 0.538013;294 0.724863 1.05 0.4185; 295 0.786523 1.05 0.286271;296 0.824284 1.05 0.145344; 298 0.837 1.2 0; 299 0.824284 1.2 -0.145344;300 0.786523 1.2 -0.286271; 301 0.724863 1.2 -0.4185;302 0.641179 1.2 -0.538013; 303 0.538013 1.2 -0.641179;304 0.4185 1.2 -0.724863; 305 0.286271 1.2 -0.786523;306 0.145344 1.2 -0.824284; 307 5.12498e-17 1.2 -0.837;308 -0.145344 1.2 -0.824284; 309 -0.286271 1.2 -0.786523;310 -0.4185 1.2 -0.724863; 311 -0.538013 1.2 -0.641179;312 -0.641179 1.2 -0.538013; 313 -0.724863 1.2 -0.4185;314 -0.786523 1.2 -0.286271; 315 -0.824284 1.2 -0.145344;316 -0.837 1.2 -1.025e-16; 317 -0.824284 1.2 0.145344;318 -0.786523 1.2 0.286271; 319 -0.724863 1.2 0.4185;320 -0.641179 1.2 0.538013; 321 -0.538013 1.2 0.641179;322 -0.4185 1.2 0.724863; 323 -0.286271 1.2 0.786523;324 -0.145344 1.2 0.824284; 325 -1.53749e-16 1.2 0.837;326 0.145344 1.2 0.824284; 327 0.286271 1.2 0.786523; 328 0.4185 1.2 0.724863;329 0.538013 1.2 0.641179; 330 0.641179 1.2 0.538013; 331 0.724863 1.2 0.4185;332 0.786523 1.2 0.286271; 333 0.824284 1.2 0.145344; 335 0.837 1.35 0;336 0.824284 1.35 -0.145344; 337 0.786523 1.35 -0.286271;338 0.724863 1.35 -0.4185; 339 0.641179 1.35 -0.538013;340 0.538013 1.35 -0.641179; 341 0.4185 1.35 -0.724863;342 0.286271 1.35 -0.786523; 343 0.145344 1.35 -0.824284;344 5.12498e-17 1.35 -0.837; 345 -0.145344 1.35 -0.824284;346 -0.286271 1.35 -0.786523; 347 -0.4185 1.35 -0.724863;348 -0.538013 1.35 -0.641179; 349 -0.641179 1.35 -0.538013;350 -0.724863 1.35 -0.4185; 351 -0.786523 1.35 -0.286271;352 -0.824284 1.35 -0.145344; 353 -0.837 1.35 -1.025e-16;354 -0.824284 1.35 0.145344; 355 -0.786523 1.35 0.286271;356 -0.724863 1.35 0.4185; 357 -0.641179 1.35 0.538013;358 -0.538013 1.35 0.641179; 359 -0.4185 1.35 0.724863;360 -0.286271 1.35 0.786523; 361 -0.145344 1.35 0.824284;362 -1.53749e-16 1.35 0.837; 363 0.145344 1.35 0.824284;364 0.286271 1.35 0.786523; 365 0.4185 1.35 0.724863;366 0.538013 1.35 0.641179; 367 0.641179 1.35 0.538013;368 0.724863 1.35 0.4185; 369 0.786523 1.35 0.286271;370 0.824284 1.35 0.145344; 372 0.837 1.5 0; 373 0.824284 1.5 -0.145344;374 0.786523 1.5 -0.286271; 375 0.724863 1.5 -0.4185;376 0.641179 1.5 -0.538013; 377 0.538013 1.5 -0.641179;378 0.4185 1.5 -0.724863; 379 0.286271 1.5 -0.786523;380 0.145344 1.5 -0.824284; 381 5.12498e-17 1.5 -0.837;382 -0.145344 1.5 -0.824284; 383 -0.286271 1.5 -0.786523;384 -0.4185 1.5 -0.724863; 385 -0.538013 1.5 -0.641179;386 -0.641179 1.5 -0.538013; 387 -0.724863 1.5 -0.4185;388 -0.786523 1.5 -0.286271; 389 -0.824284 1.5 -0.145344;390 -0.837 1.5 -1.025e-16; 391 -0.824284 1.5 0.145344;392 -0.786523 1.5 0.286271; 393 -0.724863 1.5 0.4185;394 -0.641179 1.5 0.538013; 395 -0.538013 1.5 0.641179;396 -0.4185 1.5 0.724863; 397 -0.286271 1.5 0.786523;398 -0.145344 1.5 0.824284; 399 -1.53749e-16 1.5 0.837;400 0.145344 1.5 0.824284; 401 0.286271 1.5 0.786523; 402 0.4185 1.5 0.724863;403 0.538013 1.5 0.641179; 404 0.641179 1.5 0.538013; 405 0.724863 1.5 0.4185;406 0.786523 1.5 0.286271; 407 0.824284 1.5 0.145344; 409 0.837 1.65 0;410 0.824284 1.65 -0.145344; 411 0.786523 1.65 -0.286271;412 0.724863 1.65 -0.4185; 413 0.641179 1.65 -0.538013;414 0.538013 1.65 -0.641179; 415 0.4185 1.65 -0.724863;416 0.286271 1.65 -0.786523; 417 0.145344 1.65 -0.824284;418 5.12498e-17 1.65 -0.837; 419 -0.145344 1.65 -0.824284;420 -0.286271 1.65 -0.786523; 421 -0.4185 1.65 -0.724863;422 -0.538013 1.65 -0.641179; 423 -0.641179 1.65 -0.538013;424 -0.724863 1.65 -0.4185; 425 -0.786523 1.65 -0.286271;426 -0.824284 1.65 -0.145344; 427 -0.837 1.65 -1.025e-16;428 -0.824284 1.65 0.145344; 429 -0.786523 1.65 0.286271;430 -0.724863 1.65 0.4185; 431 -0.641179 1.65 0.538013;432 -0.538013 1.65 0.641179; 433 -0.4185 1.65 0.724863;434 -0.286271 1.65 0.786523; 435 -0.145344 1.65 0.824284;436 -1.53749e-16 1.65 0.837; 437 0.145344 1.65 0.824284;438 0.286271 1.65 0.786523; 439 0.4185 1.65 0.724863;440 0.538013 1.65 0.641179; 441 0.641179 1.65 0.538013;442 0.724863 1.65 0.4185; 443 0.786523 1.65 0.286271;444 0.824284 1.65 0.145344; 446 0.837 1.8 0; 447 0.824284 1.8 -0.145344;448 0.786523 1.8 -0.286271; 449 0.724863 1.8 -0.4185;450 0.641179 1.8 -0.538013; 451 0.538013 1.8 -0.641179;452 0.4185 1.8 -0.724863; 453 0.286271 1.8 -0.786523;454 0.145344 1.8 -0.824284; 455 5.12498e-17 1.8 -0.837;456 -0.145344 1.8 -0.824284; 457 -0.286271 1.8 -0.786523;458 -0.4185 1.8 -0.724863; 459 -0.538013 1.8 -0.641179;460 -0.641179 1.8 -0.538013; 461 -0.724863 1.8 -0.4185;462 -0.786523 1.8 -0.286271; 463 -0.824284 1.8 -0.145344;464 -0.837 1.8 -1.025e-16; 465 -0.824284 1.8 0.145344;466 -0.786523 1.8 0.286271; 467 -0.724863 1.8 0.4185;468 -0.641179 1.8 0.538013; 469 -0.538013 1.8 0.641179;470 -0.4185 1.8 0.724863; 471 -0.286271 1.8 0.786523;472 -0.145344 1.8 0.824284; 473 -1.53749e-16 1.8 0.837;474 0.145344 1.8 0.824284; 475 0.286271 1.8 0.786523; 476 0.4185 1.8 0.724863;477 0.538013 1.8 0.641179; 478 0.641179 1.8 0.538013; 479 0.724863 1.8 0.4185;480 0.786523 1.8 0.286271; 481 0.824284 1.8 0.145344; 483 0.837 1.95 0;484 0.824284 1.95 -0.145344; 485 0.786523 1.95 -0.286271;486 0.724863 1.95 -0.4185; 487 0.641179 1.95 -0.538013;488 0.538013 1.95 -0.641179; 489 0.4185 1.95 -0.724863;490 0.286271 1.95 -0.786523; 491 0.145344 1.95 -0.824284;492 5.12498e-17 1.95 -0.837; 493 -0.145344 1.95 -0.824284;494 -0.286271 1.95 -0.786523; 495 -0.4185 1.95 -0.724863;496 -0.538013 1.95 -0.641179; 497 -0.641179 1.95 -0.538013;498 -0.724863 1.95 -0.4185; 499 -0.786523 1.95 -0.286271;500 -0.824284 1.95 -0.145344; 501 -0.837 1.95 -1.025e-16;502 -0.824284 1.95 0.145344; 503 -0.786523 1.95 0.286271;504 -0.724863 1.95 0.4185; 505 -0.641179 1.95 0.538013;506 -0.538013 1.95 0.641179; 507 -0.4185 1.95 0.724863;508 -0.286271 1.95 0.786523; 509 -0.145344 1.95 0.824284;510 -1.53749e-16 1.95 0.837; 511 0.145344 1.95 0.824284;512 0.286271 1.95 0.786523; 513 0.4185 1.95 0.724863;514 0.538013 1.95 0.641179; 515 0.641179 1.95 0.538013;516 0.724863 1.95 0.4185; 517 0.786523 1.95 0.286271;518 0.824284 1.95 0.145344; 520 0.837 2.1 0; 521 0.824284 2.1 -0.145344;522 0.786523 2.1 -0.286271; 523 0.724863 2.1 -0.4185;524 0.641179 2.1 -0.538013; 525 0.538013 2.1 -0.641179;526 0.4185 2.1 -0.724863; 527 0.286271 2.1 -0.786523;528 0.145344 2.1 -0.824284; 529 5.12498e-17 2.1 -0.837;530 -0.145344 2.1 -0.824284; 531 -0.286271 2.1 -0.786523;532 -0.4185 2.1 -0.724863; 533 -0.538013 2.1 -0.641179;534 -0.641179 2.1 -0.538013; 535 -0.724863 2.1 -0.4185;536 -0.786523 2.1 -0.286271; 537 -0.824284 2.1 -0.145344;538 -0.837 2.1 -1.025e-16; 539 -0.824284 2.1 0.145344;540 -0.786523 2.1 0.286271; 541 -0.724863 2.1 0.4185;542 -0.641179 2.1 0.538013; 543 -0.538013 2.1 0.641179;544 -0.4185 2.1 0.724863; 545 -0.286271 2.1 0.786523;546 -0.145344 2.1 0.824284; 547 -1.53749e-16 2.1 0.837;548 0.145344 2.1 0.824284; 549 0.286271 2.1 0.786523; 550 0.4185 2.1 0.724863;551 0.538013 2.1 0.641179; 552 0.641179 2.1 0.538013; 553 0.724863 2.1 0.4185;554 0.786523 2.1 0.286271; 555 0.824284 2.1 0.145344; 557 0.837 2.25 0;558 0.824284 2.25 -0.145344; 559 0.786523 2.25 -0.286271;560 0.724863 2.25 -0.4185; 561 0.641179 2.25 -0.538013;562 0.538013 2.25 -0.641179; 563 0.4185 2.25 -0.724863;564 0.286271 2.25 -0.786523; 565 0.145344 2.25 -0.824284;566 5.12498e-17 2.25 -0.837; 567 -0.145344 2.25 -0.824284;568 -0.286271 2.25 -0.786523; 569 -0.4185 2.25 -0.724863;570 -0.538013 2.25 -0.641179; 571 -0.641179 2.25 -0.538013;572 -0.724863 2.25 -0.4185; 573 -0.786523 2.25 -0.286271;574 -0.824284 2.25 -0.145344; 575 -0.837 2.25 -1.025e-16;576 -0.824284 2.25 0.145344; 577 -0.786523 2.25 0.286271;578 -0.724863 2.25 0.4185; 579 -0.641179 2.25 0.538013;580 -0.538013 2.25 0.641179; 581 -0.4185 2.25 0.724863;582 -0.286271 2.25 0.786523; 583 -0.145344 2.25 0.824284;584 -1.53749e-16 2.25 0.837; 585 0.145344 2.25 0.824284;586 0.286271 2.25 0.786523; 587 0.4185 2.25 0.724863;588 0.538013 2.25 0.641179; 589 0.641179 2.25 0.538013;590 0.724863 2.25 0.4185; 591 0.786523 2.25 0.286271;592 0.824284 2.25 0.145344; 594 0.837 2.4 0; 595 0.824284 2.4 -0.145344;596 0.786523 2.4 -0.286271; 597 0.724863 2.4 -0.4185;598 0.641179 2.4 -0.538013; 599 0.538013 2.4 -0.641179;600 0.4185 2.4 -0.724863; 601 0.286271 2.4 -0.786523;602 0.145344 2.4 -0.824284; 603 5.12498e-17 2.4 -0.837;604 -0.145344 2.4 -0.824284; 605 -0.286271 2.4 -0.786523;606 -0.4185 2.4 -0.724863; 607 -0.538013 2.4 -0.641179;608 -0.641179 2.4 -0.538013; 609 -0.724863 2.4 -0.4185;610 -0.786523 2.4 -0.286271; 611 -0.824284 2.4 -0.145344;612 -0.837 2.4 -1.025e-16; 613 -0.824284 2.4 0.145344;614 -0.786523 2.4 0.286271; 615 -0.724863 2.4 0.4185;616 -0.641179 2.4 0.538013; 617 -0.538013 2.4 0.641179;618 -0.4185 2.4 0.724863; 619 -0.286271 2.4 0.786523;620 -0.145344 2.4 0.824284; 621 -1.53749e-16 2.4 0.837;622 0.145344 2.4 0.824284; 623 0.286271 2.4 0.786523; 624 0.4185 2.4 0.724863;625 0.538013 2.4 0.641179; 626 0.641179 2.4 0.538013; 627 0.724863 2.4 0.4185;628 0.786523 2.4 0.286271; 629 0.824284 2.4 0.145344; 631 0.837 2.55 0;632 0.824284 2.55 -0.145344; 633 0.786523 2.55 -0.286271;634 0.724863 2.55 -0.4185; 635 0.641179 2.55 -0.538013;636 0.538013 2.55 -0.641179; 637 0.4185 2.55 -0.724863;638 0.286271 2.55 -0.786523; 639 0.145344 2.55 -0.824284;640 5.12498e-17 2.55 -0.837; 641 -0.145344 2.55 -0.824284;642 -0.286271 2.55 -0.786523; 643 -0.4185 2.55 -0.724863;644 -0.538013 2.55 -0.641179; 645 -0.641179 2.55 -0.538013;646 -0.724863 2.55 -0.4185; 647 -0.786523 2.55 -0.286271;648 -0.824284 2.55 -0.145344; 649 -0.837 2.55 -1.025e-16;650 -0.824284 2.55 0.145344; 651 -0.786523 2.55 0.286271;652 -0.724863 2.55 0.4185; 653 -0.641179 2.55 0.538013;654 -0.538013 2.55 0.641179; 655 -0.4185 2.55 0.724863;656 -0.286271 2.55 0.786523; 657 -0.145344 2.55 0.824284;658 -1.53749e-16 2.55 0.837; 659 0.145344 2.55 0.824284;660 0.286271 2.55 0.786523; 661 0.4185 2.55 0.724863;662 0.538013 2.55 0.641179; 663 0.641179 2.55 0.538013;664 0.724863 2.55 0.4185; 665 0.786523 2.55 0.286271;666 0.824284 2.55 0.145344; 667 0.837 2.7 0; 668 0.824284 2.7 -0.145344;669 0.786523 2.7 -0.286271; 670 0.724863 2.7 -0.4185;671 0.641179 2.7 -0.538013; 672 0.538013 2.7 -0.641179;673 0.4185 2.7 -0.724863; 674 0.286271 2.7 -0.786523;675 0.145344 2.7 -0.824284; 676 5.12498e-17 2.7 -0.837;677 -0.145344 2.7 -0.824284; 678 -0.286271 2.7 -0.786523;679 -0.4185 2.7 -0.724863; 680 -0.538013 2.7 -0.641179;681 -0.641179 2.7 -0.538013; 682 -0.724863 2.7 -0.4185;683 -0.786523 2.7 -0.286271; 684 -0.824284 2.7 -0.145344;685 -0.837 2.7 -1.025e-16; 686 -0.824284 2.7 0.145344;687 -0.786523 2.7 0.286271; 688 -0.724863 2.7 0.4185;689 -0.641179 2.7 0.538013; 690 -0.538013 2.7 0.641179;691 -0.4185 2.7 0.724863; 692 -0.286271 2.7 0.786523;693 -0.145344 2.7 0.824284; 694 -1.53749e-16 2.7 0.837;695 0.145344 2.7 0.824284; 696 0.286271 2.7 0.786523; 697 0.4185 2.7 0.724863;698 0.538013 2.7 0.641179; 699 0.641179 2.7 0.538013; 700 0.724863 2.7 0.4185;701 0.786523 2.7 0.286271; 702 0.824284 2.7 0.145344; 703 0.837 2.85 0;704 0.824284 2.85 -0.145344; 705 0.786523 2.85 -0.286271;706 0.724863 2.85 -0.4185; 707 0.641179 2.85 -0.538013;708 0.538013 2.85 -0.641179; 709 0.4185 2.85 -0.724863;710 0.286271 2.85 -0.786523; 711 0.145344 2.85 -0.824284;712 5.12498e-17 2.85 -0.837; 713 -0.145344 2.85 -0.824284;714 -0.286271 2.85 -0.786523; 715 -0.4185 2.85 -0.724863;716 -0.538013 2.85 -0.641179; 717 -0.641179 2.85 -0.538013;718 -0.724863 2.85 -0.4185; 719 -0.786523 2.85 -0.286271;720 -0.824284 2.85 -0.145344; 721 -0.837 2.85 -1.025e-16;722 -0.824284 2.85 0.145344; 723 -0.786523 2.85 0.286271;724 -0.724863 2.85 0.4185; 725 -0.641179 2.85 0.538013;726 -0.538013 2.85 0.641179; 727 -0.4185 2.85 0.724863;728 -0.286271 2.85 0.786523; 729 -0.145344 2.85 0.824284;730 -1.53749e-16 2.85 0.837; 731 0.145344 2.85 0.824284;732 0.286271 2.85 0.786523; 733 0.4185 2.85 0.724863;734 0.538013 2.85 0.641179; 735 0.641179 2.85 0.538013;736 0.724863 2.85 0.4185; 737 0.786523 2.85 0.286271;738 0.824284 2.85 0.145344; 739 0.837 3 0; 740 0.824284 3 -0.145344;741 0.786523 3 -0.286271; 742 0.724863 3 -0.4185; 743 0.641179 3 -0.538013;744 0.538013 3 -0.641179; 745 0.4185 3 -0.724863; 746 0.286271 3 -0.786523;747 0.145344 3 -0.824284; 748 5.12498e-17 3 -0.837; 749 -0.145344 3 -0.824284;750 -0.286271 3 -0.786523; 751 -0.4185 3 -0.724863; 752 -0.538013 3 -0.641179;753 -0.641179 3 -0.538013; 754 -0.724863 3 -0.4185; 755 -0.786523 3 -0.286271;756 -0.824284 3 -0.145344; 757 -0.837 3 -1.025e-16; 758 -0.824284 3 0.145344;759 -0.786523 3 0.286271; 760 -0.724863 3 0.4185; 761 -0.641179 3 0.538013;762 -0.538013 3 0.641179; 763 -0.4185 3 0.724863; 764 -0.286271 3 0.786523;765 -0.145344 3 0.824284; 766 -1.53749e-16 3 0.837; 767 0.145344 3 0.824284;768 0.286271 3 0.786523; 769 0.4185 3 0.724863; 770 0.538013 3 0.641179;771 0.641179 3 0.538013; 772 0.724863 3 0.4185; 773 0.786523 3 0.286271;774 0.824284 3 0.145344; 775 0.837 3.15 0; 776 0.824284 3.15 -0.145344;777 0.786523 3.15 -0.286271; 778 0.724863 3.15 -0.4185;779 0.641179 3.15 -0.538013; 780 0.538013 3.15 -0.641179;781 0.4185 3.15 -0.724863; 782 0.286271 3.15 -0.786523;783 0.145344 3.15 -0.824284; 784 5.12498e-17 3.15 -0.837;785 -0.145344 3.15 -0.824284; 786 -0.286271 3.15 -0.786523;787 -0.4185 3.15 -0.724863; 788 -0.538013 3.15 -0.641179;789 -0.641179 3.15 -0.538013; 790 -0.724863 3.15 -0.4185;791 -0.786523 3.15 -0.286271; 792 -0.824284 3.15 -0.145344;793 -0.837 3.15 -1.025e-16; 794 -0.824284 3.15 0.145344;795 -0.786523 3.15 0.286271; 796 -0.724863 3.15 0.4185;797 -0.641179 3.15 0.538013; 798 -0.538013 3.15 0.641179;799 -0.4185 3.15 0.724863; 800 -0.286271 3.15 0.786523;801 -0.145344 3.15 0.824284; 802 -1.53749e-16 3.15 0.837;803 0.145344 3.15 0.824284; 804 0.286271 3.15 0.786523;805 0.4185 3.15 0.724863; 806 0.538013 3.15 0.641179;807 0.641179 3.15 0.538013; 808 0.724863 3.15 0.4185;809 0.786523 3.15 0.286271; 810 0.824284 3.15 0.145344; 811 0.837 3.3 0;812 0.824284 3.3 -0.145344; 813 0.786523 3.3 -0.286271;814 0.724863 3.3 -0.4185; 815 0.641179 3.3 -0.538013;816 0.538013 3.3 -0.641179; 817 0.4185 3.3 -0.724863;818 0.286271 3.3 -0.786523; 819 0.145344 3.3 -0.824284;820 5.12498e-17 3.3 -0.837; 821 -0.145344 3.3 -0.824284;822 -0.286271 3.3 -0.786523; 823 -0.4185 3.3 -0.724863;824 -0.538013 3.3 -0.641179; 825 -0.641179 3.3 -0.538013;826 -0.724863 3.3 -0.4185; 827 -0.786523 3.3 -0.286271;828 -0.824284 3.3 -0.145344; 829 -0.837 3.3 -1.025e-16;830 -0.824284 3.3 0.145344; 831 -0.786523 3.3 0.286271;832 -0.724863 3.3 0.4185; 833 -0.641179 3.3 0.538013;834 -0.538013 3.3 0.641179; 835 -0.4185 3.3 0.724863;836 -0.286271 3.3 0.786523; 837 -0.145344 3.3 0.824284;838 -1.53749e-16 3.3 0.837; 839 0.145344 3.3 0.824284;840 0.286271 3.3 0.786523; 841 0.4185 3.3 0.724863; 842 0.538013 3.3 0.641179;843 0.641179 3.3 0.538013; 844 0.724863 3.3 0.4185; 845 0.786523 3.3 0.286271;846 0.824284 3.3 0.145344; 847 0.837 3.45 0; 848 0.824284 3.45 -0.145344;849 0.786523 3.45 -0.286271; 850 0.724863 3.45 -0.4185;851 0.641179 3.45 -0.538013; 852 0.538013 3.45 -0.641179;853 0.4185 3.45 -0.724863; 854 0.286271 3.45 -0.786523;855 0.145344 3.45 -0.824284; 856 5.12498e-17 3.45 -0.837;857 -0.145344 3.45 -0.824284; 858 -0.286271 3.45 -0.786523;859 -0.4185 3.45 -0.724863; 860 -0.538013 3.45 -0.641179;861 -0.641179 3.45 -0.538013; 862 -0.724863 3.45 -0.4185;863 -0.786523 3.45 -0.286271; 864 -0.824284 3.45 -0.145344;865 -0.837 3.45 -1.025e-16; 866 -0.824284 3.45 0.145344;867 -0.786523 3.45 0.286271; 868 -0.724863 3.45 0.4185;869 -0.641179 3.45 0.538013; 870 -0.538013 3.45 0.641179;871 -0.4185 3.45 0.724863; 872 -0.286271 3.45 0.786523;873 -0.145344 3.45 0.824284; 874 -1.53749e-16 3.45 0.837;875 0.145344 3.45 0.824284; 876 0.286271 3.45 0.786523;877 0.4185 3.45 0.724863; 878 0.538013 3.45 0.641179;879 0.641179 3.45 0.538013; 880 0.724863 3.45 0.4185;881 0.786523 3.45 0.286271; 882 0.824284 3.45 0.145344; 883 0.837 3.6 0;884 0.824284 3.6 -0.145344; 885 0.786523 3.6 -0.286271;886 0.724863 3.6 -0.4185; 887 0.641179 3.6 -0.538013;888 0.538013 3.6 -0.641179; 889 0.4185 3.6 -0.724863;890 0.286271 3.6 -0.786523; 891 0.145344 3.6 -0.824284;892 5.12498e-17 3.6 -0.837; 893 -0.145344 3.6 -0.824284;894 -0.286271 3.6 -0.786523; 895 -0.4185 3.6 -0.724863;896 -0.538013 3.6 -0.641179; 897 -0.641179 3.6 -0.538013;898 -0.724863 3.6 -0.4185; 899 -0.786523 3.6 -0.286271;900 -0.824284 3.6 -0.145344; 901 -0.837 3.6 -1.025e-16;902 -0.824284 3.6 0.145344; 903 -0.786523 3.6 0.286271;904 -0.724863 3.6 0.4185; 905 -0.641179 3.6 0.538013;906 -0.538013 3.6 0.641179; 907 -0.4185 3.6 0.724863;908 -0.286271 3.6 0.786523; 909 -0.145344 3.6 0.824284;910 -1.53749e-16 3.6 0.837; 911 0.145344 3.6 0.824284;912 0.286271 3.6 0.786523; 913 0.4185 3.6 0.724863; 914 0.538013 3.6 0.641179;915 0.641179 3.6 0.538013; 916 0.724863 3.6 0.4185; 917 0.786523 3.6 0.286271;918 0.824284 3.6 0.145344; 919 0.837 3.75 0; 920 0.824284 3.75 -0.145344;921 0.786523 3.75 -0.286271; 922 0.724863 3.75 -0.4185;923 0.641179 3.75 -0.538013; 924 0.538013 3.75 -0.641179;925 0.4185 3.75 -0.724863; 926 0.286271 3.75 -0.786523;927 0.145344 3.75 -0.824284; 928 5.12498e-17 3.75 -0.837;929 -0.145344 3.75 -0.824284; 930 -0.286271 3.75 -0.786523;931 -0.4185 3.75 -0.724863; 932 -0.538013 3.75 -0.641179;933 -0.641179 3.75 -0.538013; 934 -0.724863 3.75 -0.4185;935 -0.786523 3.75 -0.286271; 936 -0.824284 3.75 -0.145344;937 -0.837 3.75 -1.025e-16; 938 -0.824284 3.75 0.145344;939 -0.786523 3.75 0.286271; 940 -0.724863 3.75 0.4185;941 -0.641179 3.75 0.538013; 942 -0.538013 3.75 0.641179;943 -0.4185 3.75 0.724863; 944 -0.286271 3.75 0.786523;945 -0.145344 3.75 0.824284; 946 -1.53749e-16 3.75 0.837;947 0.145344 3.75 0.824284; 948 0.286271 3.75 0.786523;949 0.4185 3.75 0.724863; 950 0.538013 3.75 0.641179;951 0.641179 3.75 0.538013; 952 0.724863 3.75 0.4185;953 0.786523 3.75 0.286271; 954 0.824284 3.75 0.145344; 955 0.837 3.9 0;956 0.824284 3.9 -0.145344; 957 0.786523 3.9 -0.286271;958 0.724863 3.9 -0.4185; 959 0.641179 3.9 -0.538013;960 0.538013 3.9 -0.641179; 961 0.4185 3.9 -0.724863;962 0.286271 3.9 -0.786523; 963 0.145344 3.9 -0.824284;964 5.12498e-17 3.9 -0.837; 965 -0.145344 3.9 -0.824284;966 -0.286271 3.9 -0.786523; 967 -0.4185 3.9 -0.724863;968 -0.538013 3.9 -0.641179; 969 -0.641179 3.9 -0.538013;970 -0.724863 3.9 -0.4185; 971 -0.786523 3.9 -0.286271;972 -0.824284 3.9 -0.145344; 973 -0.837 3.9 -1.025e-16;974 -0.824284 3.9 0.145344; 975 -0.786523 3.9 0.286271;976 -0.724863 3.9 0.4185; 977 -0.641179 3.9 0.538013;978 -0.538013 3.9 0.641179; 979 -0.4185 3.9 0.724863;980 -0.286271 3.9 0.786523; 981 -0.145344 3.9 0.824284;982 -1.53749e-16 3.9 0.837; 983 0.145344 3.9 0.824284;984 0.286271 3.9 0.786523; 985 0.4185 3.9 0.724863; 986 0.538013 3.9 0.641179;987 0.641179 3.9 0.538013; 988 0.724863 3.9 0.4185; 989 0.786523 3.9 0.286271;990 0.824284 3.9 0.145344; 991 0.837 4.05 0; 992 0.824284 4.05 -0.145344;993 0.786523 4.05 -0.286271; 994 0.724863 4.05 -0.4185;995 0.641179 4.05 -0.538013; 996 0.538013 4.05 -0.641179;997 0.4185 4.05 -0.724863; 998 0.286271 4.05 -0.786523;999 0.145344 4.05 -0.824284; 1000 5.12498e-17 4.05 -0.837;1001 -0.145344 4.05 -0.824284; 1002 -0.286271 4.05 -0.786523;1003 -0.4185 4.05 -0.724863; 1004 -0.538013 4.05 -0.641179;1005 -0.641179 4.05 -0.538013; 1006 -0.724863 4.05 -0.4185;1007 -0.786523 4.05 -0.286271; 1008 -0.824284 4.05 -0.145344;1009 -0.837 4.05 -1.025e-16; 1010 -0.824284 4.05 0.145344;1011 -0.786523 4.05 0.286271; 1012 -0.724863 4.05 0.4185;1013 -0.641179 4.05 0.538013; 1014 -0.538013 4.05 0.641179;1015 -0.4185 4.05 0.724863; 1016 -0.286271 4.05 0.786523;1017 -0.145344 4.05 0.824284; 1018 -1.53749e-16 4.05 0.837;1019 0.145344 4.05 0.824284; 1020 0.286271 4.05 0.786523;1021 0.4185 4.05 0.724863; 1022 0.538013 4.05 0.641179;1023 0.641179 4.05 0.538013; 1024 0.724863 4.05 0.4185;1025 0.786523 4.05 0.286271; 1026 0.824284 4.05 0.145344; 1027 0.837 4.2 0;1028 0.824284 4.2 -0.145344; 1029 0.786523 4.2 -0.286271;1030 0.724863 4.2 -0.4185; 1031 0.641179 4.2 -0.538013;1032 0.538013 4.2 -0.641179; 1033 0.4185 4.2 -0.724863;1034 0.286271 4.2 -0.786523; 1035 0.145344 4.2 -0.824284;1036 5.12498e-17 4.2 -0.837; 1037 -0.145344 4.2 -0.824284;1038 -0.286271 4.2 -0.786523; 1039 -0.4185 4.2 -0.724863;1040 -0.538013 4.2 -0.641179; 1041 -0.641179 4.2 -0.538013;1042 -0.724863 4.2 -0.4185; 1043 -0.786523 4.2 -0.286271;1044 -0.824284 4.2 -0.145344; 1045 -0.837 4.2 -1.025e-16;1046 -0.824284 4.2 0.145344; 1047 -0.786523 4.2 0.286271;1048 -0.724863 4.2 0.4185; 1049 -0.641179 4.2 0.538013;1050 -0.538013 4.2 0.641179; 1051 -0.4185 4.2 0.724863;1052 -0.286271 4.2 0.786523; 1053 -0.145344 4.2 0.824284;1054 -1.53749e-16 4.2 0.837; 1055 0.145344 4.2 0.824284;1056 0.286271 4.2 0.786523; 1057 0.4185 4.2 0.724863;1058 0.538013 4.2 0.641179; 1059 0.641179 4.2 0.538013;1060 0.724863 4.2 0.4185; 1061 0.786523 4.2 0.286271;1062 0.824284 4.2 0.145344; 1063 0.837 4.35 0; 1064 0.824284 4.35 -0.145344;1065 0.786523 4.35 -0.286271; 1066 0.724863 4.35 -0.4185;1067 0.641179 4.35 -0.538013; 1068 0.538013 4.35 -0.641179;1069 0.4185 4.35 -0.724863; 1070 0.286271 4.35 -0.786523;1071 0.145344 4.35 -0.824284; 1072 5.12498e-17 4.35 -0.837;1073 -0.145344 4.35 -0.824284; 1074 -0.286271 4.35 -0.786523;1075 -0.4185 4.35 -0.724863; 1076 -0.538013 4.35 -0.641179;1077 -0.641179 4.35 -0.538013; 1078 -0.724863 4.35 -0.4185;1079 -0.786523 4.35 -0.286271; 1080 -0.824284 4.35 -0.145344;1081 -0.837 4.35 -1.025e-16; 1082 -0.824284 4.35 0.145344;1083 -0.786523 4.35 0.286271; 1084 -0.724863 4.35 0.4185;1085 -0.641179 4.35 0.538013; 1086 -0.538013 4.35 0.641179;1087 -0.4185 4.35 0.724863; 1088 -0.286271 4.35 0.786523;1089 -0.145344 4.35 0.824284; 1090 -1.53749e-16 4.35 0.837;1091 0.145344 4.35 0.824284; 1092 0.286271 4.35 0.786523;1093 0.4185 4.35 0.724863; 1094 0.538013 4.35 0.641179;1095 0.641179 4.35 0.538013; 1096 0.724863 4.35 0.4185;1097 0.786523 4.35 0.286271; 1098 0.824284 4.35 0.145344; 1099 0.837 4.5 0;1100 0.824284 4.5 -0.145344; 1101 0.786523 4.5 -0.286271;1102 0.724863 4.5 -0.4185; 1103 0.641179 4.5 -0.538013;1104 0.538013 4.5 -0.641179; 1105 0.4185 4.5 -0.724863;1106 0.286271 4.5 -0.786523; 1107 0.145344 4.5 -0.824284;1108 5.12498e-17 4.5 -0.837; 1109 -0.145344 4.5 -0.824284;1110 -0.286271 4.5 -0.786523; 1111 -0.4185 4.5 -0.724863;1112 -0.538013 4.5 -0.641179; 1113 -0.641179 4.5 -0.538013;1114 -0.724863 4.5 -0.4185; 1115 -0.786523 4.5 -0.286271;1116 -0.824284 4.5 -0.145344; 1117 -0.837 4.5 -1.025e-16;1118 -0.824284 4.5 0.145344; 1119 -0.786523 4.5 0.286271;1120 -0.724863 4.5 0.4185; 1121 -0.641179 4.5 0.538013;1122 -0.538013 4.5 0.641179; 1123 -0.4185 4.5 0.724863;1124 -0.286271 4.5 0.786523; 1125 -0.145344 4.5 0.824284;1126 -1.53749e-16 4.5 0.837; 1127 0.145344 4.5 0.824284;1128 0.286271 4.5 0.786523; 1129 0.4185 4.5 0.724863;1130 0.538013 4.5 0.641179; 1131 0.641179 4.5 0.538013;1132 0.724863 4.5 0.4185; 1133 0.786523 4.5 0.286271;1134 0.824284 4.5 0.145344; 1135 0.837 4.65 0; 1136 0.824284 4.65 -0.145344;1137 0.786523 4.65 -0.286271; 1138 0.724863 4.65 -0.4185;1139 0.641179 4.65 -0.538013; 1140 0.538013 4.65 -0.641179;1141 0.4185 4.65 -0.724863; 1142 0.286271 4.65 -0.786523;1143 0.145344 4.65 -0.824284; 1144 5.12498e-17 4.65 -0.837;1145 -0.145344 4.65 -0.824284; 1146 -0.286271 4.65 -0.786523;1147 -0.4185 4.65 -0.724863; 1148 -0.538013 4.65 -0.641179;1149 -0.641179 4.65 -0.538013; 1150 -0.724863 4.65 -0.4185;1151 -0.786523 4.65 -0.286271; 1152 -0.824284 4.65 -0.145344;1153 -0.837 4.65 -1.025e-16; 1154 -0.824284 4.65 0.145344;1155 -0.786523 4.65 0.286271; 1156 -0.724863 4.65 0.4185;1157 -0.641179 4.65 0.538013; 1158 -0.538013 4.65 0.641179;1159 -0.4185 4.65 0.724863; 1160 -0.286271 4.65 0.786523;1161 -0.145344 4.65 0.824284; 1162 -1.53749e-16 4.65 0.837;1163 0.145344 4.65 0.824284; 1164 0.286271 4.65 0.786523;1165 0.4185 4.65 0.724863; 1166 0.538013 4.65 0.641179;1167 0.641179 4.65 0.538013; 1168 0.724863 4.65 0.4185;1169 0.786523 4.65 0.286271; 1170 0.824284 4.65 0.145344; 1171 0.837 4.8 0;1172 0.824284 4.8 -0.145344; 1173 0.786523 4.8 -0.286271;1174 0.724863 4.8 -0.4185; 1175 0.641179 4.8 -0.538013;1176 0.538013 4.8 -0.641179; 1177 0.4185 4.8 -0.724863;1178 0.286271 4.8 -0.786523; 1179 0.145344 4.8 -0.824284;1180 5.12498e-17 4.8 -0.837; 1181 -0.145344 4.8 -0.824284;1182 -0.286271 4.8 -0.786523; 1183 -0.4185 4.8 -0.724863;1184 -0.538013 4.8 -0.641179; 1185 -0.641179 4.8 -0.538013;1186 -0.724863 4.8 -0.4185; 1187 -0.786523 4.8 -0.286271;1188 -0.824284 4.8 -0.145344; 1189 -0.837 4.8 -1.025e-16;1190 -0.824284 4.8 0.145344; 1191 -0.786523 4.8 0.286271;1192 -0.724863 4.8 0.4185; 1193 -0.641179 4.8 0.538013;1194 -0.538013 4.8 0.641179; 1195 -0.4185 4.8 0.724863;1196 -0.286271 4.8 0.786523; 1197 -0.145344 4.8 0.824284;1198 -1.53749e-16 4.8 0.837; 1199 0.145344 4.8 0.824284;1200 0.286271 4.8 0.786523; 1201 0.4185 4.8 0.724863;1202 0.538013 4.8 0.641179; 1203 0.641179 4.8 0.538013;1204 0.724863 4.8 0.4185; 1205 0.786523 4.8 0.286271;1206 0.824284 4.8 0.145344; 1207 0.837 4.95 0; 1208 0.824284 4.95 -0.145344;1209 0.786523 4.95 -0.286271; 1210 0.724863 4.95 -0.4185;1211 0.641179 4.95 -0.538013; 1212 0.538013 4.95 -0.641179;1213 0.4185 4.95 -0.724863; 1214 0.286271 4.95 -0.786523;1215 0.145344 4.95 -0.824284; 1216 5.12498e-17 4.95 -0.837;1217 -0.145344 4.95 -0.824284; 1218 -0.286271 4.95 -0.786523;1219 -0.4185 4.95 -0.724863; 1220 -0.538013 4.95 -0.641179;1221 -0.641179 4.95 -0.538013; 1222 -0.724863 4.95 -0.4185;1223 -0.786523 4.95 -0.286271; 1224 -0.824284 4.95 -0.145344;1225 -0.837 4.95 -1.025e-16; 1226 -0.824284 4.95 0.145344;1227 -0.786523 4.95 0.286271; 1228 -0.724863 4.95 0.4185;1229 -0.641179 4.95 0.538013; 1230 -0.538013 4.95 0.641179;1231 -0.4185 4.95 0.724863; 1232 -0.286271 4.95 0.786523;1233 -0.145344 4.95 0.824284; 1234 -1.53749e-16 4.95 0.837;1235 0.145344 4.95 0.824284; 1236 0.286271 4.95 0.786523;1237 0.4185 4.95 0.724863; 1238 0.538013 4.95 0.641179;1239 0.641179 4.95 0.538013; 1240 0.724863 4.95 0.4185;1241 0.786523 4.95 0.286271; 1242 0.824284 4.95 0.145344; 1243 0.837 5.1 0;1244 0.824284 5.1 -0.145344; 1245 0.786523 5.1 -0.286271;1246 0.724863 5.1 -0.4185; 1247 0.641179 5.1 -0.538013;1248 0.538013 5.1 -0.641179; 1249 0.4185 5.1 -0.724863;1250 0.286271 5.1 -0.786523; 1251 0.145344 5.1 -0.824284;1252 5.12498e-17 5.1 -0.837; 1253 -0.145344 5.1 -0.824284;1254 -0.286271 5.1 -0.786523; 1255 -0.4185 5.1 -0.724863;1256 -0.538013 5.1 -0.641179; 1257 -0.641179 5.1 -0.538013;1258 -0.724863 5.1 -0.4185; 1259 -0.786523 5.1 -0.286271;1260 -0.824284 5.1 -0.145344; 1261 -0.837 5.1 -1.025e-16;1262 -0.824284 5.1 0.145344; 1263 -0.786523 5.1 0.286271;1264 -0.724863 5.1 0.4185; 1265 -0.641179 5.1 0.538013;1266 -0.538013 5.1 0.641179; 1267 -0.4185 5.1 0.724863;1268 -0.286271 5.1 0.786523; 1269 -0.145344 5.1 0.824284;1270 -1.53749e-16 5.1 0.837; 1271 0.145344 5.1 0.824284;1272 0.286271 5.1 0.786523; 1273 0.4185 5.1 0.724863;1274 0.538013 5.1 0.641179; 1275 0.641179 5.1 0.538013;1276 0.724863 5.1 0.4185; 1277 0.786523 5.1 0.286271;1278 0.824284 5.1 0.145344; 1279 0.837 5.25 0; 1280 0.824284 5.25 -0.145344;1281 0.786523 5.25 -0.286271; 1282 0.724863 5.25 -0.4185;1283 0.641179 5.25 -0.538013; 1284 0.538013 5.25 -0.641179;1285 0.4185 5.25 -0.724863; 1286 0.286271 5.25 -0.786523;1287 0.145344 5.25 -0.824284; 1288 5.12498e-17 5.25 -0.837;1289 -0.145344 5.25 -0.824284; 1290 -0.286271 5.25 -0.786523;1291 -0.4185 5.25 -0.724863; 1292 -0.538013 5.25 -0.641179;1293 -0.641179 5.25 -0.538013; 1294 -0.724863 5.25 -0.4185;1295 -0.786523 5.25 -0.286271; 1296 -0.824284 5.25 -0.145344;1297 -0.837 5.25 -1.025e-16; 1298 -0.824284 5.25 0.145344;1299 -0.786523 5.25 0.286271; 1300 -0.724863 5.25 0.4185;1301 -0.641179 5.25 0.538013; 1302 -0.538013 5.25 0.641179;1303 -0.4185 5.25 0.724863; 1304 -0.286271 5.25 0.786523;1305 -0.145344 5.25 0.824284; 1306 -1.53749e-16 5.25 0.837;1307 0.145344 5.25 0.824284; 1308 0.286271 5.25 0.786523;1309 0.4185 5.25 0.724863; 1310 0.538013 5.25 0.641179;1311 0.641179 5.25 0.538013; 1312 0.724863 5.25 0.4185;1313 0.786523 5.25 0.286271; 1314 0.824284 5.25 0.145344; 1315 0.837 5.4 0;1316 0.824284 5.4 -0.145344; 1317 0.786523 5.4 -0.286271;1318 0.724863 5.4 -0.4185; 1319 0.641179 5.4 -0.538013;1320 0.538013 5.4 -0.641179; 1321 0.4185 5.4 -0.724863;1322 0.286271 5.4 -0.786523; 1323 0.145344 5.4 -0.824284;1324 5.12498e-17 5.4 -0.837; 1325 -0.145344 5.4 -0.824284;1326 -0.286271 5.4 -0.786523; 1327 -0.4185 5.4 -0.724863;1328 -0.538013 5.4 -0.641179; 1329 -0.641179 5.4 -0.538013;1330 -0.724863 5.4 -0.4185; 1331 -0.786523 5.4 -0.286271;1332 -0.824284 5.4 -0.145344; 1333 -0.837 5.4 -1.025e-16;1334 -0.824284 5.4 0.145344; 1335 -0.786523 5.4 0.286271;1336 -0.724863 5.4 0.4185; 1337 -0.641179 5.4 0.538013;1338 -0.538013 5.4 0.641179; 1339 -0.4185 5.4 0.724863;1340 -0.286271 5.4 0.786523; 1341 -0.145344 5.4 0.824284;1342 -1.53749e-16 5.4 0.837; 1343 0.145344 5.4 0.824284;1344 0.286271 5.4 0.786523; 1345 0.4185 5.4 0.724863;1346 0.538013 5.4 0.641179; 1347 0.641179 5.4 0.538013;1348 0.724863 5.4 0.4185; 1349 0.786523 5.4 0.286271;1350 0.824284 5.4 0.145344; 1351 0.837 5.55 0; 1352 0.824284 5.55 -0.145344;1353 0.786523 5.55 -0.286271; 1354 0.724863 5.55 -0.4185;1355 0.641179 5.55 -0.538013; 1356 0.538013 5.55 -0.641179;1357 0.4185 5.55 -0.724863; 1358 0.286271 5.55 -0.786523;1359 0.145344 5.55 -0.824284; 1360 5.12498e-17 5.55 -0.837;1361 -0.145344 5.55 -0.824284; 1362 -0.286271 5.55 -0.786523;1363 -0.4185 5.55 -0.724863; 1364 -0.538013 5.55 -0.641179;1365 -0.641179 5.55 -0.538013; 1366 -0.724863 5.55 -0.4185;1367 -0.786523 5.55 -0.286271; 1368 -0.824284 5.55 -0.145344;1369 -0.837 5.55 -1.025e-16; 1370 -0.824284 5.55 0.145344;1371 -0.786523 5.55 0.286271; 1372 -0.724863 5.55 0.4185;1373 -0.641179 5.55 0.538013; 1374 -0.538013 5.55 0.641179;1375 -0.4185 5.55 0.724863; 1376 -0.286271 5.55 0.786523;1377 -0.145344 5.55 0.824284; 1378 -1.53749e-16 5.55 0.837;1379 0.145344 5.55 0.824284; 1380 0.286271 5.55 0.786523;1381 0.4185 5.55 0.724863; 1382 0.538013 5.55 0.641179;1383 0.641179 5.55 0.538013; 1384 0.724863 5.55 0.4185;1385 0.786523 5.55 0.286271; 1386 0.824284 5.55 0.145344; 1387 0.837 5.7 0;1388 0.824284 5.7 -0.145344; 1389 0.786523 5.7 -0.286271;1390 0.724863 5.7 -0.4185; 1391 0.641179 5.7 -0.538013;1392 0.538013 5.7 -0.641179; 1393 0.4185 5.7 -0.724863;1394 0.286271 5.7 -0.786523; 1395 0.145344 5.7 -0.824284;1396 5.12498e-17 5.7 -0.837; 1397 -0.145344 5.7 -0.824284;1398 -0.286271 5.7 -0.786523; 1399 -0.4185 5.7 -0.724863;1400 -0.538013 5.7 -0.641179; 1401 -0.641179 5.7 -0.538013;1402 -0.724863 5.7 -0.4185; 1403 -0.786523 5.7 -0.286271;1404 -0.824284 5.7 -0.145344; 1405 -0.837 5.7 -1.025e-16;1406 -0.824284 5.7 0.145344; 1407 -0.786523 5.7 0.286271;1408 -0.724863 5.7 0.4185; 1409 -0.641179 5.7 0.538013;1410 -0.538013 5.7 0.641179; 1411 -0.4185 5.7 0.724863;1412 -0.286271 5.7 0.786523; 1413 -0.145344 5.7 0.824284;1414 -1.53749e-16 5.7 0.837; 1415 0.145344 5.7 0.824284;1416 0.286271 5.7 0.786523; 1417 0.4185 5.7 0.724863;1418 0.538013 5.7 0.641179; 1419 0.641179 5.7 0.538013;1420 0.724863 5.7 0.4185; 1421 0.786523 5.7 0.286271;1422 0.824284 5.7 0.145344; 1423 0.837 5.85 0; 1424 0.824284 5.85 -0.145344;1425 0.786523 5.85 -0.286271; 1426 0.724863 5.85 -0.4185;1427 0.641179 5.85 -0.538013; 1428 0.538013 5.85 -0.641179;1429 0.4185 5.85 -0.724863; 1430 0.286271 5.85 -0.786523;1431 0.145344 5.85 -0.824284; 1432 5.12498e-17 5.85 -0.837;1433 -0.145344 5.85 -0.824284; 1434 -0.286271 5.85 -0.786523;1435 -0.4185 5.85 -0.724863; 1436 -0.538013 5.85 -0.641179;1437 -0.641179 5.85 -0.538013; 1438 -0.724863 5.85 -0.4185;1439 -0.786523 5.85 -0.286271; 1440 -0.824284 5.85 -0.145344;1441 -0.837 5.85 -1.025e-16; 1442 -0.824284 5.85 0.145344;1443 -0.786523 5.85 0.286271; 1444 -0.724863 5.85 0.4185;1445 -0.641179 5.85 0.538013; 1446 -0.538013 5.85 0.641179;1447 -0.4185 5.85 0.724863; 1448 -0.286271 5.85 0.786523;1449 -0.145344 5.85 0.824284; 1450 -1.53749e-16 5.85 0.837;1451 0.145344 5.85 0.824284; 1452 0.286271 5.85 0.786523;1453 0.4185 5.85 0.724863; 1454 0.538013 5.85 0.641179;1455 0.641179 5.85 0.538013; 1456 0.724863 5.85 0.4185;1457 0.786523 5.85 0.286271; 1458 0.824284 5.85 0.145344; 1459 0.837 6 0;1460 0.824284 6 -0.145344; 1461 0.786523 6 -0.286271; 1462 0.724863 6 -0.4185;1463 0.641179 6 -0.538013; 1464 0.538013 6 -0.641179; 1465 0.4185 6 -0.724863;1466 0.286271 6 -0.786523; 1467 0.145344 6 -0.824284;1468 5.12498e-17 6 -0.837; 1469 -0.145344 6 -0.824284;1470 -0.286271 6 -0.786523; 1471 -0.4185 6 -0.724863;1472 -0.538013 6 -0.641179; 1473 -0.641179 6 -0.538013;1474 -0.724863 6 -0.4185; 1475 -0.786523 6 -0.286271;1476 -0.824284 6 -0.145344; 1477 -0.837 6 -1.025e-16;1478 -0.824284 6 0.145344; 1479 -0.786523 6 0.286271; 1480 -0.724863 6 0.4185;1481 -0.641179 6 0.538013; 1482 -0.538013 6 0.641179; 1483 -0.4185 6 0.724863;1484 -0.286271 6 0.786523; 1485 -0.145344 6 0.824284;1486 -1.53749e-16 6 0.837; 1487 0.145344 6 0.824284; 1488 0.286271 6 0.786523;1489 0.4185 6 0.724863; 1490 0.538013 6 0.641179; 1491 0.641179 6 0.538013;1492 0.724863 6 0.4185; 1493 0.786523 6 0.286271; 1494 0.824284 6 0.145344;1495 0.837 6.15 0; 1496 0.824284 6.15 -0.145344; 1497 0.786523 6.15 -0.286271;1498 0.724863 6.15 -0.4185; 1499 0.641179 6.15 -0.538013;1500 0.538013 6.15 -0.641179; 1501 0.4185 6.15 -0.724863;1502 0.286271 6.15 -0.786523; 1503 0.145344 6.15 -0.824284;1504 5.12498e-17 6.15 -0.837; 1505 -0.145344 6.15 -0.824284;1506 -0.286271 6.15 -0.786523; 1507 -0.4185 6.15 -0.724863;1508 -0.538013 6.15 -0.641179; 1509 -0.641179 6.15 -0.538013;1510 -0.724863 6.15 -0.4185; 1511 -0.786523 6.15 -0.286271;1512 -0.824284 6.15 -0.145344; 1513 -0.837 6.15 -1.025e-16;1514 -0.824284 6.15 0.145344; 1515 -0.786523 6.15 0.286271;1516 -0.724863 6.15 0.4185; 1517 -0.641179 6.15 0.538013;1518 -0.538013 6.15 0.641179; 1519 -0.4185 6.15 0.724863;1520 -0.286271 6.15 0.786523; 1521 -0.145344 6.15 0.824284;1522 -1.53749e-16 6.15 0.837; 1523 0.145344 6.15 0.824284;1524 0.286271 6.15 0.786523; 1525 0.4185 6.15 0.724863;1526 0.538013 6.15 0.641179; 1527 0.641179 6.15 0.538013;1528 0.724863 6.15 0.4185; 1529 0.786523 6.15 0.286271;1530 0.824284 6.15 0.145344; 1531 0.837 6.3 0; 1532 0.824284 6.3 -0.145344;1533 0.786523 6.3 -0.286271; 1534 0.724863 6.3 -0.4185;1535 0.641179 6.3 -0.538013; 1536 0.538013 6.3 -0.641179;1537 0.4185 6.3 -0.724863; 1538 0.286271 6.3 -0.786523;1539 0.145344 6.3 -0.824284; 1540 5.12498e-17 6.3 -0.837;1541 -0.145344 6.3 -0.824284; 1542 -0.286271 6.3 -0.786523;1543 -0.4185 6.3 -0.724863; 1544 -0.538013 6.3 -0.641179;1545 -0.641179 6.3 -0.538013; 1546 -0.724863 6.3 -0.4185;1547 -0.786523 6.3 -0.286271; 1548 -0.824284 6.3 -0.145344;1549 -0.837 6.3 -1.025e-16; 1550 -0.824284 6.3 0.145344;1551 -0.786523 6.3 0.286271; 1552 -0.724863 6.3 0.4185;1553 -0.641179 6.3 0.538013; 1554 -0.538013 6.3 0.641179;1555 -0.4185 6.3 0.724863; 1556 -0.286271 6.3 0.786523;1557 -0.145344 6.3 0.824284; 1558 -1.53749e-16 6.3 0.837;1559 0.145344 6.3 0.824284; 1560 0.286271 6.3 0.786523;1561 0.4185 6.3 0.724863; 1562 0.538013 6.3 0.641179;1563 0.641179 6.3 0.538013; 1564 0.724863 6.3 0.4185;1565 0.786523 6.3 0.286271; 1566 0.824284 6.3 0.145344; 1567 0.837 6.45 0;1568 0.824284 6.45 -0.145344; 1569 0.786523 6.45 -0.286271;1570 0.724863 6.45 -0.4185; 1571 0.641179 6.45 -0.538013;1572 0.538013 6.45 -0.641179; 1573 0.4185 6.45 -0.724863;1574 0.286271 6.45 -0.786523; 1575 0.145344 6.45 -0.824284;1576 5.12498e-17 6.45 -0.837; 1577 -0.145344 6.45 -0.824284;1578 -0.286271 6.45 -0.786523; 1579 -0.4185 6.45 -0.724863;1580 -0.538013 6.45 -0.641179; 1581 -0.641179 6.45 -0.538013;1582 -0.724863 6.45 -0.4185; 1583 -0.786523 6.45 -0.286271;1584 -0.824284 6.45 -0.145344; 1585 -0.837 6.45 -1.025e-16;1586 -0.824284 6.45 0.145344; 1587 -0.786523 6.45 0.286271;1588 -0.724863 6.45 0.4185; 1589 -0.641179 6.45 0.538013;1590 -0.538013 6.45 0.641179; 1591 -0.4185 6.45 0.724863;1592 -0.286271 6.45 0.786523; 1593 -0.145344 6.45 0.824284;1594 -1.53749e-16 6.45 0.837; 1595 0.145344 6.45 0.824284;1596 0.286271 6.45 0.786523; 1597 0.4185 6.45 0.724863;1598 0.538013 6.45 0.641179; 1599 0.641179 6.45 0.538013;1600 0.724863 6.45 0.4185; 1601 0.786523 6.45 0.286271;1602 0.824284 6.45 0.145344; 1603 0.837 6.6 0; 1604 0.824284 6.6 -0.145344;1605 0.786523 6.6 -0.286271; 1606 0.724863 6.6 -0.4185;1607 0.641179 6.6 -0.538013; 1608 0.538013 6.6 -0.641179;1609 0.4185 6.6 -0.724863; 1610 0.286271 6.6 -0.786523;1611 0.145344 6.6 -0.824284; 1612 5.12498e-17 6.6 -0.837;1613 -0.145344 6.6 -0.824284; 1614 -0.286271 6.6 -0.786523;1615 -0.4185 6.6 -0.724863; 1616 -0.538013 6.6 -0.641179;1617 -0.641179 6.6 -0.538013; 1618 -0.724863 6.6 -0.4185;1619 -0.786523 6.6 -0.286271; 1620 -0.824284 6.6 -0.145344;1621 -0.837 6.6 -1.025e-16; 1622 -0.824284 6.6 0.145344;1623 -0.786523 6.6 0.286271; 1624 -0.724863 6.6 0.4185;1625 -0.641179 6.6 0.538013; 1626 -0.538013 6.6 0.641179;1627 -0.4185 6.6 0.724863; 1628 -0.286271 6.6 0.786523;1629 -0.145344 6.6 0.824284; 1630 -1.53749e-16 6.6 0.837;1631 0.145344 6.6 0.824284; 1632 0.286271 6.6 0.786523;1633 0.4185 6.6 0.724863; 1634 0.538013 6.6 0.641179;1635 0.641179 6.6 0.538013; 1636 0.724863 6.6 0.4185;1637 0.786523 6.6 0.286271; 1638 0.824284 6.6 0.145344; 1639 0.837 6.75 0;1640 0.824284 6.75 -0.145344; 1641 0.786523 6.75 -0.286271;1642 0.724863 6.75 -0.4185; 1643 0.641179 6.75 -0.538013;1644 0.538013 6.75 -0.641179; 1645 0.4185 6.75 -0.724863;1646 0.286271 6.75 -0.786523; 1647 0.145344 6.75 -0.824284;1648 5.12498e-17 6.75 -0.837; 1649 -0.145344 6.75 -0.824284;1650 -0.286271 6.75 -0.786523; 1651 -0.4185 6.75 -0.724863;1652 -0.538013 6.75 -0.641179; 1653 -0.641179 6.75 -0.538013;1654 -0.724863 6.75 -0.4185; 1655 -0.786523 6.75 -0.286271;1656 -0.824284 6.75 -0.145344; 1657 -0.837 6.75 -1.025e-16;1658 -0.824284 6.75 0.145344; 1659 -0.786523 6.75 0.286271;1660 -0.724863 6.75 0.4185; 1661 -0.641179 6.75 0.538013;1662 -0.538013 6.75 0.641179; 1663 -0.4185 6.75 0.724863;1664 -0.286271 6.75 0.786523; 1665 -0.145344 6.75 0.824284;1666 -1.53749e-16 6.75 0.837; 1667 0.145344 6.75 0.824284;1668 0.286271 6.75 0.786523; 1669 0.4185 6.75 0.724863;1670 0.538013 6.75 0.641179; 1671 0.641179 6.75 0.538013;1672 0.724863 6.75 0.4185; 1673 0.786523 6.75 0.286271;1674 0.824284 6.75 0.145344; 1675 0.837 6.9 0; 1676 0.824284 6.9 -0.145344;1677 0.786523 6.9 -0.286271; 1678 0.724863 6.9 -0.4185;1679 0.641179 6.9 -0.538013; 1680 0.538013 6.9 -0.641179;1681 0.4185 6.9 -0.724863; 1682 0.286271 6.9 -0.786523;1683 0.145344 6.9 -0.824284; 1684 5.12498e-17 6.9 -0.837;1685 -0.145344 6.9 -0.824284; 1686 -0.286271 6.9 -0.786523;1687 -0.4185 6.9 -0.724863; 1688 -0.538013 6.9 -0.641179;1689 -0.641179 6.9 -0.538013; 1690 -0.724863 6.9 -0.4185;1691 -0.786523 6.9 -0.286271; 1692 -0.824284 6.9 -0.145344;1693 -0.837 6.9 -1.025e-16; 1694 -0.824284 6.9 0.145344;1695 -0.786523 6.9 0.286271; 1696 -0.724863 6.9 0.4185;1697 -0.641179 6.9 0.538013; 1698 -0.538013 6.9 0.641179;1699 -0.4185 6.9 0.724863; 1700 -0.286271 6.9 0.786523;1701 -0.145344 6.9 0.824284; 1702 -1.53749e-16 6.9 0.837;1703 0.145344 6.9 0.824284; 1704 0.286271 6.9 0.786523;1705 0.4185 6.9 0.724863; 1706 0.538013 6.9 0.641179;1707 0.641179 6.9 0.538013; 1708 0.724863 6.9 0.4185;1709 0.786523 6.9 0.286271; 1710 0.824284 6.9 0.145344; 1711 0.837 7.05 0;1712 0.824284 7.05 -0.145344; 1713 0.786523 7.05 -0.286271;1714 0.724863 7.05 -0.4185; 1715 0.641179 7.05 -0.538013;1716 0.538013 7.05 -0.641179; 1717 0.4185 7.05 -0.724863;1718 0.286271 7.05 -0.786523; 1719 0.145344 7.05 -0.824284;1720 5.12498e-17 7.05 -0.837; 1721 -0.145344 7.05 -0.824284;1722 -0.286271 7.05 -0.786523; 1723 -0.4185 7.05 -0.724863;1724 -0.538013 7.05 -0.641179; 1725 -0.641179 7.05 -0.538013;1726 -0.724863 7.05 -0.4185; 1727 -0.786523 7.05 -0.286271;1728 -0.824284 7.05 -0.145344; 1729 -0.837 7.05 -1.025e-16;1730 -0.824284 7.05 0.145344; 1731 -0.786523 7.05 0.286271;1732 -0.724863 7.05 0.4185; 1733 -0.641179 7.05 0.538013;1734 -0.538013 7.05 0.641179; 1735 -0.4185 7.05 0.724863;1736 -0.286271 7.05 0.786523; 1737 -0.145344 7.05 0.824284;1738 -1.53749e-16 7.05 0.837; 1739 0.145344 7.05 0.824284;1740 0.286271 7.05 0.786523; 1741 0.4185 7.05 0.724863;1742 0.538013 7.05 0.641179; 1743 0.641179 7.05 0.538013;1744 0.724863 7.05 0.4185; 1745 0.786523 7.05 0.286271;1746 0.824284 7.05 0.145344; 1747 0.837 7.2 0; 1748 0.824284 7.2 -0.145344;1749 0.786523 7.2 -0.286271; 1750 0.724863 7.2 -0.4185;1751 0.641179 7.2 -0.538013; 1752 0.538013 7.2 -0.641179;1753 0.4185 7.2 -0.724863; 1754 0.286271 7.2 -0.786523;1755 0.145344 7.2 -0.824284; 1756 5.12498e-17 7.2 -0.837;1757 -0.145344 7.2 -0.824284; 1758 -0.286271 7.2 -0.786523;1759 -0.4185 7.2 -0.724863; 1760 -0.538013 7.2 -0.641179;1761 -0.641179 7.2 -0.538013; 1762 -0.724863 7.2 -0.4185;1763 -0.786523 7.2 -0.286271; 1764 -0.824284 7.2 -0.145344;1765 -0.837 7.2 -1.025e-16; 1766 -0.824284 7.2 0.145344;1767 -0.786523 7.2 0.286271; 1768 -0.724863 7.2 0.4185;1769 -0.641179 7.2 0.538013; 1770 -0.538013 7.2 0.641179;1771 -0.4185 7.2 0.724863; 1772 -0.286271 7.2 0.786523;1773 -0.145344 7.2 0.824284; 1774 -1.53749e-16 7.2 0.837;1775 0.145344 7.2 0.824284; 1776 0.286271 7.2 0.786523;1777 0.4185 7.2 0.724863; 1778 0.538013 7.2 0.641179;1779 0.641179 7.2 0.538013; 1780 0.724863 7.2 0.4185;1781 0.786523 7.2 0.286271; 1782 0.824284 7.2 0.145344; 1783 0.837 7.35 0;1784 0.824284 7.35 -0.145344; 1785 0.786523 7.35 -0.286271;1786 0.724863 7.35 -0.4185; 1787 0.641179 7.35 -0.538013;1788 0.538013 7.35 -0.641179; 1789 0.4185 7.35 -0.724863;1790 0.286271 7.35 -0.786523; 1791 0.145344 7.35 -0.824284;1792 5.12498e-17 7.35 -0.837; 1793 -0.145344 7.35 -0.824284;1794 -0.286271 7.35 -0.786523; 1795 -0.4185 7.35 -0.724863;1796 -0.538013 7.35 -0.641179; 1797 -0.641179 7.35 -0.538013;1798 -0.724863 7.35 -0.4185; 1799 -0.786523 7.35 -0.286271;1800 -0.824284 7.35 -0.145344; 1801 -0.837 7.35 -1.025e-16;1802 -0.824284 7.35 0.145344; 1803 -0.786523 7.35 0.286271;1804 -0.724863 7.35 0.4185; 1805 -0.641179 7.35 0.538013;1806 -0.538013 7.35 0.641179; 1807 -0.4185 7.35 0.724863;1808 -0.286271 7.35 0.786523; 1809 -0.145344 7.35 0.824284;1810 -1.53749e-16 7.35 0.837; 1811 0.145344 7.35 0.824284;1812 0.286271 7.35 0.786523; 1813 0.4185 7.35 0.724863;1814 0.538013 7.35 0.641179; 1815 0.641179 7.35 0.538013;1816 0.724863 7.35 0.4185; 1817 0.786523 7.35 0.286271;1818 0.824284 7.35 0.145344; 1819 0.837 7.5 0; 1820 0.824284 7.5 -0.145344;1821 0.786523 7.5 -0.286271; 1822 0.724863 7.5 -0.4185;1823 0.641179 7.5 -0.538013; 1824 0.538013 7.5 -0.641179;1825 0.4185 7.5 -0.724863; 1826 0.286271 7.5 -0.786523;1827 0.145344 7.5 -0.824284; 1828 5.12498e-17 7.5 -0.837;1829 -0.145344 7.5 -0.824284; 1830 -0.286271 7.5 -0.786523;1831 -0.4185 7.5 -0.724863; 1832 -0.538013 7.5 -0.641179;1833 -0.641179 7.5 -0.538013; 1834 -0.724863 7.5 -0.4185;1835 -0.786523 7.5 -0.286271; 1836 -0.824284 7.5 -0.145344;1837 -0.837 7.5 -1.025e-16; 1838 -0.824284 7.5 0.145344;1839 -0.786523 7.5 0.286271; 1840 -0.724863 7.5 0.4185;1841 -0.641179 7.5 0.538013; 1842 -0.538013 7.5 0.641179;1843 -0.4185 7.5 0.724863; 1844 -0.286271 7.5 0.786523;1845 -0.145344 7.5 0.824284; 1846 -1.53749e-16 7.5 0.837;1847 0.145344 7.5 0.824284; 1848 0.286271 7.5 0.786523;1849 0.4185 7.5 0.724863; 1850 0.538013 7.5 0.641179;1851 0.641179 7.5 0.538013; 1852 0.724863 7.5 0.4185;1853 0.786523 7.5 0.286271; 1854 0.824284 7.5 0.145344; 1855 0.837 7.65 0;1856 0.824284 7.65 -0.145344; 1857 0.786523 7.65 -0.286271;1858 0.724863 7.65 -0.4185; 1859 0.641179 7.65 -0.538013;1860 0.538013 7.65 -0.641179; 1861 0.4185 7.65 -0.724863;1862 0.286271 7.65 -0.786523; 1863 0.145344 7.65 -0.824284;1864 5.12498e-17 7.65 -0.837; 1865 -0.145344 7.65 -0.824284;1866 -0.286271 7.65 -0.786523; 1867 -0.4185 7.65 -0.724863;1868 -0.538013 7.65 -0.641179; 1869 -0.641179 7.65 -0.538013;1870 -0.724863 7.65 -0.4185; 1871 -0.786523 7.65 -0.286271;1872 -0.824284 7.65 -0.145344; 1873 -0.837 7.65 -1.025e-16;1874 -0.824284 7.65 0.145344; 1875 -0.786523 7.65 0.286271;1876 -0.724863 7.65 0.4185; 1877 -0.641179 7.65 0.538013;1878 -0.538013 7.65 0.641179; 1879 -0.4185 7.65 0.724863;1880 -0.286271 7.65 0.786523; 1881 -0.145344 7.65 0.824284;1882 -1.53749e-16 7.65 0.837; 1883 0.145344 7.65 0.824284;1884 0.286271 7.65 0.786523; 1885 0.4185 7.65 0.724863;1886 0.538013 7.65 0.641179; 1887 0.641179 7.65 0.538013;1888 0.724863 7.65 0.4185; 1889 0.786523 7.65 0.286271;1890 0.824284 7.65 0.145344; 1891 0.837 7.8 0; 1892 0.824284 7.8 -0.145344;1893 0.786523 7.8 -0.286271; 1894 0.724863 7.8 -0.4185;1895 0.641179 7.8 -0.538013; 1896 0.538013 7.8 -0.641179;1897 0.4185 7.8 -0.724863; 1898 0.286271 7.8 -0.786523;1899 0.145344 7.8 -0.824284; 1900 5.12498e-17 7.8 -0.837;1901 -0.145344 7.8 -0.824284; 1902 -0.286271 7.8 -0.786523;1903 -0.4185 7.8 -0.724863; 1904 -0.538013 7.8 -0.641179;1905 -0.641179 7.8 -0.538013; 1906 -0.724863 7.8 -0.4185;1907 -0.786523 7.8 -0.286271; 1908 -0.824284 7.8 -0.145344;1909 -0.837 7.8 -1.025e-16; 1910 -0.824284 7.8 0.145344;1911 -0.786523 7.8 0.286271; 1912 -0.724863 7.8 0.4185;1913 -0.641179 7.8 0.538013; 1914 -0.538013 7.8 0.641179;1915 -0.4185 7.8 0.724863; 1916 -0.286271 7.8 0.786523;1917 -0.145344 7.8 0.824284; 1918 -1.53749e-16 7.8 0.837;1919 0.145344 7.8 0.824284; 1920 0.286271 7.8 0.786523;1921 0.4185 7.8 0.724863; 1922 0.538013 7.8 0.641179;1923 0.641179 7.8 0.538013; 1924 0.724863 7.8 0.4185;1925 0.786523 7.8 0.286271; 1926 0.824284 7.8 0.145344; 1927 0.837 7.95 0;1928 0.824284 7.95 -0.145344; 1929 0.786523 7.95 -0.286271;1930 0.724863 7.95 -0.4185; 1931 0.641179 7.95 -0.538013;1932 0.538013 7.95 -0.641179; 1933 0.4185 7.95 -0.724863;1934 0.286271 7.95 -0.786523; 1935 0.145344 7.95 -0.824284;1936 5.12498e-17 7.95 -0.837; 1937 -0.145344 7.95 -0.824284;1938 -0.286271 7.95 -0.786523; 1939 -0.4185 7.95 -0.724863;1940 -0.538013 7.95 -0.641179; 1941 -0.641179 7.95 -0.538013;1942 -0.724863 7.95 -0.4185; 1943 -0.786523 7.95 -0.286271;1944 -0.824284 7.95 -0.145344; 1945 -0.837 7.95 -1.025e-16;1946 -0.824284 7.95 0.145344; 1947 -0.786523 7.95 0.286271;1948 -0.724863 7.95 0.4185; 1949 -0.641179 7.95 0.538013;1950 -0.538013 7.95 0.641179; 1951 -0.4185 7.95 0.724863;1952 -0.286271 7.95 0.786523; 1953 -0.145344 7.95 0.824284;1954 -1.53749e-16 7.95 0.837; 1955 0.145344 7.95 0.824284;1956 0.286271 7.95 0.786523; 1957 0.4185 7.95 0.724863;1958 0.538013 7.95 0.641179; 1959 0.641179 7.95 0.538013;1960 0.724863 7.95 0.4185; 1961 0.786523 7.95 0.286271;1962 0.824284 7.95 0.145344; 1963 0.837 8.1 0; 1964 0.824284 8.1 -0.145344;1965 0.786523 8.1 -0.286271; 1966 0.724863 8.1 -0.4185;1967 0.641179 8.1 -0.538013; 1968 0.538013 8.1 -0.641179;1969 0.4185 8.1 -0.724863; 1970 0.286271 8.1 -0.786523;1971 0.145344 8.1 -0.824284; 1972 5.12498e-17 8.1 -0.837;1973 -0.145344 8.1 -0.824284; 1974 -0.286271 8.1 -0.786523;1975 -0.4185 8.1 -0.724863; 1976 -0.538013 8.1 -0.641179;1977 -0.641179 8.1 -0.538013; 1978 -0.724863 8.1 -0.4185;1979 -0.786523 8.1 -0.286271; 1980 -0.824284 8.1 -0.145344;1981 -0.837 8.1 -1.025e-16; 1982 -0.824284 8.1 0.145344;1983 -0.786523 8.1 0.286271; 1984 -0.724863 8.1 0.4185;1985 -0.641179 8.1 0.538013; 1986 -0.538013 8.1 0.641179;1987 -0.4185 8.1 0.724863; 1988 -0.286271 8.1 0.786523;1989 -0.145344 8.1 0.824284; 1990 -1.53749e-16 8.1 0.837;1991 0.145344 8.1 0.824284; 1992 0.286271 8.1 0.786523;1993 0.4185 8.1 0.724863; 1994 0.538013 8.1 0.641179;1995 0.641179 8.1 0.538013; 1996 0.724863 8.1 0.4185;1997 0.786523 8.1 0.286271; 1998 0.824284 8.1 0.145344; 1999 0.837 8.25 0;2000 0.824284 8.25 -0.145344; 2001 0.786523 8.25 -0.286271;2002 0.724863 8.25 -0.4185; 2003 0.641179 8.25 -0.538013;2004 0.538013 8.25 -0.641179; 2005 0.4185 8.25 -0.724863;2006 0.286271 8.25 -0.786523; 2007 0.145344 8.25 -0.824284;2008 5.12498e-17 8.25 -0.837; 2009 -0.145344 8.25 -0.824284;2010 -0.286271 8.25 -0.786523; 2011 -0.4185 8.25 -0.724863;2012 -0.538013 8.25 -0.641179; 2013 -0.641179 8.25 -0.538013;2014 -0.724863 8.25 -0.4185; 2015 -0.786523 8.25 -0.286271;2016 -0.824284 8.25 -0.145344; 2017 -0.837 8.25 -1.025e-16;2018 -0.824284 8.25 0.145344; 2019 -0.786523 8.25 0.286271;2020 -0.724863 8.25 0.4185; 2021 -0.641179 8.25 0.538013;2022 -0.538013 8.25 0.641179; 2023 -0.4185 8.25 0.724863;2024 -0.286271 8.25 0.786523; 2025 -0.145344 8.25 0.824284;2026 -1.53749e-16 8.25 0.837; 2027 0.145344 8.25 0.824284;2028 0.286271 8.25 0.786523; 2029 0.4185 8.25 0.724863;2030 0.538013 8.25 0.641179; 2031 0.641179 8.25 0.538013;2032 0.724863 8.25 0.4185; 2033 0.786523 8.25 0.286271;2034 0.824284 8.25 0.145344; 2035 0.837 8.4 0; 2036 0.824284 8.4 -0.145344;2037 0.786523 8.4 -0.286271; 2038 0.724863 8.4 -0.4185;2039 0.641179 8.4 -0.538013; 2040 0.538013 8.4 -0.641179;2041 0.4185 8.4 -0.724863; 2042 0.286271 8.4 -0.786523;2043 0.145344 8.4 -0.824284; 2044 5.12498e-17 8.4 -0.837;2045 -0.145344 8.4 -0.824284; 2046 -0.286271 8.4 -0.786523;2047 -0.4185 8.4 -0.724863; 2048 -0.538013 8.4 -0.641179;2049 -0.641179 8.4 -0.538013; 2050 -0.724863 8.4 -0.4185;2051 -0.786523 8.4 -0.286271; 2052 -0.824284 8.4 -0.145344;2053 -0.837 8.4 -1.025e-16; 2054 -0.824284 8.4 0.145344;2055 -0.786523 8.4 0.286271; 2056 -0.724863 8.4 0.4185;2057 -0.641179 8.4 0.538013; 2058 -0.538013 8.4 0.641179;2059 -0.4185 8.4 0.724863; 2060 -0.286271 8.4 0.786523;2061 -0.145344 8.4 0.824284; 2062 -1.53749e-16 8.4 0.837;2063 0.145344 8.4 0.824284; 2064 0.286271 8.4 0.786523;2065 0.4185 8.4 0.724863; 2066 0.538013 8.4 0.641179;2067 0.641179 8.4 0.538013; 2068 0.724863 8.4 0.4185;2069 0.786523 8.4 0.286271; 2070 0.824284 8.4 0.145344; 2071 0.837 8.55 0;2072 0.824284 8.55 -0.145344; 2073 0.786523 8.55 -0.286271;2074 0.724863 8.55 -0.4185; 2075 0.641179 8.55 -0.538013;2076 0.538013 8.55 -0.641179; 2077 0.4185 8.55 -0.724863;2078 0.286271 8.55 -0.786523; 2079 0.145344 8.55 -0.824284;2080 5.12498e-17 8.55 -0.837; 2081 -0.145344 8.55 -0.824284;2082 -0.286271 8.55 -0.786523; 2083 -0.4185 8.55 -0.724863;2084 -0.538013 8.55 -0.641179; 2085 -0.641179 8.55 -0.538013;2086 -0.724863 8.55 -0.4185; 2087 -0.786523 8.55 -0.286271;2088 -0.824284 8.55 -0.145344; 2089 -0.837 8.55 -1.025e-16;2090 -0.824284 8.55 0.145344; 2091 -0.786523 8.55 0.286271;2092 -0.724863 8.55 0.4185; 2093 -0.641179 8.55 0.538013;2094 -0.538013 8.55 0.641179; 2095 -0.4185 8.55 0.724863;2096 -0.286271 8.55 0.786523; 2097 -0.145344 8.55 0.824284;2098 -1.53749e-16 8.55 0.837; 2099 0.145344 8.55 0.824284;2100 0.286271 8.55 0.786523; 2101 0.4185 8.55 0.724863;2102 0.538013 8.55 0.641179; 2103 0.641179 8.55 0.538013;2104 0.724863 8.55 0.4185; 2105 0.786523 8.55 0.286271;2106 0.824284 8.55 0.145344; 2107 0.837 8.7 0; 2108 0.824284 8.7 -0.145344;2109 0.786523 8.7 -0.286271; 2110 0.724863 8.7 -0.4185;2111 0.641179 8.7 -0.538013; 2112 0.538013 8.7 -0.641179;2113 0.4185 8.7 -0.724863; 2114 0.286271 8.7 -0.786523;2115 0.145344 8.7 -0.824284; 2116 5.12498e-17 8.7 -0.837;2117 -0.145344 8.7 -0.824284; 2118 -0.286271 8.7 -0.786523;2119 -0.4185 8.7 -0.724863; 2120 -0.538013 8.7 -0.641179;2121 -0.641179 8.7 -0.538013; 2122 -0.724863 8.7 -0.4185;2123 -0.786523 8.7 -0.286271; 2124 -0.824284 8.7 -0.145344;2125 -0.837 8.7 -1.025e-16; 2126 -0.824284 8.7 0.145344;2127 -0.786523 8.7 0.286271; 2128 -0.724863 8.7 0.4185;2129 -0.641179 8.7 0.538013; 2130 -0.538013 8.7 0.641179;2131 -0.4185 8.7 0.724863; 2132 -0.286271 8.7 0.786523;2133 -0.145344 8.7 0.824284; 2134 -1.53749e-16 8.7 0.837;2135 0.145344 8.7 0.824284; 2136 0.286271 8.7 0.786523;2137 0.4185 8.7 0.724863; 2138 0.538013 8.7 0.641179;2139 0.641179 8.7 0.538013; 2140 0.724863 8.7 0.4185;2141 0.786523 8.7 0.286271; 2142 0.824284 8.7 0.145344; 2143 0.837 8.85 0;2144 0.824284 8.85 -0.145344; 2145 0.786523 8.85 -0.286271;2146 0.724863 8.85 -0.4185; 2147 0.641179 8.85 -0.538013;2148 0.538013 8.85 -0.641179; 2149 0.4185 8.85 -0.724863;2150 0.286271 8.85 -0.786523; 2151 0.145344 8.85 -0.824284;2152 5.12498e-17 8.85 -0.837; 2153 -0.145344 8.85 -0.824284;2154 -0.286271 8.85 -0.786523; 2155 -0.4185 8.85 -0.724863;2156 -0.538013 8.85 -0.641179; 2157 -0.641179 8.85 -0.538013;2158 -0.724863 8.85 -0.4185; 2159 -0.786523 8.85 -0.286271;2160 -0.824284 8.85 -0.145344; 2161 -0.837 8.85 -1.025e-16;2162 -0.824284 8.85 0.145344; 2163 -0.786523 8.85 0.286271;2164 -0.724863 8.85 0.4185; 2165 -0.641179 8.85 0.538013;2166 -0.538013 8.85 0.641179; 2167 -0.4185 8.85 0.724863;2168 -0.286271 8.85 0.786523; 2169 -0.145344 8.85 0.824284;2170 -1.53749e-16 8.85 0.837; 2171 0.145344 8.85 0.824284;2172 0.286271 8.85 0.786523; 2173 0.4185 8.85 0.724863;2174 0.538013 8.85 0.641179; 2175 0.641179 8.85 0.538013;2176 0.724863 8.85 0.4185; 2177 0.786523 8.85 0.286271;2178 0.824284 8.85 0.145344; 2179 0.837 9 0; 2180 0.824284 9 -0.145344;2181 0.786523 9 -0.286271; 2182 0.724863 9 -0.4185; 2183 0.641179 9 -0.538013;2184 0.538013 9 -0.641179; 2185 0.4185 9 -0.724863; 2186 0.286271 9 -0.786523;2187 0.145344 9 -0.824284; 2188 5.12498e-17 9 -0.837;2189 -0.145344 9 -0.824284; 2190 -0.286271 9 -0.786523;2191 -0.4185 9 -0.724863; 2192 -0.538013 9 -0.641179;2193 -0.641179 9 -0.538013; 2194 -0.724863 9 -0.4185;2195 -0.786523 9 -0.286271; 2196 -0.824284 9 -0.145344;2197 -0.837 9 -1.025e-16; 2198 -0.824284 9 0.145344; 2199 -0.786523 9 0.286271;2200 -0.724863 9 0.4185; 2201 -0.641179 9 0.538013; 2202 -0.538013 9 0.641179;2203 -0.4185 9 0.724863; 2204 -0.286271 9 0.786523; 2205 -0.145344 9 0.824284;2206 -1.53749e-16 9 0.837; 2207 0.145344 9 0.824284; 2208 0.286271 9 0.786523;2209 0.4185 9 0.724863; 2210 0.538013 9 0.641179; 2211 0.641179 9 0.538013;2212 0.724863 9 0.4185; 2213 0.786523 9 0.286271; 2214 0.824284 9 0.145344;2215 0.837 9.15 0; 2216 0.824284 9.15 -0.145344; 2217 0.786523 9.15 -0.286271;2218 0.724863 9.15 -0.4185; 2219 0.641179 9.15 -0.538013;2220 0.538013 9.15 -0.641179; 2221 0.4185 9.15 -0.724863;2222 0.286271 9.15 -0.786523; 2223 0.145344 9.15 -0.824284;2224 5.12498e-17 9.15 -0.837; 2225 -0.145344 9.15 -0.824284;2226 -0.286271 9.15 -0.786523; 2227 -0.4185 9.15 -0.724863;2228 -0.538013 9.15 -0.641179; 2229 -0.641179 9.15 -0.538013;2230 -0.724863 9.15 -0.4185; 2231 -0.786523 9.15 -0.286271;2232 -0.824284 9.15 -0.145344; 2233 -0.837 9.15 -1.025e-16;2234 -0.824284 9.15 0.145344; 2235 -0.786523 9.15 0.286271;2236 -0.724863 9.15 0.4185; 2237 -0.641179 9.15 0.538013;2238 -0.538013 9.15 0.641179; 2239 -0.4185 9.15 0.724863;2240 -0.286271 9.15 0.786523; 2241 -0.145344 9.15 0.824284;2242 -1.53749e-16 9.15 0.837; 2243 0.145344 9.15 0.824284;2244 0.286271 9.15 0.786523; 2245 0.4185 9.15 0.724863;2246 0.538013 9.15 0.641179; 2247 0.641179 9.15 0.538013;2248 0.724863 9.15 0.4185; 2249 0.786523 9.15 0.286271;2250 0.824284 9.15 0.145344; 2251 0.837 9.3 0; 2252 0.824284 9.3 -0.145344;2253 0.786523 9.3 -0.286271; 2254 0.724863 9.3 -0.4185;2255 0.641179 9.3 -0.538013; 2256 0.538013 9.3 -0.641179;2257 0.4185 9.3 -0.724863; 2258 0.286271 9.3 -0.786523;2259 0.145344 9.3 -0.824284; 2260 5.12498e-17 9.3 -0.837;2261 -0.145344 9.3 -0.824284; 2262 -0.286271 9.3 -0.786523;2263 -0.4185 9.3 -0.724863; 2264 -0.538013 9.3 -0.641179;2265 -0.641179 9.3 -0.538013; 2266 -0.724863 9.3 -0.4185;2267 -0.786523 9.3 -0.286271; 2268 -0.824284 9.3 -0.145344;2269 -0.837 9.3 -1.025e-16; 2270 -0.824284 9.3 0.145344;2271 -0.786523 9.3 0.286271; 2272 -0.724863 9.3 0.4185;2273 -0.641179 9.3 0.538013; 2274 -0.538013 9.3 0.641179;2275 -0.4185 9.3 0.724863; 2276 -0.286271 9.3 0.786523;2277 -0.145344 9.3 0.824284; 2278 -1.53749e-16 9.3 0.837;2279 0.145344 9.3 0.824284; 2280 0.286271 9.3 0.786523;2281 0.4185 9.3 0.724863; 2282 0.538013 9.3 0.641179;2283 0.641179 9.3 0.538013; 2284 0.724863 9.3 0.4185;2285 0.786523 9.3 0.286271; 2286 0.824284 9.3 0.145344; 2287 0.837 9.45 0;2288 0.824284 9.45 -0.145344; 2289 0.786523 9.45 -0.286271;2290 0.724863 9.45 -0.4185; 2291 0.641179 9.45 -0.538013;2292 0.538013 9.45 -0.641179; 2293 0.4185 9.45 -0.724863;2294 0.286271 9.45 -0.786523; 2295 0.145344 9.45 -0.824284;2296 5.12498e-17 9.45 -0.837; 2297 -0.145344 9.45 -0.824284;2298 -0.286271 9.45 -0.786523; 2299 -0.4185 9.45 -0.724863;2300 -0.538013 9.45 -0.641179; 2301 -0.641179 9.45 -0.538013;2302 -0.724863 9.45 -0.4185; 2303 -0.786523 9.45 -0.286271;2304 -0.824284 9.45 -0.145344; 2305 -0.837 9.45 -1.025e-16;2306 -0.824284 9.45 0.145344; 2307 -0.786523 9.45 0.286271;2308 -0.724863 9.45 0.4185; 2309 -0.641179 9.45 0.538013;2310 -0.538013 9.45 0.641179; 2311 -0.4185 9.45 0.724863;2312 -0.286271 9.45 0.786523; 2313 -0.145344 9.45 0.824284;2314 -1.53749e-16 9.45 0.837; 2315 0.145344 9.45 0.824284;2316 0.286271 9.45 0.786523; 2317 0.4185 9.45 0.724863;2318 0.538013 9.45 0.641179; 2319 0.641179 9.45 0.538013;2320 0.724863 9.45 0.4185; 2321 0.786523 9.45 0.286271;2322 0.824284 9.45 0.145344; 2323 0.837 9.6 0; 2324 0.824284 9.6 -0.145344;2325 0.786523 9.6 -0.286271; 2326 0.724863 9.6 -0.4185;2327 0.641179 9.6 -0.538013; 2328 0.538013 9.6 -0.641179;2329 0.4185 9.6 -0.724863; 2330 0.286271 9.6 -0.786523;2331 0.145344 9.6 -0.824284; 2332 5.12498e-17 9.6 -0.837;2333 -0.145344 9.6 -0.824284; 2334 -0.286271 9.6 -0.786523;2335 -0.4185 9.6 -0.724863; 2336 -0.538013 9.6 -0.641179;2337 -0.641179 9.6 -0.538013; 2338 -0.724863 9.6 -0.4185;2339 -0.786523 9.6 -0.286271; 2340 -0.824284 9.6 -0.145344;2341 -0.837 9.6 -1.025e-16; 2342 -0.824284 9.6 0.145344;2343 -0.786523 9.6 0.286271; 2344 -0.724863 9.6 0.4185;2345 -0.641179 9.6 0.538013; 2346 -0.538013 9.6 0.641179;2347 -0.4185 9.6 0.724863; 2348 -0.286271 9.6 0.786523;2349 -0.145344 9.6 0.824284; 2350 -1.53749e-16 9.6 0.837;2351 0.145344 9.6 0.824284; 2352 0.286271 9.6 0.786523;2353 0.4185 9.6 0.724863; 2354 0.538013 9.6 0.641179;2355 0.641179 9.6 0.538013; 2356 0.724863 9.6 0.4185;2357 0.786523 9.6 0.286271; 2358 0.824284 9.6 0.145344; 2359 0.837 9.75 0;2360 0.824284 9.75 -0.145344; 2361 0.786523 9.75 -0.286271;2362 0.724863 9.75 -0.4185; 2363 0.641179 9.75 -0.538013;2364 0.538013 9.75 -0.641179; 2365 0.4185 9.75 -0.724863;2366 0.286271 9.75 -0.786523; 2367 0.145344 9.75 -0.824284;2368 5.12498e-17 9.75 -0.837; 2369 -0.145344 9.75 -0.824284;2370 -0.286271 9.75 -0.786523; 2371 -0.4185 9.75 -0.724863;2372 -0.538013 9.75 -0.641179; 2373 -0.641179 9.75 -0.538013;2374 -0.724863 9.75 -0.4185; 2375 -0.786523 9.75 -0.286271;2376 -0.824284 9.75 -0.145344; 2377 -0.837 9.75 -1.025e-16;2378 -0.824284 9.75 0.145344; 2379 -0.786523 9.75 0.286271;2380 -0.724863 9.75 0.4185; 2381 -0.641179 9.75 0.538013;2382 -0.538013 9.75 0.641179; 2383 -0.4185 9.75 0.724863;2384 -0.286271 9.75 0.786523; 2385 -0.145344 9.75 0.824284;2386 -1.53749e-16 9.75 0.837; 2387 0.145344 9.75 0.824284;2388 0.286271 9.75 0.786523; 2389 0.4185 9.75 0.724863;2390 0.538013 9.75 0.641179; 2391 0.641179 9.75 0.538013;2392 0.724863 9.75 0.4185; 2393 0.786523 9.75 0.286271;2394 0.824284 9.75 0.145344; 2395 0.837 9.9 0; 2396 0.824284 9.9 -0.145344;2397 0.786523 9.9 -0.286271; 2398 0.724863 9.9 -0.4185;2399 0.641179 9.9 -0.538013; 2400 0.538013 9.9 -0.641179;2401 0.4185 9.9 -0.724863; 2402 0.286271 9.9 -0.786523;2403 0.145344 9.9 -0.824284; 2404 5.12498e-17 9.9 -0.837;2405 -0.145344 9.9 -0.824284; 2406 -0.286271 9.9 -0.786523;2407 -0.4185 9.9 -0.724863; 2408 -0.538013 9.9 -0.641179;2409 -0.641179 9.9 -0.538013; 2410 -0.724863 9.9 -0.4185;2411 -0.786523 9.9 -0.286271; 2412 -0.824284 9.9 -0.145344;2413 -0.837 9.9 -1.025e-16; 2414 -0.824284 9.9 0.145344;2415 -0.786523 9.9 0.286271; 2416 -0.724863 9.9 0.4185;2417 -0.641179 9.9 0.538013; 2418 -0.538013 9.9 0.641179;2419 -0.4185 9.9 0.724863; 2420 -0.286271 9.9 0.786523;2421 -0.145344 9.9 0.824284; 2422 -1.53749e-16 9.9 0.837;2423 0.145344 9.9 0.824284; 2424 0.286271 9.9 0.786523;2425 0.4185 9.9 0.724863; 2426 0.538013 9.9 0.641179;2427 0.641179 9.9 0.538013; 2428 0.724863 9.9 0.4185;2429 0.786523 9.9 0.286271; 2430 0.824284 9.9 0.145344; 2431 0.837 10.05 0;2432 0.824284 10.05 -0.145344; 2433 0.786523 10.05 -0.286271;2434 0.724863 10.05 -0.4185; 2435 0.641179 10.05 -0.538013;2436 0.538013 10.05 -0.641179; 2437 0.4185 10.05 -0.724863;2438 0.286271 10.05 -0.786523; 2439 0.145344 10.05 -0.824284;2440 5.12498e-17 10.05 -0.837; 2441 -0.145344 10.05 -0.824284;2442 -0.286271 10.05 -0.786523; 2443 -0.4185 10.05 -0.724863;2444 -0.538013 10.05 -0.641179; 2445 -0.641179 10.05 -0.538013;2446 -0.724863 10.05 -0.4185; 2447 -0.786523 10.05 -0.286271;2448 -0.824284 10.05 -0.145344; 2449 -0.837 10.05 -1.025e-16;2450 -0.824284 10.05 0.145344; 2451 -0.786523 10.05 0.286271;2452 -0.724863 10.05 0.4185; 2453 -0.641179 10.05 0.538013;2454 -0.538013 10.05 0.641179; 2455 -0.4185 10.05 0.724863;2456 -0.286271 10.05 0.786523; 2457 -0.145344 10.05 0.824284;2458 -1.53749e-16 10.05 0.837; 2459 0.145344 10.05 0.824284;2460 0.286271 10.05 0.786523; 2461 0.4185 10.05 0.724863;2462 0.538013 10.05 0.641179; 2463 0.641179 10.05 0.538013;2464 0.724863 10.05 0.4185; 2465 0.786523 10.05 0.286271;2466 0.824284 10.05 0.145344; 2467 0.837 10.2 0; 2468 0.824284 10.2 -0.145344;2469 0.786523 10.2 -0.286271; 2470 0.724863 10.2 -0.4185;2471 0.641179 10.2 -0.538013; 2472 0.538013 10.2 -0.641179;2473 0.4185 10.2 -0.724863; 2474 0.286271 10.2 -0.786523;2475 0.145344 10.2 -0.824284; 2476 5.12498e-17 10.2 -0.837;2477 -0.145344 10.2 -0.824284; 2478 -0.286271 10.2 -0.786523;2479 -0.4185 10.2 -0.724863; 2480 -0.538013 10.2 -0.641179;2481 -0.641179 10.2 -0.538013; 2482 -0.724863 10.2 -0.4185;2483 -0.786523 10.2 -0.286271; 2484 -0.824284 10.2 -0.145344;2485 -0.837 10.2 -1.025e-16; 2486 -0.824284 10.2 0.145344;2487 -0.786523 10.2 0.286271; 2488 -0.724863 10.2 0.4185;2489 -0.641179 10.2 0.538013; 2490 -0.538013 10.2 0.641179;2491 -0.4185 10.2 0.724863; 2492 -0.286271 10.2 0.786523;2493 -0.145344 10.2 0.824284; 2494 -1.53749e-16 10.2 0.837;2495 0.145344 10.2 0.824284; 2496 0.286271 10.2 0.786523;2497 0.4185 10.2 0.724863; 2498 0.538013 10.2 0.641179;2499 0.641179 10.2 0.538013; 2500 0.724863 10.2 0.4185;2501 0.786523 10.2 0.286271; 2502 0.824284 10.2 0.145344; 2503 0.837 10.35 0;2504 0.824284 10.35 -0.145344; 2505 0.786523 10.35 -0.286271;2506 0.724863 10.35 -0.4185; 2507 0.641179 10.35 -0.538013;2508 0.538013 10.35 -0.641179; 2509 0.4185 10.35 -0.724863;2510 0.286271 10.35 -0.786523; 2511 0.145344 10.35 -0.824284;2512 5.12498e-17 10.35 -0.837; 2513 -0.145344 10.35 -0.824284;2514 -0.286271 10.35 -0.786523; 2515 -0.4185 10.35 -0.724863;2516 -0.538013 10.35 -0.641179; 2517 -0.641179 10.35 -0.538013;2518 -0.724863 10.35 -0.4185; 2519 -0.786523 10.35 -0.286271;2520 -0.824284 10.35 -0.145344; 2521 -0.837 10.35 -1.025e-16;2522 -0.824284 10.35 0.145344; 2523 -0.786523 10.35 0.286271;2524 -0.724863 10.35 0.4185; 2525 -0.641179 10.35 0.538013;2526 -0.538013 10.35 0.641179; 2527 -0.4185 10.35 0.724863;2528 -0.286271 10.35 0.786523; 2529 -0.145344 10.35 0.824284;2530 -1.53749e-16 10.35 0.837; 2531 0.145344 10.35 0.824284;2532 0.286271 10.35 0.786523; 2533 0.4185 10.35 0.724863;2534 0.538013 10.35 0.641179; 2535 0.641179 10.35 0.538013;2536 0.724863 10.35 0.4185; 2537 0.786523 10.35 0.286271;2538 0.824284 10.35 0.145344; 2539 0.837 10.5 0; 2540 0.824284 10.5 -0.145344;2541 0.786523 10.5 -0.286271; 2542 0.724863 10.5 -0.4185;2543 0.641179 10.5 -0.538013; 2544 0.538013 10.5 -0.641179;2545 0.4185 10.5 -0.724863; 2546 0.286271 10.5 -0.786523;2547 0.145344 10.5 -0.824284; 2548 5.12498e-17 10.5 -0.837;2549 -0.145344 10.5 -0.824284; 2550 -0.286271 10.5 -0.786523;2551 -0.4185 10.5 -0.724863; 2552 -0.538013 10.5 -0.641179;2553 -0.641179 10.5 -0.538013; 2554 -0.724863 10.5 -0.4185;2555 -0.786523 10.5 -0.286271; 2556 -0.824284 10.5 -0.145344;2557 -0.837 10.5 -1.025e-16; 2558 -0.824284 10.5 0.145344;2559 -0.786523 10.5 0.286271; 2560 -0.724863 10.5 0.4185;2561 -0.641179 10.5 0.538013; 2562 -0.538013 10.5 0.641179;2563 -0.4185 10.5 0.724863; 2564 -0.286271 10.5 0.786523;2565 -0.145344 10.5 0.824284; 2566 -1.53749e-16 10.5 0.837;2567 0.145344 10.5 0.824284; 2568 0.286271 10.5 0.786523;2569 0.4185 10.5 0.724863; 2570 0.538013 10.5 0.641179;2571 0.641179 10.5 0.538013; 2572 0.724863 10.5 0.4185;2573 0.786523 10.5 0.286271; 2574 0.824284 10.5 0.145344; 2575 0.837 10.65 0;2576 0.824284 10.65 -0.145344; 2577 0.786523 10.65 -0.286271;2578 0.724863 10.65 -0.4185; 2579 0.641179 10.65 -0.538013;2580 0.538013 10.65 -0.641179; 2581 0.4185 10.65 -0.724863;2582 0.286271 10.65 -0.786523; 2583 0.145344 10.65 -0.824284;2584 5.12498e-17 10.65 -0.837; 2585 -0.145344 10.65 -0.824284;2586 -0.286271 10.65 -0.786523; 2587 -0.4185 10.65 -0.724863;2588 -0.538013 10.65 -0.641179; 2589 -0.641179 10.65 -0.538013;2590 -0.724863 10.65 -0.4185; 2591 -0.786523 10.65 -0.286271;2592 -0.824284 10.65 -0.145344; 2593 -0.837 10.65 -1.025e-16;2594 -0.824284 10.65 0.145344; 2595 -0.786523 10.65 0.286271;2596 -0.724863 10.65 0.4185; 2597 -0.641179 10.65 0.538013;2598 -0.538013 10.65 0.641179; 2599 -0.4185 10.65 0.724863;2600 -0.286271 10.65 0.786523; 2601 -0.145344 10.65 0.824284;2602 -1.53749e-16 10.65 0.837; 2603 0.145344 10.65 0.824284;2604 0.286271 10.65 0.786523; 2605 0.4185 10.65 0.724863;2606 0.538013 10.65 0.641179; 2607 0.641179 10.65 0.538013;2608 0.724863 10.65 0.4185; 2609 0.786523 10.65 0.286271;2610 0.824284 10.65 0.145344; 2611 0.837 10.8 0; 2612 0.824284 10.8 -0.145344;2613 0.786523 10.8 -0.286271; 2614 0.724863 10.8 -0.4185;2615 0.641179 10.8 -0.538013; 2616 0.538013 10.8 -0.641179;2617 0.4185 10.8 -0.724863; 2618 0.286271 10.8 -0.786523;2619 0.145344 10.8 -0.824284; 2620 5.12498e-17 10.8 -0.837;2621 -0.145344 10.8 -0.824284; 2622 -0.286271 10.8 -0.786523;2623 -0.4185 10.8 -0.724863; 2624 -0.538013 10.8 -0.641179;2625 -0.641179 10.8 -0.538013; 2626 -0.724863 10.8 -0.4185;2627 -0.786523 10.8 -0.286271; 2628 -0.824284 10.8 -0.145344;2629 -0.837 10.8 -1.025e-16; 2630 -0.824284 10.8 0.145344;2631 -0.786523 10.8 0.286271; 2632 -0.724863 10.8 0.4185;2633 -0.641179 10.8 0.538013; 2634 -0.538013 10.8 0.641179;2635 -0.4185 10.8 0.724863; 2636 -0.286271 10.8 0.786523;2637 -0.145344 10.8 0.824284; 2638 -1.53749e-16 10.8 0.837;2639 0.145344 10.8 0.824284; 2640 0.286271 10.8 0.786523;2641 0.4185 10.8 0.724863; 2642 0.538013 10.8 0.641179;2643 0.641179 10.8 0.538013; 2644 0.724863 10.8 0.4185;2645 0.786523 10.8 0.286271; 2646 0.824284 10.8 0.145344; 2647 0.837 10.95 0;2648 0.824284 10.95 -0.145344; 2649 0.786523 10.95 -0.286271;2650 0.724863 10.95 -0.4185; 2651 0.641179 10.95 -0.538013;2652 0.538013 10.95 -0.641179; 2653 0.4185 10.95 -0.724863;2654 0.286271 10.95 -0.786523; 2655 0.145344 10.95 -0.824284;2656 5.12498e-17 10.95 -0.837; 2657 -0.145344 10.95 -0.824284;2658 -0.286271 10.95 -0.786523; 2659 -0.4185 10.95 -0.724863;2660 -0.538013 10.95 -0.641179; 2661 -0.641179 10.95 -0.538013;2662 -0.724863 10.95 -0.4185; 2663 -0.786523 10.95 -0.286271;2664 -0.824284 10.95 -0.145344; 2665 -0.837 10.95 -1.025e-16;2666 -0.824284 10.95 0.145344; 2667 -0.786523 10.95 0.286271;2668 -0.724863 10.95 0.4185; 2669 -0.641179 10.95 0.538013;2670 -0.538013 10.95 0.641179; 2671 -0.4185 10.95 0.724863;2672 -0.286271 10.95 0.786523; 2673 -0.145344 10.95 0.824284;2674 -1.53749e-16 10.95 0.837; 2675 0.145344 10.95 0.824284;2676 0.286271 10.95 0.786523; 2677 0.4185 10.95 0.724863;2678 0.538013 10.95 0.641179; 2679 0.641179 10.95 0.538013;2680 0.724863 10.95 0.4185; 2681 0.786523 10.95 0.286271;2682 0.824284 10.95 0.145344; 2683 0.837 11.1 0; 2684 0.824284 11.1 -0.145344;2685 0.786523 11.1 -0.286271; 2686 0.724863 11.1 -0.4185;2687 0.641179 11.1 -0.538013; 2688 0.538013 11.1 -0.641179;2689 0.4185 11.1 -0.724863; 2690 0.286271 11.1 -0.786523;2691 0.145344 11.1 -0.824284; 2692 5.12498e-17 11.1 -0.837;2693 -0.145344 11.1 -0.824284; 2694 -0.286271 11.1 -0.786523;2695 -0.4185 11.1 -0.724863; 2696 -0.538013 11.1 -0.641179;2697 -0.641179 11.1 -0.538013; 2698 -0.724863 11.1 -0.4185;2699 -0.786523 11.1 -0.286271; 2700 -0.824284 11.1 -0.145344;2701 -0.837 11.1 -1.025e-16; 2702 -0.824284 11.1 0.145344;2703 -0.786523 11.1 0.286271; 2704 -0.724863 11.1 0.4185;2705 -0.641179 11.1 0.538013; 2706 -0.538013 11.1 0.641179;2707 -0.4185 11.1 0.724863; 2708 -0.286271 11.1 0.786523;2709 -0.145344 11.1 0.824284; 2710 -1.53749e-16 11.1 0.837;2711 0.145344 11.1 0.824284; 2712 0.286271 11.1 0.786523;2713 0.4185 11.1 0.724863; 2714 0.538013 11.1 0.641179;2715 0.641179 11.1 0.538013; 2716 0.724863 11.1 0.4185;2717 0.786523 11.1 0.286271; 2718 0.824284 11.1 0.145344; 2719 0.837 11.25 0;2720 0.824284 11.25 -0.145344; 2721 0.786523 11.25 -0.286271;2722 0.724863 11.25 -0.4185; 2723 0.641179 11.25 -0.538013;2724 0.538013 11.25 -0.641179; 2725 0.4185 11.25 -0.724863;2726 0.286271 11.25 -0.786523; 2727 0.145344 11.25 -0.824284;2728 5.12498e-17 11.25 -0.837; 2729 -0.145344 11.25 -0.824284;2730 -0.286271 11.25 -0.786523; 2731 -0.4185 11.25 -0.724863;2732 -0.538013 11.25 -0.641179; 2733 -0.641179 11.25 -0.538013;2734 -0.724863 11.25 -0.4185; 2735 -0.786523 11.25 -0.286271;2736 -0.824284 11.25 -0.145344; 2737 -0.837 11.25 -1.025e-16;2738 -0.824284 11.25 0.145344; 2739 -0.786523 11.25 0.286271;2740 -0.724863 11.25 0.4185; 2741 -0.641179 11.25 0.538013;2742 -0.538013 11.25 0.641179; 2743 -0.4185 11.25 0.724863;2744 -0.286271 11.25 0.786523; 2745 -0.145344 11.25 0.824284;2746 -1.53749e-16 11.25 0.837; 2747 0.145344 11.25 0.824284;2748 0.286271 11.25 0.786523; 2749 0.4185 11.25 0.724863;2750 0.538013 11.25 0.641179; 2751 0.641179 11.25 0.538013;2752 0.724863 11.25 0.4185; 2753 0.786523 11.25 0.286271;2754 0.824284 11.25 0.145344; 2755 0.837 11.4 0; 2756 0.824284 11.4 -0.145344;2757 0.786523 11.4 -0.286271; 2758 0.724863 11.4 -0.4185;2759 0.641179 11.4 -0.538013; 2760 0.538013 11.4 -0.641179;2761 0.4185 11.4 -0.724863; 2762 0.286271 11.4 -0.786523;2763 0.145344 11.4 -0.824284; 2764 5.12498e-17 11.4 -0.837;2765 -0.145344 11.4 -0.824284; 2766 -0.286271 11.4 -0.786523;2767 -0.4185 11.4 -0.724863; 2768 -0.538013 11.4 -0.641179;2769 -0.641179 11.4 -0.538013; 2770 -0.724863 11.4 -0.4185;2771 -0.786523 11.4 -0.286271; 2772 -0.824284 11.4 -0.145344;2773 -0.837 11.4 -1.025e-16; 2774 -0.824284 11.4 0.145344;2775 -0.786523 11.4 0.286271; 2776 -0.724863 11.4 0.4185;2777 -0.641179 11.4 0.538013; 2778 -0.538013 11.4 0.641179;2779 -0.4185 11.4 0.724863; 2780 -0.286271 11.4 0.786523;2781 -0.145344 11.4 0.824284; 2782 -1.53749e-16 11.4 0.837;2783 0.145344 11.4 0.824284; 2784 0.286271 11.4 0.786523;2785 0.4185 11.4 0.724863; 2786 0.538013 11.4 0.641179;2787 0.641179 11.4 0.538013; 2788 0.724863 11.4 0.4185;2789 0.786523 11.4 0.286271; 2790 0.824284 11.4 0.145344; 2791 0.837 11.55 0;2792 0.824284 11.55 -0.145344; 2793 0.786523 11.55 -0.286271;2794 0.724863 11.55 -0.4185; 2795 0.641179 11.55 -0.538013;2796 0.538013 11.55 -0.641179; 2797 0.4185 11.55 -0.724863;2798 0.286271 11.55 -0.786523; 2799 0.145344 11.55 -0.824284;2800 5.12498e-17 11.55 -0.837; 2801 -0.145344 11.55 -0.824284;2802 -0.286271 11.55 -0.786523; 2803 -0.4185 11.55 -0.724863;2804 -0.538013 11.55 -0.641179; 2805 -0.641179 11.55 -0.538013;2806 -0.724863 11.55 -0.4185; 2807 -0.786523 11.55 -0.286271;2808 -0.824284 11.55 -0.145344; 2809 -0.837 11.55 -1.025e-16;2810 -0.824284 11.55 0.145344; 2811 -0.786523 11.55 0.286271;2812 -0.724863 11.55 0.4185; 2813 -0.641179 11.55 0.538013;2814 -0.538013 11.55 0.641179; 2815 -0.4185 11.55 0.724863;2816 -0.286271 11.55 0.786523; 2817 -0.145344 11.55 0.824284;2818 -1.53749e-16 11.55 0.837; 2819 0.145344 11.55 0.824284;2820 0.286271 11.55 0.786523; 2821 0.4185 11.55 0.724863;2822 0.538013 11.55 0.641179; 2823 0.641179 11.55 0.538013;2824 0.724863 11.55 0.4185; 2825 0.786523 11.55 0.286271;2826 0.824284 11.55 0.145344; 2827 0.837 11.7 0; 2828 0.824284 11.7 -0.145344;2829 0.786523 11.7 -0.286271; 2830 0.724863 11.7 -0.4185;2831 0.641179 11.7 -0.538013; 2832 0.538013 11.7 -0.641179;2833 0.4185 11.7 -0.724863; 2834 0.286271 11.7 -0.786523;2835 0.145344 11.7 -0.824284; 2836 5.12498e-17 11.7 -0.837;2837 -0.145344 11.7 -0.824284; 2838 -0.286271 11.7 -0.786523;2839 -0.4185 11.7 -0.724863; 2840 -0.538013 11.7 -0.641179;2841 -0.641179 11.7 -0.538013; 2842 -0.724863 11.7 -0.4185;2843 -0.786523 11.7 -0.286271; 2844 -0.824284 11.7 -0.145344;2845 -0.837 11.7 -1.025e-16; 2846 -0.824284 11.7 0.145344;2847 -0.786523 11.7 0.286271; 2848 -0.724863 11.7 0.4185;2849 -0.641179 11.7 0.538013; 2850 -0.538013 11.7 0.641179;2851 -0.4185 11.7 0.724863; 2852 -0.286271 11.7 0.786523;2853 -0.145344 11.7 0.824284; 2854 -1.53749e-16 11.7 0.837;2855 0.145344 11.7 0.824284; 2856 0.286271 11.7 0.786523;2857 0.4185 11.7 0.724863; 2858 0.538013 11.7 0.641179;2859 0.641179 11.7 0.538013; 2860 0.724863 11.7 0.4185;2861 0.786523 11.7 0.286271; 2862 0.824284 11.7 0.145344; 2863 0.837 11.85 0;2864 0.824284 11.85 -0.145344; 2865 0.786523 11.85 -0.286271;2866 0.724863 11.85 -0.4185; 2867 0.641179 11.85 -0.538013;2868 0.538013 11.85 -0.641179; 2869 0.4185 11.85 -0.724863;2870 0.286271 11.85 -0.786523; 2871 0.145344 11.85 -0.824284;2872 5.12498e-17 11.85 -0.837; 2873 -0.145344 11.85 -0.824284;2874 -0.286271 11.85 -0.786523; 2875 -0.4185 11.85 -0.724863;2876 -0.538013 11.85 -0.641179; 2877 -0.641179 11.85 -0.538013;2878 -0.724863 11.85 -0.4185; 2879 -0.786523 11.85 -0.286271;2880 -0.824284 11.85 -0.145344; 2881 -0.837 11.85 -1.025e-16;2882 -0.824284 11.85 0.145344; 2883 -0.786523 11.85 0.286271;2884 -0.724863 11.85 0.4185; 2885 -0.641179 11.85 0.538013;2886 -0.538013 11.85 0.641179; 2887 -0.4185 11.85 0.724863;2888 -0.286271 11.85 0.786523; 2889 -0.145344 11.85 0.824284;2890 -1.53749e-16 11.85 0.837; 2891 0.145344 11.85 0.824284;2892 0.286271 11.85 0.786523; 2893 0.4185 11.85 0.724863;2894 0.538013 11.85 0.641179; 2895 0.641179 11.85 0.538013;2896 0.724863 11.85 0.4185; 2897 0.786523 11.85 0.286271;2898 0.824284 11.85 0.145344; 2899 0.837 12 0; 2900 0.824284 12 -0.145344;2901 0.786523 12 -0.286271; 2902 0.724863 12 -0.4185;2903 0.641179 12 -0.538013; 2904 0.538013 12 -0.641179;2905 0.4185 12 -0.724863; 2906 0.286271 12 -0.786523;2907 0.145344 12 -0.824284; 2908 5.12498e-17 12 -0.837;2909 -0.145344 12 -0.824284; 2910 -0.286271 12 -0.786523;2911 -0.4185 12 -0.724863; 2912 -0.538013 12 -0.641179;2913 -0.641179 12 -0.538013; 2914 -0.724863 12 -0.4185;2915 -0.786523 12 -0.286271; 2916 -0.824284 12 -0.145344;2917 -0.837 12 -1.025e-16; 2918 -0.824284 12 0.145344;2919 -0.786523 12 0.286271; 2920 -0.724863 12 0.4185;2921 -0.641179 12 0.538013; 2922 -0.538013 12 0.641179;2923 -0.4185 12 0.724863; 2924 -0.286271 12 0.786523;2925 -0.145344 12 0.824284; 2926 -1.53749e-16 12 0.837;2927 0.145344 12 0.824284; 2928 0.286271 12 0.786523; 2929 0.4185 12 0.724863;2930 0.538013 12 0.641179; 2931 0.641179 12 0.538013; 2932 0.724863 12 0.4185;2933 0.786523 12 0.286271; 2934 0.824284 12 0.145344; 2935 0.837 12.15 0;2936 0.824284 12.15 -0.145344; 2937 0.786523 12.15 -0.286271;2938 0.724863 12.15 -0.4185; 2939 0.641179 12.15 -0.538013;2940 0.538013 12.15 -0.641179; 2941 0.4185 12.15 -0.724863;2942 0.286271 12.15 -0.786523; 2943 0.145344 12.15 -0.824284;2944 5.12498e-17 12.15 -0.837; 2945 -0.145344 12.15 -0.824284;2946 -0.286271 12.15 -0.786523; 2947 -0.4185 12.15 -0.724863;2948 -0.538013 12.15 -0.641179; 2949 -0.641179 12.15 -0.538013;2950 -0.724863 12.15 -0.4185; 2951 -0.786523 12.15 -0.286271;2952 -0.824284 12.15 -0.145344; 2953 -0.837 12.15 -1.025e-16;2954 -0.824284 12.15 0.145344; 2955 -0.786523 12.15 0.286271;2956 -0.724863 12.15 0.4185; 2957 -0.641179 12.15 0.538013;2958 -0.538013 12.15 0.641179; 2959 -0.4185 12.15 0.724863;2960 -0.286271 12.15 0.786523; 2961 -0.145344 12.15 0.824284;2962 -1.53749e-16 12.15 0.837; 2963 0.145344 12.15 0.824284;2964 0.286271 12.15 0.786523; 2965 0.4185 12.15 0.724863;2966 0.538013 12.15 0.641179; 2967 0.641179 12.15 0.538013;2968 0.724863 12.15 0.4185; 2969 0.786523 12.15 0.286271;2970 0.824284 12.15 0.145344; 2971 0.837 12.3 0; 2972 0.824284 12.3 -0.145344;2973 0.786523 12.3 -0.286271; 2974 0.724863 12.3 -0.4185;2975 0.641179 12.3 -0.538013; 2976 0.538013 12.3 -0.641179;2977 0.4185 12.3 -0.724863; 2978 0.286271 12.3 -0.786523;2979 0.145344 12.3 -0.824284; 2980 5.12498e-17 12.3 -0.837;2981 -0.145344 12.3 -0.824284; 2982 -0.286271 12.3 -0.786523;2983 -0.4185 12.3 -0.724863; 2984 -0.538013 12.3 -0.641179;2985 -0.641179 12.3 -0.538013; 2986 -0.724863 12.3 -0.4185;2987 -0.786523 12.3 -0.286271; 2988 -0.824284 12.3 -0.145344;2989 -0.837 12.3 -1.025e-16; 2990 -0.824284 12.3 0.145344;2991 -0.786523 12.3 0.286271; 2992 -0.724863 12.3 0.4185;2993 -0.641179 12.3 0.538013; 2994 -0.538013 12.3 0.641179;2995 -0.4185 12.3 0.724863; 2996 -0.286271 12.3 0.786523;2997 -0.145344 12.3 0.824284; 2998 -1.53749e-16 12.3 0.837;2999 0.145344 12.3 0.824284; 3000 0.286271 12.3 0.786523;3001 0.4185 12.3 0.724863; 3002 0.538013 12.3 0.641179;3003 0.641179 12.3 0.538013; 3004 0.724863 12.3 0.4185;3005 0.786523 12.3 0.286271; 3006 0.824284 12.3 0.145344; 3007 0.837 12.45 0;3008 0.824284 12.45 -0.145344; 3009 0.786523 12.45 -0.286271;3010 0.724863 12.45 -0.4185; 3011 0.641179 12.45 -0.538013;3012 0.538013 12.45 -0.641179; 3013 0.4185 12.45 -0.724863;3014 0.286271 12.45 -0.786523; 3015 0.145344 12.45 -0.824284;3016 5.12498e-17 12.45 -0.837; 3017 -0.145344 12.45 -0.824284;3018 -0.286271 12.45 -0.786523; 3019 -0.4185 12.45 -0.724863;3020 -0.538013 12.45 -0.641179; 3021 -0.641179 12.45 -0.538013;3022 -0.724863 12.45 -0.4185; 3023 -0.786523 12.45 -0.286271;3024 -0.824284 12.45 -0.145344; 3025 -0.837 12.45 -1.025e-16;3026 -0.824284 12.45 0.145344; 3027 -0.786523 12.45 0.286271;3028 -0.724863 12.45 0.4185; 3029 -0.641179 12.45 0.538013;3030 -0.538013 12.45 0.641179; 3031 -0.4185 12.45 0.724863;3032 -0.286271 12.45 0.786523; 3033 -0.145344 12.45 0.824284;3034 -1.53749e-16 12.45 0.837; 3035 0.145344 12.45 0.824284;3036 0.286271 12.45 0.786523; 3037 0.4185 12.45 0.724863;3038 0.538013 12.45 0.641179; 3039 0.641179 12.45 0.538013;3040 0.724863 12.45 0.4185; 3041 0.786523 12.45 0.286271;3042 0.824284 12.45 0.145344; 3043 0.837 12.6 0; 3044 0.824284 12.6 -0.145344;3045 0.786523 12.6 -0.286271; 3046 0.724863 12.6 -0.4185;3047 0.641179 12.6 -0.538013; 3048 0.538013 12.6 -0.641179;3049 0.4185 12.6 -0.724863; 3050 0.286271 12.6 -0.786523;3051 0.145344 12.6 -0.824284; 3052 5.12498e-17 12.6 -0.837;3053 -0.145344 12.6 -0.824284; 3054 -0.286271 12.6 -0.786523;3055 -0.4185 12.6 -0.724863; 3056 -0.538013 12.6 -0.641179;3057 -0.641179 12.6 -0.538013; 3058 -0.724863 12.6 -0.4185;3059 -0.786523 12.6 -0.286271; 3060 -0.824284 12.6 -0.145344;3061 -0.837 12.6 -1.025e-16; 3062 -0.824284 12.6 0.145344;3063 -0.786523 12.6 0.286271; 3064 -0.724863 12.6 0.4185;3065 -0.641179 12.6 0.538013; 3066 -0.538013 12.6 0.641179;3067 -0.4185 12.6 0.724863; 3068 -0.286271 12.6 0.786523;3069 -0.145344 12.6 0.824284; 3070 -1.53749e-16 12.6 0.837;3071 0.145344 12.6 0.824284; 3072 0.286271 12.6 0.786523;3073 0.4185 12.6 0.724863; 3074 0.538013 12.6 0.641179;3075 0.641179 12.6 0.538013; 3076 0.724863 12.6 0.4185;3077 0.786523 12.6 0.286271; 3078 0.824284 12.6 0.145344; 3079 0.837 12.75 0;3080 0.824284 12.75 -0.145344; 3081 0.786523 12.75 -0.286271;3082 0.724863 12.75 -0.4185; 3083 0.641179 12.75 -0.538013;3084 0.538013 12.75 -0.641179; 3085 0.4185 12.75 -0.724863;3086 0.286271 12.75 -0.786523; 3087 0.145344 12.75 -0.824284;3088 5.12498e-17 12.75 -0.837; 3089 -0.145344 12.75 -0.824284;3090 -0.286271 12.75 -0.786523; 3091 -0.4185 12.75 -0.724863;3092 -0.538013 12.75 -0.641179; 3093 -0.641179 12.75 -0.538013;3094 -0.724863 12.75 -0.4185; 3095 -0.786523 12.75 -0.286271;3096 -0.824284 12.75 -0.145344; 3097 -0.837 12.75 -1.025e-16;3098 -0.824284 12.75 0.145344; 3099 -0.786523 12.75 0.286271;3100 -0.724863 12.75 0.4185; 3101 -0.641179 12.75 0.538013;3102 -0.538013 12.75 0.641179; 3103 -0.4185 12.75 0.724863;3104 -0.286271 12.75 0.786523; 3105 -0.145344 12.75 0.824284;3106 -1.53749e-16 12.75 0.837; 3107 0.145344 12.75 0.824284;3108 0.286271 12.75 0.786523; 3109 0.4185 12.75 0.724863;3110 0.538013 12.75 0.641179; 3111 0.641179 12.75 0.538013;3112 0.724863 12.75 0.4185; 3113 0.786523 12.75 0.286271;3114 0.824284 12.75 0.145344; 3115 0.837 12.9 0; 3116 0.824284 12.9 -0.145344;3117 0.786523 12.9 -0.286271; 3118 0.724863 12.9 -0.4185;3119 0.641179 12.9 -0.538013; 3120 0.538013 12.9 -0.641179;3121 0.4185 12.9 -0.724863; 3122 0.286271 12.9 -0.786523;3123 0.145344 12.9 -0.824284; 3124 5.12498e-17 12.9 -0.837;3125 -0.145344 12.9 -0.824284; 3126 -0.286271 12.9 -0.786523;3127 -0.4185 12.9 -0.724863; 3128 -0.538013 12.9 -0.641179;3129 -0.641179 12.9 -0.538013; 3130 -0.724863 12.9 -0.4185;3131 -0.786523 12.9 -0.286271; 3132 -0.824284 12.9 -0.145344;3133 -0.837 12.9 -1.025e-16; 3134 -0.824284 12.9 0.145344;3135 -0.786523 12.9 0.286271; 3136 -0.724863 12.9 0.4185;3137 -0.641179 12.9 0.538013; 3138 -0.538013 12.9 0.641179;3139 -0.4185 12.9 0.724863; 3140 -0.286271 12.9 0.786523;3141 -0.145344 12.9 0.824284; 3142 -1.53749e-16 12.9 0.837;3143 0.145344 12.9 0.824284; 3144 0.286271 12.9 0.786523;3145 0.4185 12.9 0.724863; 3146 0.538013 12.9 0.641179;3147 0.641179 12.9 0.538013; 3148 0.724863 12.9 0.4185;3149 0.786523 12.9 0.286271; 3150 0.824284 12.9 0.145344; 3151 0.837 13.05 0;3152 0.824284 13.05 -0.145344; 3153 0.786523 13.05 -0.286271;3154 0.724863 13.05 -0.4185; 3155 0.641179 13.05 -0.538013;3156 0.538013 13.05 -0.641179; 3157 0.4185 13.05 -0.724863;3158 0.286271 13.05 -0.786523; 3159 0.145344 13.05 -0.824284;3160 5.12498e-17 13.05 -0.837; 3161 -0.145344 13.05 -0.824284;3162 -0.286271 13.05 -0.786523; 3163 -0.4185 13.05 -0.724863;3164 -0.538013 13.05 -0.641179; 3165 -0.641179 13.05 -0.538013;3166 -0.724863 13.05 -0.4185; 3167 -0.786523 13.05 -0.286271;3168 -0.824284 13.05 -0.145344; 3169 -0.837 13.05 -1.025e-16;3170 -0.824284 13.05 0.145344; 3171 -0.786523 13.05 0.286271;3172 -0.724863 13.05 0.4185; 3173 -0.641179 13.05 0.538013;3174 -0.538013 13.05 0.641179; 3175 -0.4185 13.05 0.724863;3176 -0.286271 13.05 0.786523; 3177 -0.145344 13.05 0.824284;3178 -1.53749e-16 13.05 0.837; 3179 0.145344 13.05 0.824284;3180 0.286271 13.05 0.786523; 3181 0.4185 13.05 0.724863;3182 0.538013 13.05 0.641179; 3183 0.641179 13.05 0.538013;3184 0.724863 13.05 0.4185; 3185 0.786523 13.05 0.286271;3186 0.824284 13.05 0.145344; 3187 0.837 13.2 0; 3188 0.824284 13.2 -0.145344;3189 0.786523 13.2 -0.286271; 3190 0.724863 13.2 -0.4185;3191 0.641179 13.2 -0.538013; 3192 0.538013 13.2 -0.641179;3193 0.4185 13.2 -0.724863; 3194 0.286271 13.2 -0.786523;3195 0.145344 13.2 -0.824284; 3196 5.12498e-17 13.2 -0.837;3197 -0.145344 13.2 -0.824284; 3198 -0.286271 13.2 -0.786523;3199 -0.4185 13.2 -0.724863; 3200 -0.538013 13.2 -0.641179;3201 -0.641179 13.2 -0.538013; 3202 -0.724863 13.2 -0.4185;3203 -0.786523 13.2 -0.286271; 3204 -0.824284 13.2 -0.145344;3205 -0.837 13.2 -1.025e-16; 3206 -0.824284 13.2 0.145344;3207 -0.786523 13.2 0.286271; 3208 -0.724863 13.2 0.4185;3209 -0.641179 13.2 0.538013; 3210 -0.538013 13.2 0.641179;3211 -0.4185 13.2 0.724863; 3212 -0.286271 13.2 0.786523;3213 -0.145344 13.2 0.824284; 3214 -1.53749e-16 13.2 0.837;3215 0.145344 13.2 0.824284; 3216 0.286271 13.2 0.786523;3217 0.4185 13.2 0.724863; 3218 0.538013 13.2 0.641179;3219 0.641179 13.2 0.538013; 3220 0.724863 13.2 0.4185;3221 0.786523 13.2 0.286271; 3222 0.824284 13.2 0.145344; 3223 0.837 13.35 0;3224 0.824284 13.35 -0.145344; 3225 0.786523 13.35 -0.286271;3226 0.724863 13.35 -0.4185; 3227 0.641179 13.35 -0.538013;3228 0.538013 13.35 -0.641179; 3229 0.4185 13.35 -0.724863;3230 0.286271 13.35 -0.786523; 3231 0.145344 13.35 -0.824284;3232 5.12498e-17 13.35 -0.837; 3233 -0.145344 13.35 -0.824284;3234 -0.286271 13.35 -0.786523; 3235 -0.4185 13.35 -0.724863;3236 -0.538013 13.35 -0.641179; 3237 -0.641179 13.35 -0.538013;3238 -0.724863 13.35 -0.4185; 3239 -0.786523 13.35 -0.286271;3240 -0.824284 13.35 -0.145344; 3241 -0.837 13.35 -1.025e-16;3242 -0.824284 13.35 0.145344; 3243 -0.786523 13.35 0.286271;3244 -0.724863 13.35 0.4185; 3245 -0.641179 13.35 0.538013;3246 -0.538013 13.35 0.641179; 3247 -0.4185 13.35 0.724863;3248 -0.286271 13.35 0.786523; 3249 -0.145344 13.35 0.824284;3250 -1.53749e-16 13.35 0.837; 3251 0.145344 13.35 0.824284;3252 0.286271 13.35 0.786523; 3253 0.4185 13.35 0.724863;3254 0.538013 13.35 0.641179; 3255 0.641179 13.35 0.538013;3256 0.724863 13.35 0.4185; 3257 0.786523 13.35 0.286271;3258 0.824284 13.35 0.145344; 3259 0.837 13.5 0; 3260 0.824284 13.5 -0.145344;3261 0.786523 13.5 -0.286271; 3262 0.724863 13.5 -0.4185;3263 0.641179 13.5 -0.538013; 3264 0.538013 13.5 -0.641179;3265 0.4185 13.5 -0.724863; 3266 0.286271 13.5 -0.786523;3267 0.145344 13.5 -0.824284; 3268 5.12498e-17 13.5 -0.837;3269 -0.145344 13.5 -0.824284; 3270 -0.286271 13.5 -0.786523;3271 -0.4185 13.5 -0.724863; 3272 -0.538013 13.5 -0.641179;3273 -0.641179 13.5 -0.538013; 3274 -0.724863 13.5 -0.4185;3275 -0.786523 13.5 -0.286271; 3276 -0.824284 13.5 -0.145344;3277 -0.837 13.5 -1.025e-16; 3278 -0.824284 13.5 0.145344;3279 -0.786523 13.5 0.286271; 3280 -0.724863 13.5 0.4185;3281 -0.641179 13.5 0.538013; 3282 -0.538013 13.5 0.641179;3283 -0.4185 13.5 0.724863; 3284 -0.286271 13.5 0.786523;3285 -0.145344 13.5 0.824284; 3286 -1.53749e-16 13.5 0.837;3287 0.145344 13.5 0.824284; 3288 0.286271 13.5 0.786523;3289 0.4185 13.5 0.724863; 3290 0.538013 13.5 0.641179;3291 0.641179 13.5 0.538013; 3292 0.724863 13.5 0.4185;3293 0.786523 13.5 0.286271; 3294 0.824284 13.5 0.145344; 3295 0.837 13.65 0;3296 0.824284 13.65 -0.145344; 3297 0.786523 13.65 -0.286271;3298 0.724863 13.65 -0.4185; 3299 0.641179 13.65 -0.538013;3300 0.538013 13.65 -0.641179; 3301 0.4185 13.65 -0.724863;3302 0.286271 13.65 -0.786523; 3303 0.145344 13.65 -0.824284;3304 5.12498e-17 13.65 -0.837; 3305 -0.145344 13.65 -0.824284;3306 -0.286271 13.65 -0.786523; 3307 -0.4185 13.65 -0.724863;3308 -0.538013 13.65 -0.641179; 3309 -0.641179 13.65 -0.538013;3310 -0.724863 13.65 -0.4185; 3311 -0.786523 13.65 -0.286271;3312 -0.824284 13.65 -0.145344; 3313 -0.837 13.65 -1.025e-16;3314 -0.824284 13.65 0.145344; 3315 -0.786523 13.65 0.286271;3316 -0.724863 13.65 0.4185; 3317 -0.641179 13.65 0.538013;3318 -0.538013 13.65 0.641179; 3319 -0.4185 13.65 0.724863;3320 -0.286271 13.65 0.786523; 3321 -0.145344 13.65 0.824284;3322 -1.53749e-16 13.65 0.837; 3323 0.145344 13.65 0.824284;3324 0.286271 13.65 0.786523; 3325 0.4185 13.65 0.724863;3326 0.538013 13.65 0.641179; 3327 0.641179 13.65 0.538013;3328 0.724863 13.65 0.4185; 3329 0.786523 13.65 0.286271;3330 0.824284 13.65 0.145344; 3331 0.837 13.8 0; 3332 0.824284 13.8 -0.145344;3333 0.786523 13.8 -0.286271; 3334 0.724863 13.8 -0.4185;3335 0.641179 13.8 -0.538013; 3336 0.538013 13.8 -0.641179;3337 0.4185 13.8 -0.724863; 3338 0.286271 13.8 -0.786523;3339 0.145344 13.8 -0.824284; 3340 5.12498e-17 13.8 -0.837;3341 -0.145344 13.8 -0.824284; 3342 -0.286271 13.8 -0.786523;3343 -0.4185 13.8 -0.724863; 3344 -0.538013 13.8 -0.641179;3345 -0.641179 13.8 -0.538013; 3346 -0.724863 13.8 -0.4185;3347 -0.786523 13.8 -0.286271; 3348 -0.824284 13.8 -0.145344;3349 -0.837 13.8 -1.025e-16; 3350 -0.824284 13.8 0.145344;3351 -0.786523 13.8 0.286271; 3352 -0.724863 13.8 0.4185;3353 -0.641179 13.8 0.538013; 3354 -0.538013 13.8 0.641179;3355 -0.4185 13.8 0.724863; 3356 -0.286271 13.8 0.786523;3357 -0.145344 13.8 0.824284; 3358 -1.53749e-16 13.8 0.837;3359 0.145344 13.8 0.824284; 3360 0.286271 13.8 0.786523;3361 0.4185 13.8 0.724863; 3362 0.538013 13.8 0.641179;3363 0.641179 13.8 0.538013; 3364 0.724863 13.8 0.4185;3365 0.786523 13.8 0.286271; 3366 0.824284 13.8 0.145344; 3367 0.837 13.95 0;3368 0.824284 13.95 -0.145344; 3369 0.786523 13.95 -0.286271;3370 0.724863 13.95 -0.4185; 3371 0.641179 13.95 -0.538013;3372 0.538013 13.95 -0.641179; 3373 0.4185 13.95 -0.724863;3374 0.286271 13.95 -0.786523; 3375 0.145344 13.95 -0.824284;3376 5.12498e-17 13.95 -0.837; 3377 -0.145344 13.95 -0.824284;3378 -0.286271 13.95 -0.786523; 3379 -0.4185 13.95 -0.724863;3380 -0.538013 13.95 -0.641179; 3381 -0.641179 13.95 -0.538013;3382 -0.724863 13.95 -0.4185; 3383 -0.786523 13.95 -0.286271;3384 -0.824284 13.95 -0.145344; 3385 -0.837 13.95 -1.025e-16;3386 -0.824284 13.95 0.145344; 3387 -0.786523 13.95 0.286271;3388 -0.724863 13.95 0.4185; 3389 -0.641179 13.95 0.538013;3390 -0.538013 13.95 0.641179; 3391 -0.4185 13.95 0.724863;3392 -0.286271 13.95 0.786523; 3393 -0.145344 13.95 0.824284;3394 -1.53749e-16 13.95 0.837; 3395 0.145344 13.95 0.824284;3396 0.286271 13.95 0.786523; 3397 0.4185 13.95 0.724863;3398 0.538013 13.95 0.641179; 3399 0.641179 13.95 0.538013;3400 0.724863 13.95 0.4185; 3401 0.786523 13.95 0.286271;3402 0.824284 13.95 0.145344; 3403 0.837 14.1 0; 3404 0.824284 14.1 -0.145344;3405 0.786523 14.1 -0.286271; 3406 0.724863 14.1 -0.4185;3407 0.641179 14.1 -0.538013; 3408 0.538013 14.1 -0.641179;3409 0.4185 14.1 -0.724863; 3410 0.286271 14.1 -0.786523;3411 0.145344 14.1 -0.824284; 3412 5.12498e-17 14.1 -0.837;3413 -0.145344 14.1 -0.824284; 3414 -0.286271 14.1 -0.786523;3415 -0.4185 14.1 -0.724863; 3416 -0.538013 14.1 -0.641179;3417 -0.641179 14.1 -0.538013; 3418 -0.724863 14.1 -0.4185;3419 -0.786523 14.1 -0.286271; 3420 -0.824284 14.1 -0.145344;3421 -0.837 14.1 -1.025e-16; 3422 -0.824284 14.1 0.145344;3423 -0.786523 14.1 0.286271; 3424 -0.724863 14.1 0.4185;3425 -0.641179 14.1 0.538013; 3426 -0.538013 14.1 0.641179;3427 -0.4185 14.1 0.724863; 3428 -0.286271 14.1 0.786523;3429 -0.145344 14.1 0.824284; 3430 -1.53749e-16 14.1 0.837;3431 0.145344 14.1 0.824284; 3432 0.286271 14.1 0.786523;3433 0.4185 14.1 0.724863; 3434 0.538013 14.1 0.641179;3435 0.641179 14.1 0.538013; 3436 0.724863 14.1 0.4185;3437 0.786523 14.1 0.286271; 3438 0.824284 14.1 0.145344; 3439 0.837 14.25 0;3440 0.824284 14.25 -0.145344; 3441 0.786523 14.25 -0.286271;3442 0.724863 14.25 -0.4185; 3443 0.641179 14.25 -0.538013;3444 0.538013 14.25 -0.641179; 3445 0.4185 14.25 -0.724863;3446 0.286271 14.25 -0.786523; 3447 0.145344 14.25 -0.824284;3448 5.12498e-17 14.25 -0.837; 3449 -0.145344 14.25 -0.824284;3450 -0.286271 14.25 -0.786523; 3451 -0.4185 14.25 -0.724863;3452 -0.538013 14.25 -0.641179; 3453 -0.641179 14.25 -0.538013;3454 -0.724863 14.25 -0.4185; 3455 -0.786523 14.25 -0.286271;3456 -0.824284 14.25 -0.145344; 3457 -0.837 14.25 -1.025e-16;3458 -0.824284 14.25 0.145344; 3459 -0.786523 14.25 0.286271;3460 -0.724863 14.25 0.4185; 3461 -0.641179 14.25 0.538013;3462 -0.538013 14.25 0.641179; 3463 -0.4185 14.25 0.724863;3464 -0.286271 14.25 0.786523; 3465 -0.145344 14.25 0.824284;3466 -1.53749e-16 14.25 0.837; 3467 0.145344 14.25 0.824284;3468 0.286271 14.25 0.786523; 3469 0.4185 14.25 0.724863;3470 0.538013 14.25 0.641179; 3471 0.641179 14.25 0.538013;3472 0.724863 14.25 0.4185; 3473 0.786523 14.25 0.286271;3474 0.824284 14.25 0.145344; 3475 0.837 14.4 0; 3476 0.824284 14.4 -0.145344;3477 0.786523 14.4 -0.286271; 3478 0.724863 14.4 -0.4185;3479 0.641179 14.4 -0.538013; 3480 0.538013 14.4 -0.641179;3481 0.4185 14.4 -0.724863; 3482 0.286271 14.4 -0.786523;3483 0.145344 14.4 -0.824284; 3484 5.12498e-17 14.4 -0.837;3485 -0.145344 14.4 -0.824284; 3486 -0.286271 14.4 -0.786523;3487 -0.4185 14.4 -0.724863; 3488 -0.538013 14.4 -0.641179;3489 -0.641179 14.4 -0.538013; 3490 -0.724863 14.4 -0.4185;3491 -0.786523 14.4 -0.286271; 3492 -0.824284 14.4 -0.145344;3493 -0.837 14.4 -1.025e-16; 3494 -0.824284 14.4 0.145344;3495 -0.786523 14.4 0.286271; 3496 -0.724863 14.4 0.4185;3497 -0.641179 14.4 0.538013; 3498 -0.538013 14.4 0.641179;3499 -0.4185 14.4 0.724863; 3500 -0.286271 14.4 0.786523;3501 -0.145344 14.4 0.824284; 3502 -1.53749e-16 14.4 0.837;3503 0.145344 14.4 0.824284; 3504 0.286271 14.4 0.786523;3505 0.4185 14.4 0.724863; 3506 0.538013 14.4 0.641179;3507 0.641179 14.4 0.538013; 3508 0.724863 14.4 0.4185;3509 0.786523 14.4 0.286271; 3510 0.824284 14.4 0.145344; 3511 0.837 14.55 0;3512 0.824284 14.55 -0.145344; 3513 0.786523 14.55 -0.286271;3514 0.724863 14.55 -0.4185; 3515 0.641179 14.55 -0.538013;3516 0.538013 14.55 -0.641179; 3517 0.4185 14.55 -0.724863;3518 0.286271 14.55 -0.786523; 3519 0.145344 14.55 -0.824284;3520 5.12498e-17 14.55 -0.837; 3521 -0.145344 14.55 -0.824284;3522 -0.286271 14.55 -0.786523; 3523 -0.4185 14.55 -0.724863;3524 -0.538013 14.55 -0.641179; 3525 -0.641179 14.55 -0.538013;3526 -0.724863 14.55 -0.4185; 3527 -0.786523 14.55 -0.286271;3528 -0.824284 14.55 -0.145344; 3529 -0.837 14.55 -1.025e-16;3530 -0.824284 14.55 0.145344; 3531 -0.786523 14.55 0.286271;3532 -0.724863 14.55 0.4185; 3533 -0.641179 14.55 0.538013;3534 -0.538013 14.55 0.641179; 3535 -0.4185 14.55 0.724863;3536 -0.286271 14.55 0.786523; 3537 -0.145344 14.55 0.824284;3538 -1.53749e-16 14.55 0.837; 3539 0.145344 14.55 0.824284;3540 0.286271 14.55 0.786523; 3541 0.4185 14.55 0.724863;3542 0.538013 14.55 0.641179; 3543 0.641179 14.55 0.538013;3544 0.724863 14.55 0.4185; 3545 0.786523 14.55 0.286271;3546 0.824284 14.55 0.145344; 3547 0.837 14.7 0; 3548 0.824284 14.7 -0.145344;3549 0.786523 14.7 -0.286271; 3550 0.724863 14.7 -0.4185;3551 0.641179 14.7 -0.538013; 3552 0.538013 14.7 -0.641179;3553 0.4185 14.7 -0.724863; 3554 0.286271 14.7 -0.786523;3555 0.145344 14.7 -0.824284; 3556 5.12498e-17 14.7 -0.837;3557 -0.145344 14.7 -0.824284; 3558 -0.286271 14.7 -0.786523;3559 -0.4185 14.7 -0.724863; 3560 -0.538013 14.7 -0.641179;3561 -0.641179 14.7 -0.538013; 3562 -0.724863 14.7 -0.4185;3563 -0.786523 14.7 -0.286271; 3564 -0.824284 14.7 -0.145344;3565 -0.837 14.7 -1.025e-16; 3566 -0.824284 14.7 0.145344;3567 -0.786523 14.7 0.286271; 3568 -0.724863 14.7 0.4185;3569 -0.641179 14.7 0.538013; 3570 -0.538013 14.7 0.641179;3571 -0.4185 14.7 0.724863; 3572 -0.286271 14.7 0.786523;3573 -0.145344 14.7 0.824284; 3574 -1.53749e-16 14.7 0.837;3575 0.145344 14.7 0.824284; 3576 0.286271 14.7 0.786523;3577 0.4185 14.7 0.724863; 3578 0.538013 14.7 0.641179;3579 0.641179 14.7 0.538013; 3580 0.724863 14.7 0.4185;3581 0.786523 14.7 0.286271; 3582 0.824284 14.7 0.145344; 3583 0.837 14.85 0;3584 0.824284 14.85 -0.145344; 3585 0.786523 14.85 -0.286271;3586 0.724863 14.85 -0.4185; 3587 0.641179 14.85 -0.538013;3588 0.538013 14.85 -0.641179; 3589 0.4185 14.85 -0.724863;3590 0.286271 14.85 -0.786523; 3591 0.145344 14.85 -0.824284;3592 5.12498e-17 14.85 -0.837; 3593 -0.145344 14.85 -0.824284;3594 -0.286271 14.85 -0.786523; 3595 -0.4185 14.85 -0.724863;3596 -0.538013 14.85 -0.641179; 3597 -0.641179 14.85 -0.538013;3598 -0.724863 14.85 -0.4185; 3599 -0.786523 14.85 -0.286271;3600 -0.824284 14.85 -0.145344; 3601 -0.837 14.85 -1.025e-16;3602 -0.824284 14.85 0.145344; 3603 -0.786523 14.85 0.286271;3604 -0.724863 14.85 0.4185; 3605 -0.641179 14.85 0.538013;3606 -0.538013 14.85 0.641179; 3607 -0.4185 14.85 0.724863;3608 -0.286271 14.85 0.786523; 3609 -0.145344 14.85 0.824284;3610 -1.53749e-16 14.85 0.837; 3611 0.145344 14.85 0.824284;3612 0.286271 14.85 0.786523; 3613 0.4185 14.85 0.724863;3614 0.538013 14.85 0.641179; 3615 0.641179 14.85 0.538013;3616 0.724863 14.85 0.4185; 3617 0.786523 14.85 0.286271;3618 0.824284 14.85 0.145344; 3619 0.837 15 0; 3620 0.824284 15 -0.145344;3621 0.786523 15 -0.286271; 3622 0.724863 15 -0.4185;3623 0.641179 15 -0.538013; 3624 0.538013 15 -0.641179;3625 0.4185 15 -0.724863; 3626 0.286271 15 -0.786523;3627 0.145344 15 -0.824284; 3628 5.12498e-17 15 -0.837;3629 -0.145344 15 -0.824284; 3630 -0.286271 15 -0.786523;3631 -0.4185 15 -0.724863; 3632 -0.538013 15 -0.641179;3633 -0.641179 15 -0.538013; 3634 -0.724863 15 -0.4185;3635 -0.786523 15 -0.286271; 3636 -0.824284 15 -0.145344;3637 -0.837 15 -1.025e-16; 3638 -0.824284 15 0.145344;3639 -0.786523 15 0.286271; 3640 -0.724863 15 0.4185;3641 -0.641179 15 0.538013; 3642 -0.538013 15 0.641179;3643 -0.4185 15 0.724863; 3644 -0.286271 15 0.786523;3645 -0.145344 15 0.824284; 3646 -1.53749e-16 15 0.837;3647 0.145344 15 0.824284; 3648 0.286271 15 0.786523; 3649 0.4185 15 0.724863;3650 0.538013 15 0.641179; 3651 0.641179 15 0.538013; 3652 0.724863 15 0.4185;3653 0.786523 15 0.286271; 3654 0.824284 15 0.145344; 3655 0.837 15.15 0;3656 0.824284 15.15 -0.145344; 3657 0.786523 15.15 -0.286271;3658 0.724863 15.15 -0.4185; 3659 0.641179 15.15 -0.538013;3660 0.538013 15.15 -0.641179; 3661 0.4185 15.15 -0.724863;3662 0.286271 15.15 -0.786523; 3663 0.145344 15.15 -0.824284;3664 5.12498e-17 15.15 -0.837; 3665 -0.145344 15.15 -0.824284;3666 -0.286271 15.15 -0.786523; 3667 -0.4185 15.15 -0.724863;3668 -0.538013 15.15 -0.641179; 3669 -0.641179 15.15 -0.538013;3670 -0.724863 15.15 -0.4185; 3671 -0.786523 15.15 -0.286271;3672 -0.824284 15.15 -0.145344; 3673 -0.837 15.15 -1.025e-16;3674 -0.824284 15.15 0.145344; 3675 -0.786523 15.15 0.286271;3676 -0.724863 15.15 0.4185; 3677 -0.641179 15.15 0.538013;3678 -0.538013 15.15 0.641179; 3679 -0.4185 15.15 0.724863;3680 -0.286271 15.15 0.786523; 3681 -0.145344 15.15 0.824284;3682 -1.53749e-16 15.15 0.837; 3683 0.145344 15.15 0.824284;3684 0.286271 15.15 0.786523; 3685 0.4185 15.15 0.724863;3686 0.538013 15.15 0.641179; 3687 0.641179 15.15 0.538013;3688 0.724863 15.15 0.4185; 3689 0.786523 15.15 0.286271;3690 0.824284 15.15 0.145344; 3691 0.837 15.3 0; 3692 0.824284 15.3 -0.145344;3693 0.786523 15.3 -0.286271; 3694 0.724863 15.3 -0.4185;3695 0.641179 15.3 -0.538013; 3696 0.538013 15.3 -0.641179;3697 0.4185 15.3 -0.724863; 3698 0.286271 15.3 -0.786523;3699 0.145344 15.3 -0.824284; 3700 5.12498e-17 15.3 -0.837;3701 -0.145344 15.3 -0.824284; 3702 -0.286271 15.3 -0.786523;3703 -0.4185 15.3 -0.724863; 3704 -0.538013 15.3 -0.641179;3705 -0.641179 15.3 -0.538013; 3706 -0.724863 15.3 -0.4185;3707 -0.786523 15.3 -0.286271; 3708 -0.824284 15.3 -0.145344;3709 -0.837 15.3 -1.025e-16; 3710 -0.824284 15.3 0.145344;3711 -0.786523 15.3 0.286271; 3712 -0.724863 15.3 0.4185;3713 -0.641179 15.3 0.538013; 3714 -0.538013 15.3 0.641179;3715 -0.4185 15.3 0.724863; 3716 -0.286271 15.3 0.786523;3717 -0.145344 15.3 0.824284; 3718 -1.53749e-16 15.3 0.837;3719 0.145344 15.3 0.824284; 3720 0.286271 15.3 0.786523;3721 0.4185 15.3 0.724863; 3722 0.538013 15.3 0.641179;3723 0.641179 15.3 0.538013; 3724 0.724863 15.3 0.4185;3725 0.786523 15.3 0.286271; 3726 0.824284 15.3 0.145344; 3727 0.837 15.45 0;3728 0.824284 15.45 -0.145344; 3729 0.786523 15.45 -0.286271;3730 0.724863 15.45 -0.4185; 3731 0.641179 15.45 -0.538013;3732 0.538013 15.45 -0.641179; 3733 0.4185 15.45 -0.724863;3734 0.286271 15.45 -0.786523; 3735 0.145344 15.45 -0.824284;3736 5.12498e-17 15.45 -0.837; 3737 -0.145344 15.45 -0.824284;3738 -0.286271 15.45 -0.786523; 3739 -0.4185 15.45 -0.724863;3740 -0.538013 15.45 -0.641179; 3741 -0.641179 15.45 -0.538013;3742 -0.724863 15.45 -0.4185; 3743 -0.786523 15.45 -0.286271;3744 -0.824284 15.45 -0.145344; 3745 -0.837 15.45 -1.025e-16;3746 -0.824284 15.45 0.145344; 3747 -0.786523 15.45 0.286271;3748 -0.724863 15.45 0.4185; 3749 -0.641179 15.45 0.538013;3750 -0.538013 15.45 0.641179; 3751 -0.4185 15.45 0.724863;3752 -0.286271 15.45 0.786523; 3753 -0.145344 15.45 0.824284;3754 -1.53749e-16 15.45 0.837; 3755 0.145344 15.45 0.824284;3756 0.286271 15.45 0.786523; 3757 0.4185 15.45 0.724863;3758 0.538013 15.45 0.641179; 3759 0.641179 15.45 0.538013;3760 0.724863 15.45 0.4185; 3761 0.786523 15.45 0.286271;3762 0.824284 15.45 0.145344; 3763 0.837 15.6 0; 3764 0.824284 15.6 -0.145344;3765 0.786523 15.6 -0.286271; 3766 0.724863 15.6 -0.4185;3767 0.641179 15.6 -0.538013; 3768 0.538013 15.6 -0.641179;3769 0.4185 15.6 -0.724863; 3770 0.286271 15.6 -0.786523;3771 0.145344 15.6 -0.824284; 3772 5.12498e-17 15.6 -0.837;3773 -0.145344 15.6 -0.824284; 3774 -0.286271 15.6 -0.786523;3775 -0.4185 15.6 -0.724863; 3776 -0.538013 15.6 -0.641179;3777 -0.641179 15.6 -0.538013; 3778 -0.724863 15.6 -0.4185;3779 -0.786523 15.6 -0.286271; 3780 -0.824284 15.6 -0.145344;3781 -0.837 15.6 -1.025e-16; 3782 -0.824284 15.6 0.145344;3783 -0.786523 15.6 0.286271; 3784 -0.724863 15.6 0.4185;3785 -0.641179 15.6 0.538013; 3786 -0.538013 15.6 0.641179;3787 -0.4185 15.6 0.724863; 3788 -0.286271 15.6 0.786523;3789 -0.145344 15.6 0.824284; 3790 -1.53749e-16 15.6 0.837;3791 0.145344 15.6 0.824284; 3792 0.286271 15.6 0.786523;3793 0.4185 15.6 0.724863; 3794 0.538013 15.6 0.641179;3795 0.641179 15.6 0.538013; 3796 0.724863 15.6 0.4185;3797 0.786523 15.6 0.286271; 3798 0.824284 15.6 0.145344; 3799 0.837 15.75 0;3800 0.824284 15.75 -0.145344; 3801 0.786523 15.75 -0.286271;3802 0.724863 15.75 -0.4185; 3803 0.641179 15.75 -0.538013;3804 0.538013 15.75 -0.641179; 3805 0.4185 15.75 -0.724863;3806 0.286271 15.75 -0.786523; 3807 0.145344 15.75 -0.824284;3808 5.12498e-17 15.75 -0.837; 3809 -0.145344 15.75 -0.824284;3810 -0.286271 15.75 -0.786523; 3811 -0.4185 15.75 -0.724863;3812 -0.538013 15.75 -0.641179; 3813 -0.641179 15.75 -0.538013;3814 -0.724863 15.75 -0.4185; 3815 -0.786523 15.75 -0.286271;3816 -0.824284 15.75 -0.145344; 3817 -0.837 15.75 -1.025e-16;3818 -0.824284 15.75 0.145344; 3819 -0.786523 15.75 0.286271;3820 -0.724863 15.75 0.4185; 3821 -0.641179 15.75 0.538013;3822 -0.538013 15.75 0.641179; 3823 -0.4185 15.75 0.724863;3824 -0.286271 15.75 0.786523; 3825 -0.145344 15.75 0.824284;3826 -1.53749e-16 15.75 0.837; 3827 0.145344 15.75 0.824284;3828 0.286271 15.75 0.786523; 3829 0.4185 15.75 0.724863;3830 0.538013 15.75 0.641179; 3831 0.641179 15.75 0.538013;3832 0.724863 15.75 0.4185; 3833 0.786523 15.75 0.286271;3834 0.824284 15.75 0.145344; 3835 0.837 15.9 0; 3836 0.824284 15.9 -0.145344;3837 0.786523 15.9 -0.286271; 3838 0.724863 15.9 -0.4185;3839 0.641179 15.9 -0.538013; 3840 0.538013 15.9 -0.641179;3841 0.4185 15.9 -0.724863; 3842 0.286271 15.9 -0.786523;3843 0.145344 15.9 -0.824284; 3844 5.12498e-17 15.9 -0.837;3845 -0.145344 15.9 -0.824284; 3846 -0.286271 15.9 -0.786523;3847 -0.4185 15.9 -0.724863; 3848 -0.538013 15.9 -0.641179;3849 -0.641179 15.9 -0.538013; 3850 -0.724863 15.9 -0.4185;3851 -0.786523 15.9 -0.286271; 3852 -0.824284 15.9 -0.145344;3853 -0.837 15.9 -1.025e-16; 3854 -0.824284 15.9 0.145344;3855 -0.786523 15.9 0.286271; 3856 -0.724863 15.9 0.4185;3857 -0.641179 15.9 0.538013; 3858 -0.538013 15.9 0.641179;3859 -0.4185 15.9 0.724863; 3860 -0.286271 15.9 0.786523;3861 -0.145344 15.9 0.824284; 3862 -1.53749e-16 15.9 0.837;3863 0.145344 15.9 0.824284; 3864 0.286271 15.9 0.786523;3865 0.4185 15.9 0.724863; 3866 0.538013 15.9 0.641179;3867 0.641179 15.9 0.538013; 3868 0.724863 15.9 0.4185;3869 0.786523 15.9 0.286271; 3870 0.824284 15.9 0.145344; 3871 0.837 16.05 0;3872 0.824284 16.05 -0.145344; 3873 0.786523 16.05 -0.286271;3874 0.724863 16.05 -0.4185; 3875 0.641179 16.05 -0.538013;3876 0.538013 16.05 -0.641179; 3877 0.4185 16.05 -0.724863;3878 0.286271 16.05 -0.786523; 3879 0.145344 16.05 -0.824284;3880 5.12498e-17 16.05 -0.837; 3881 -0.145344 16.05 -0.824284;3882 -0.286271 16.05 -0.786523; 3883 -0.4185 16.05 -0.724863;3884 -0.538013 16.05 -0.641179; 3885 -0.641179 16.05 -0.538013;3886 -0.724863 16.05 -0.4185; 3887 -0.786523 16.05 -0.286271;3888 -0.824284 16.05 -0.145344; 3889 -0.837 16.05 -1.025e-16;3890 -0.824284 16.05 0.145344; 3891 -0.786523 16.05 0.286271;3892 -0.724863 16.05 0.4185; 3893 -0.641179 16.05 0.538013;3894 -0.538013 16.05 0.641179; 3895 -0.4185 16.05 0.724863;3896 -0.286271 16.05 0.786523; 3897 -0.145344 16.05 0.824284;3898 -1.53749e-16 16.05 0.837; 3899 0.145344 16.05 0.824284;3900 0.286271 16.05 0.786523; 3901 0.4185 16.05 0.724863;3902 0.538013 16.05 0.641179; 3903 0.641179 16.05 0.538013;3904 0.724863 16.05 0.4185; 3905 0.786523 16.05 0.286271;3906 0.824284 16.05 0.145344; 3907 0.837 16.2 0; 3908 0.824284 16.2 -0.145344;3909 0.786523 16.2 -0.286271; 3910 0.724863 16.2 -0.4185;3911 0.641179 16.2 -0.538013; 3912 0.538013 16.2 -0.641179;3913 0.4185 16.2 -0.724863; 3914 0.286271 16.2 -0.786523;3915 0.145344 16.2 -0.824284; 3916 5.12498e-17 16.2 -0.837;3917 -0.145344 16.2 -0.824284; 3918 -0.286271 16.2 -0.786523;3919 -0.4185 16.2 -0.724863; 3920 -0.538013 16.2 -0.641179;3921 -0.641179 16.2 -0.538013; 3922 -0.724863 16.2 -0.4185;3923 -0.786523 16.2 -0.286271; 3924 -0.824284 16.2 -0.145344;3925 -0.837 16.2 -1.025e-16; 3926 -0.824284 16.2 0.145344;3927 -0.786523 16.2 0.286271; 3928 -0.724863 16.2 0.4185;3929 -0.641179 16.2 0.538013; 3930 -0.538013 16.2 0.641179;3931 -0.4185 16.2 0.724863; 3932 -0.286271 16.2 0.786523;3933 -0.145344 16.2 0.824284; 3934 -1.53749e-16 16.2 0.837;3935 0.145344 16.2 0.824284; 3936 0.286271 16.2 0.786523;3937 0.4185 16.2 0.724863; 3938 0.538013 16.2 0.641179;3939 0.641179 16.2 0.538013; 3940 0.724863 16.2 0.4185;3941 0.786523 16.2 0.286271; 3942 0.824284 16.2 0.145344; 3943 0.837 16.35 0;3944 0.824284 16.35 -0.145344; 3945 0.786523 16.35 -0.286271;3946 0.724863 16.35 -0.4185; 3947 0.641179 16.35 -0.538013;3948 0.538013 16.35 -0.641179; 3949 0.4185 16.35 -0.724863;3950 0.286271 16.35 -0.786523; 3951 0.145344 16.35 -0.824284;3952 5.12498e-17 16.35 -0.837; 3953 -0.145344 16.35 -0.824284;3954 -0.286271 16.35 -0.786523; 3955 -0.4185 16.35 -0.724863;3956 -0.538013 16.35 -0.641179; 3957 -0.641179 16.35 -0.538013;3958 -0.724863 16.35 -0.4185; 3959 -0.786523 16.35 -0.286271;3960 -0.824284 16.35 -0.145344; 3961 -0.837 16.35 -1.025e-16;3962 -0.824284 16.35 0.145344; 3963 -0.786523 16.35 0.286271;3964 -0.724863 16.35 0.4185; 3965 -0.641179 16.35 0.538013;3966 -0.538013 16.35 0.641179; 3967 -0.4185 16.35 0.724863;3968 -0.286271 16.35 0.786523; 3969 -0.145344 16.35 0.824284;3970 -1.53749e-16 16.35 0.837; 3971 0.145344 16.35 0.824284;3972 0.286271 16.35 0.786523; 3973 0.4185 16.35 0.724863;3974 0.538013 16.35 0.641179; 3975 0.641179 16.35 0.538013;3976 0.724863 16.35 0.4185; 3977 0.786523 16.35 0.286271;3978 0.824284 16.35 0.145344; 3979 0.837 16.5 0; 3980 0.824284 16.5 -0.145344;3981 0.786523 16.5 -0.286271; 3982 0.724863 16.5 -0.4185;3983 0.641179 16.5 -0.538013; 3984 0.538013 16.5 -0.641179;3985 0.4185 16.5 -0.724863; 3986 0.286271 16.5 -0.786523;3987 0.145344 16.5 -0.824284; 3988 5.12498e-17 16.5 -0.837;3989 -0.145344 16.5 -0.824284; 3990 -0.286271 16.5 -0.786523;3991 -0.4185 16.5 -0.724863; 3992 -0.538013 16.5 -0.641179;3993 -0.641179 16.5 -0.538013; 3994 -0.724863 16.5 -0.4185;3995 -0.786523 16.5 -0.286271; 3996 -0.824284 16.5 -0.145344;3997 -0.837 16.5 -1.025e-16; 3998 -0.824284 16.5 0.145344;3999 -0.786523 16.5 0.286271; 4000 -0.724863 16.5 0.4185;4001 -0.641179 16.5 0.538013; 4002 -0.538013 16.5 0.641179;4003 -0.4185 16.5 0.724863; 4004 -0.286271 16.5 0.786523;4005 -0.145344 16.5 0.824284; 4006 -1.53749e-16 16.5 0.837;4007 0.145344 16.5 0.824284; 4008 0.286271 16.5 0.786523;4009 0.4185 16.5 0.724863; 4010 0.538013 16.5 0.641179;4011 0.641179 16.5 0.538013; 4012 0.724863 16.5 0.4185;4013 0.786523 16.5 0.286271; 4014 0.824284 16.5 0.145344; 4015 0.837 16.65 0;4016 0.824284 16.65 -0.145344; 4017 0.786523 16.65 -0.286271;4018 0.724863 16.65 -0.4185; 4019 0.641179 16.65 -0.538013;4020 0.538013 16.65 -0.641179; 4021 0.4185 16.65 -0.724863;4022 0.286271 16.65 -0.786523; 4023 0.145344 16.65 -0.824284;4024 5.12498e-17 16.65 -0.837; 4025 -0.145344 16.65 -0.824284;4026 -0.286271 16.65 -0.786523; 4027 -0.4185 16.65 -0.724863;4028 -0.538013 16.65 -0.641179; 4029 -0.641179 16.65 -0.538013;4030 -0.724863 16.65 -0.4185; 4031 -0.786523 16.65 -0.286271;4032 -0.824284 16.65 -0.145344; 4033 -0.837 16.65 -1.025e-16;4034 -0.824284 16.65 0.145344; 4035 -0.786523 16.65 0.286271;4036 -0.724863 16.65 0.4185; 4037 -0.641179 16.65 0.538013;4038 -0.538013 16.65 0.641179; 4039 -0.4185 16.65 0.724863;4040 -0.286271 16.65 0.786523; 4041 -0.145344 16.65 0.824284;4042 -1.53749e-16 16.65 0.837; 4043 0.145344 16.65 0.824284;4044 0.286271 16.65 0.786523; 4045 0.4185 16.65 0.724863;4046 0.538013 16.65 0.641179; 4047 0.641179 16.65 0.538013;4048 0.724863 16.65 0.4185; 4049 0.786523 16.65 0.286271;4050 0.824284 16.65 0.145344; 4051 0.837 16.8 0; 4052 0.824284 16.8 -0.145344;4053 0.786523 16.8 -0.286271; 4054 0.724863 16.8 -0.4185;4055 0.641179 16.8 -0.538013; 4056 0.538013 16.8 -0.641179;4057 0.4185 16.8 -0.724863; 4058 0.286271 16.8 -0.786523;4059 0.145344 16.8 -0.824284; 4060 5.12498e-17 16.8 -0.837;4061 -0.145344 16.8 -0.824284; 4062 -0.286271 16.8 -0.786523;4063 -0.4185 16.8 -0.724863; 4064 -0.538013 16.8 -0.641179;4065 -0.641179 16.8 -0.538013; 4066 -0.724863 16.8 -0.4185;4067 -0.786523 16.8 -0.286271; 4068 -0.824284 16.8 -0.145344;4069 -0.837 16.8 -1.025e-16; 4070 -0.824284 16.8 0.145344;4071 -0.786523 16.8 0.286271; 4072 -0.724863 16.8 0.4185;4073 -0.641179 16.8 0.538013; 4074 -0.538013 16.8 0.641179;4075 -0.4185 16.8 0.724863; 4076 -0.286271 16.8 0.786523;4077 -0.145344 16.8 0.824284; 4078 -1.53749e-16 16.8 0.837;4079 0.145344 16.8 0.824284; 4080 0.286271 16.8 0.786523;4081 0.4185 16.8 0.724863; 4082 0.538013 16.8 0.641179;4083 0.641179 16.8 0.538013; 4084 0.724863 16.8 0.4185;4085 0.786523 16.8 0.286271; 4086 0.824284 16.8 0.145344; 4087 0.837 16.95 0;4088 0.824284 16.95 -0.145344; 4089 0.786523 16.95 -0.286271;4090 0.724863 16.95 -0.4185; 4091 0.641179 16.95 -0.538013;4092 0.538013 16.95 -0.641179; 4093 0.4185 16.95 -0.724863;4094 0.286271 16.95 -0.786523; 4095 0.145344 16.95 -0.824284;4096 5.12498e-17 16.95 -0.837; 4097 -0.145344 16.95 -0.824284;4098 -0.286271 16.95 -0.786523; 4099 -0.4185 16.95 -0.724863;4100 -0.538013 16.95 -0.641179; 4101 -0.641179 16.95 -0.538013;4102 -0.724863 16.95 -0.4185; 4103 -0.786523 16.95 -0.286271;4104 -0.824284 16.95 -0.145344; 4105 -0.837 16.95 -1.025e-16;4106 -0.824284 16.95 0.145344; 4107 -0.786523 16.95 0.286271;4108 -0.724863 16.95 0.4185; 4109 -0.641179 16.95 0.538013;4110 -0.538013 16.95 0.641179; 4111 -0.4185 16.95 0.724863;4112 -0.286271 16.95 0.786523; 4113 -0.145344 16.95 0.824284;4114 -1.53749e-16 16.95 0.837; 4115 0.145344 16.95 0.824284;4116 0.286271 16.95 0.786523; 4117 0.4185 16.95 0.724863;4118 0.538013 16.95 0.641179; 4119 0.641179 16.95 0.538013;4120 0.724863 16.95 0.4185; 4121 0.786523 16.95 0.286271;4122 0.824284 16.95 0.145344; 4123 0.837 17.1 0; 4124 0.824284 17.1 -0.145344;4125 0.786523 17.1 -0.286271; 4126 0.724863 17.1 -0.4185;4127 0.641179 17.1 -0.538013; 4128 0.538013 17.1 -0.641179;4129 0.4185 17.1 -0.724863; 4130 0.286271 17.1 -0.786523;4131 0.145344 17.1 -0.824284; 4132 5.12498e-17 17.1 -0.837;4133 -0.145344 17.1 -0.824284; 4134 -0.286271 17.1 -0.786523;4135 -0.4185 17.1 -0.724863; 4136 -0.538013 17.1 -0.641179;4137 -0.641179 17.1 -0.538013; 4138 -0.724863 17.1 -0.4185;4139 -0.786523 17.1 -0.286271; 4140 -0.824284 17.1 -0.145344;4141 -0.837 17.1 -1.025e-16; 4142 -0.824284 17.1 0.145344;4143 -0.786523 17.1 0.286271; 4144 -0.724863 17.1 0.4185;4145 -0.641179 17.1 0.538013; 4146 -0.538013 17.1 0.641179;4147 -0.4185 17.1 0.724863; 4148 -0.286271 17.1 0.786523;4149 -0.145344 17.1 0.824284; 4150 -1.53749e-16 17.1 0.837;4151 0.145344 17.1 0.824284; 4152 0.286271 17.1 0.786523;4153 0.4185 17.1 0.724863; 4154 0.538013 17.1 0.641179;4155 0.641179 17.1 0.538013; 4156 0.724863 17.1 0.4185;4157 0.786523 17.1 0.286271; 4158 0.824284 17.1 0.145344; 4159 0.837 17.25 0;4160 0.824284 17.25 -0.145344; 4161 0.786523 17.25 -0.286271;4162 0.724863 17.25 -0.4185; 4163 0.641179 17.25 -0.538013;4164 0.538013 17.25 -0.641179; 4165 0.4185 17.25 -0.724863;4166 0.286271 17.25 -0.786523; 4167 0.145344 17.25 -0.824284;4168 5.12498e-17 17.25 -0.837; 4169 -0.145344 17.25 -0.824284;4170 -0.286271 17.25 -0.786523; 4171 -0.4185 17.25 -0.724863;4172 -0.538013 17.25 -0.641179; 4173 -0.641179 17.25 -0.538013;4174 -0.724863 17.25 -0.4185; 4175 -0.786523 17.25 -0.286271;4176 -0.824284 17.25 -0.145344; 4177 -0.837 17.25 -1.025e-16;4178 -0.824284 17.25 0.145344; 4179 -0.786523 17.25 0.286271;4180 -0.724863 17.25 0.4185; 4181 -0.641179 17.25 0.538013;4182 -0.538013 17.25 0.641179; 4183 -0.4185 17.25 0.724863;4184 -0.286271 17.25 0.786523; 4185 -0.145344 17.25 0.824284;4186 -1.53749e-16 17.25 0.837; 4187 0.145344 17.25 0.824284;4188 0.286271 17.25 0.786523; 4189 0.4185 17.25 0.724863;4190 0.538013 17.25 0.641179; 4191 0.641179 17.25 0.538013;4192 0.724863 17.25 0.4185; 4193 0.786523 17.25 0.286271;4194 0.824284 17.25 0.145344;ELEMENT INCIDENCES SHELL73 28 65 66 29; 74 29 66 67 30; 75 30 67 68 31; 76 31 68 69 32; 77 32 69 70 33;78 33 70 71 34; 79 34 71 72 35; 80 35 72 73 36; 81 36 73 74 37; 82 37 74 39 2;83 2 39 40 3; 84 3 40 41 4; 85 4 41 42 5; 86 5 42 43 6; 87 6 43 44 7;88 7 44 45 8; 89 8 45 46 9; 90 9 46 47 10; 91 10 47 48 11; 92 11 48 49 12;93 12 49 50 13; 94 13 50 51 14; 95 14 51 52 15; 96 15 52 53 16; 97 16 53 54 17;98 17 54 55 18; 99 18 55 56 19; 100 19 56 57 20; 101 20 57 58 21;102 21 58 59 22; 103 22 59 60 23; 104 23 60 61 24; 105 24 61 62 25;106 25 62 63 26; 107 26 63 64 27; 108 27 64 65 28; 145 65 102 103 66;146 66 103 104 67; 147 67 104 105 68; 148 68 105 106 69; 149 69 106 107 70;150 70 107 108 71; 151 71 108 109 72; 152 72 109 110 73; 153 73 110 111 74;154 74 111 76 39; 155 39 76 77 40; 156 40 77 78 41; 157 41 78 79 42;158 42 79 80 43; 159 43 80 81 44; 160 44 81 82 45; 161 45 82 83 46;162 46 83 84 47; 163 47 84 85 48; 164 48 85 86 49; 165 49 86 87 50;166 50 87 88 51; 167 51 88 89 52; 168 52 89 90 53; 169 53 90 91 54;170 54 91 92 55; 171 55 92 93 56; 172 56 93 94 57; 173 57 94 95 58;174 58 95 96 59; 175 59 96 97 60; 176 60 97 98 61; 177 61 98 99 62;178 62 99 100 63; 179 63 100 101 64; 180 64 101 102 65; 253 102 139 140 103;254 103 140 141 104; 255 104 141 142 105; 256 105 142 143 106;257 106 143 144 107; 258 107 144 145 108; 259 108 145 146 109;260 109 146 147 110; 261 110 147 148 111; 262 111 148 113 76;263 76 113 114 77; 264 77 114 115 78; 265 78 115 116 79; 266 79 116 117 80;267 80 117 118 81; 268 81 118 119 82; 269 82 119 120 83; 270 83 120 121 84;271 84 121 122 85; 272 85 122 123 86; 273 86 123 124 87; 274 87 124 125 88;275 88 125 126 89; 276 89 126 127 90; 277 90 127 128 91; 278 91 128 129 92;279 92 129 130 93; 280 93 130 131 94; 281 94 131 132 95; 282 95 132 133 96;283 96 133 134 97; 284 97 134 135 98; 285 98 135 136 99; 286 99 136 137 100;287 100 137 138 101; 288 101 138 139 102; 361 139 176 177 140;362 140 177 178 141; 363 141 178 179 142; 364 142 179 180 143;365 143 180 181 144; 366 144 181 182 145; 367 145 182 183 146;368 146 183 184 147; 369 147 184 185 148; 370 148 185 150 113;371 113 150 151 114; 372 114 151 152 115; 373 115 152 153 116;374 116 153 154 117; 375 117 154 155 118; 376 118 155 156 119;377 119 156 157 120; 378 120 157 158 121; 379 121 158 159 122;380 122 159 160 123; 381 123 160 161 124; 382 124 161 162 125;383 125 162 163 126; 384 126 163 164 127; 385 127 164 165 128;386 128 165 166 129; 387 129 166 167 130; 388 130 167 168 131;389 131 168 169 132; 390 132 169 170 133; 391 133 170 171 134;392 134 171 172 135; 393 135 172 173 136; 394 136 173 174 137;395 137 174 175 138; 396 138 175 176 139; 469 176 213 214 177;470 177 214 215 178; 471 178 215 216 179; 472 179 216 217 180;473 180 217 218 181; 474 181 218 219 182; 475 182 219 220 183;476 183 220 221 184; 477 184 221 222 185; 478 185 222 187 150;479 150 187 188 151; 480 151 188 189 152; 481 152 189 190 153;482 153 190 191 154; 483 154 191 192 155; 484 155 192 193 156;485 156 193 194 157; 486 157 194 195 158; 487 158 195 196 159;488 159 196 197 160; 489 160 197 198 161; 490 161 198 199 162;491 162 199 200 163; 492 163 200 201 164; 493 164 201 202 165;494 165 202 203 166; 495 166 203 204 167; 496 167 204 205 168;497 168 205 206 169; 498 169 206 207 170; 499 170 207 208 171;500 171 208 209 172; 501 172 209 210 173; 502 173 210 211 174;503 174 211 212 175; 504 175 212 213 176; 577 213 250 251 214;578 214 251 252 215; 579 215 252 253 216; 580 216 253 254 217;581 217 254 255 218; 582 218 255 256 219; 583 219 256 257 220;584 220 257 258 221; 585 221 258 259 222; 586 222 259 224 187;587 187 224 225 188; 588 188 225 226 189; 589 189 226 227 190;590 190 227 228 191; 591 191 228 229 192; 592 192 229 230 193;593 193 230 231 194; 594 194 231 232 195; 595 195 232 233 196;596 196 233 234 197; 597 197 234 235 198; 598 198 235 236 199;599 199 236 237 200; 600 200 237 238 201; 601 201 238 239 202;602 202 239 240 203; 603 203 240 241 204; 604 204 241 242 205;605 205 242 243 206; 606 206 243 244 207; 607 207 244 245 208;608 208 245 246 209; 609 209 246 247 210; 610 210 247 248 211;611 211 248 249 212; 612 212 249 250 213; 685 250 287 288 251;686 251 288 289 252; 687 252 289 290 253; 688 253 290 291 254;689 254 291 292 255; 690 255 292 293 256; 691 256 293 294 257;692 257 294 295 258; 693 258 295 296 259; 694 259 296 261 224;695 224 261 262 225; 696 225 262 263 226; 697 226 263 264 227;698 227 264 265 228; 699 228 265 266 229; 700 229 266 267 230;701 230 267 268 231; 702 231 268 269 232; 703 232 269 270 233;704 233 270 271 234; 705 234 271 272 235; 706 235 272 273 236;707 236 273 274 237; 708 237 274 275 238; 709 238 275 276 239;710 239 276 277 240; 711 240 277 278 241; 712 241 278 279 242;713 242 279 280 243; 714 243 280 281 244; 715 244 281 282 245;716 245 282 283 246; 717 246 283 284 247; 718 247 284 285 248;719 248 285 286 249; 720 249 286 287 250; 793 287 324 325 288;794 288 325 326 289; 795 289 326 327 290; 796 290 327 328 291;797 291 328 329 292; 798 292 329 330 293; 799 293 330 331 294;800 294 331 332 295; 801 295 332 333 296; 802 296 333 298 261;803 261 298 299 262; 804 262 299 300 263; 805 263 300 301 264;806 264 301 302 265; 807 265 302 303 266; 808 266 303 304 267;809 267 304 305 268; 810 268 305 306 269; 811 269 306 307 270;812 270 307 308 271; 813 271 308 309 272; 814 272 309 310 273;815 273 310 311 274; 816 274 311 312 275; 817 275 312 313 276;818 276 313 314 277; 819 277 314 315 278; 820 278 315 316 279;821 279 316 317 280; 822 280 317 318 281; 823 281 318 319 282;824 282 319 320 283; 825 283 320 321 284; 826 284 321 322 285;827 285 322 323 286; 828 286 323 324 287; 901 324 361 362 325;902 325 362 363 326; 903 326 363 364 327; 904 327 364 365 328;905 328 365 366 329; 906 329 366 367 330; 907 330 367 368 331;908 331 368 369 332; 909 332 369 370 333; 910 333 370 335 298;911 298 335 336 299; 912 299 336 337 300; 913 300 337 338 301;914 301 338 339 302; 915 302 339 340 303; 916 303 340 341 304;917 304 341 342 305; 918 305 342 343 306; 919 306 343 344 307;920 307 344 345 308; 921 308 345 346 309; 922 309 346 347 310;923 310 347 348 311; 924 311 348 349 312; 925 312 349 350 313;926 313 350 351 314; 927 314 351 352 315; 928 315 352 353 316;929 316 353 354 317; 930 317 354 355 318; 931 318 355 356 319;932 319 356 357 320; 933 320 357 358 321; 934 321 358 359 322;935 322 359 360 323; 936 323 360 361 324; 1009 361 398 399 362;1010 362 399 400 363; 1011 363 400 401 364; 1012 364 401 402 365;1013 365 402 403 366; 1014 366 403 404 367; 1015 367 404 405 368;1016 368 405 406 369; 1017 369 406 407 370; 1018 370 407 372 335;1019 335 372 373 336; 1020 336 373 374 337; 1021 337 374 375 338;1022 338 375 376 339; 1023 339 376 377 340; 1024 340 377 378 341;1025 341 378 379 342; 1026 342 379 380 343; 1027 343 380 381 344;1028 344 381 382 345; 1029 345 382 383 346; 1030 346 383 384 347;1031 347 384 385 348; 1032 348 385 386 349; 1033 349 386 387 350;1034 350 387 388 351; 1035 351 388 389 352; 1036 352 389 390 353;1037 353 390 391 354; 1038 354 391 392 355; 1039 355 392 393 356;1040 356 393 394 357; 1041 357 394 395 358; 1042 358 395 396 359;1043 359 396 397 360; 1044 360 397 398 361; 1117 398 435 436 399;1118 399 436 437 400; 1119 400 437 438 401; 1120 401 438 439 402;1121 402 439 440 403; 1122 403 440 441 404; 1123 404 441 442 405;1124 405 442 443 406; 1125 406 443 444 407; 1126 407 444 409 372;1127 372 409 410 373; 1128 373 410 411 374; 1129 374 411 412 375;1130 375 412 413 376; 1131 376 413 414 377; 1132 377 414 415 378;1133 378 415 416 379; 1134 379 416 417 380; 1135 380 417 418 381;1136 381 418 419 382; 1137 382 419 420 383; 1138 383 420 421 384;1139 384 421 422 385; 1140 385 422 423 386; 1141 386 423 424 387;1142 387 424 425 388; 1143 388 425 426 389; 1144 389 426 427 390;1145 390 427 428 391; 1146 391 428 429 392; 1147 392 429 430 393;1148 393 430 431 394; 1149 394 431 432 395; 1150 395 432 433 396;1151 396 433 434 397; 1152 397 434 435 398; 1225 435 472 473 436;1226 436 473 474 437; 1227 437 474 475 438; 1228 438 475 476 439;1229 439 476 477 440; 1230 440 477 478 441; 1231 441 478 479 442;1232 442 479 480 443; 1233 443 480 481 444; 1234 444 481 446 409;1235 409 446 447 410; 1236 410 447 448 411; 1237 411 448 449 412;1238 412 449 450 413; 1239 413 450 451 414; 1240 414 451 452 415;1241 415 452 453 416; 1242 416 453 454 417; 1243 417 454 455 418;1244 418 455 456 419; 1245 419 456 457 420; 1246 420 457 458 421;1247 421 458 459 422; 1248 422 459 460 423; 1249 423 460 461 424;1250 424 461 462 425; 1251 425 462 463 426; 1252 426 463 464 427;1253 427 464 465 428; 1254 428 465 466 429; 1255 429 466 467 430;1256 430 467 468 431; 1257 431 468 469 432; 1258 432 469 470 433;1259 433 470 471 434; 1260 434 471 472 435; 1333 472 509 510 473;1334 473 510 511 474; 1335 474 511 512 475; 1336 475 512 513 476;1337 476 513 514 477; 1338 477 514 515 478; 1339 478 515 516 479;1340 479 516 517 480; 1341 480 517 518 481; 1342 481 518 483 446;1343 446 483 484 447; 1344 447 484 485 448; 1345 448 485 486 449;1346 449 486 487 450; 1347 450 487 488 451; 1348 451 488 489 452;1349 452 489 490 453; 1350 453 490 491 454; 1351 454 491 492 455;1352 455 492 493 456; 1353 456 493 494 457; 1354 457 494 495 458;1355 458 495 496 459; 1356 459 496 497 460; 1357 460 497 498 461;1358 461 498 499 462; 1359 462 499 500 463; 1360 463 500 501 464;1361 464 501 502 465; 1362 465 502 503 466; 1363 466 503 504 467;1364 467 504 505 468; 1365 468 505 506 469; 1366 469 506 507 470;1367 470 507 508 471; 1368 471 508 509 472; 1441 509 546 547 510;1442 510 547 548 511; 1443 511 548 549 512; 1444 512 549 550 513;1445 513 550 551 514; 1446 514 551 552 515; 1447 515 552 553 516;1448 516 553 554 517; 1449 517 554 555 518; 1450 518 555 520 483;1451 483 520 521 484; 1452 484 521 522 485; 1453 485 522 523 486;1454 486 523 524 487; 1455 487 524 525 488; 1456 488 525 526 489;1457 489 526 527 490; 1458 490 527 528 491; 1459 491 528 529 492;1460 492 529 530 493; 1461 493 530 531 494; 1462 494 531 532 495;1463 495 532 533 496; 1464 496 533 534 497; 1465 497 534 535 498;1466 498 535 536 499; 1467 499 536 537 500; 1468 500 537 538 501;1469 501 538 539 502; 1470 502 539 540 503; 1471 503 540 541 504;1472 504 541 542 505; 1473 505 542 543 506; 1474 506 543 544 507;1475 507 544 545 508; 1476 508 545 546 509; 1549 546 583 584 547;1550 547 584 585 548; 1551 548 585 586 549; 1552 549 586 587 550;1553 550 587 588 551; 1554 551 588 589 552; 1555 552 589 590 553;1556 553 590 591 554; 1557 554 591 592 555; 1558 555 592 557 520;1559 520 557 558 521; 1560 521 558 559 522; 1561 522 559 560 523;1562 523 560 561 524; 1563 524 561 562 525; 1564 525 562 563 526;1565 526 563 564 527; 1566 527 564 565 528; 1567 528 565 566 529;1568 529 566 567 530; 1569 530 567 568 531; 1570 531 568 569 532;1571 532 569 570 533; 1572 533 570 571 534; 1573 534 571 572 535;1574 535 572 573 536; 1575 536 573 574 537; 1576 537 574 575 538;1577 538 575 576 539; 1578 539 576 577 540; 1579 540 577 578 541;1580 541 578 579 542; 1581 542 579 580 543; 1582 543 580 581 544;1583 544 581 582 545; 1584 545 582 583 546; 1657 583 620 621 584;1658 584 621 622 585; 1659 585 622 623 586; 1660 586 623 624 587;1661 587 624 625 588; 1662 588 625 626 589; 1663 589 626 627 590;1664 590 627 628 591; 1665 591 628 629 592; 1666 592 629 594 557;1667 557 594 595 558; 1668 558 595 596 559; 1669 559 596 597 560;1670 560 597 598 561; 1671 561 598 599 562; 1672 562 599 600 563;1673 563 600 601 564; 1674 564 601 602 565; 1675 565 602 603 566;1676 566 603 604 567; 1677 567 604 605 568; 1678 568 605 606 569;1679 569 606 607 570; 1680 570 607 608 571; 1681 571 608 609 572;1682 572 609 610 573; 1683 573 610 611 574; 1684 574 611 612 575;1685 575 612 613 576; 1686 576 613 614 577; 1687 577 614 615 578;1688 578 615 616 579; 1689 579 616 617 580; 1690 580 617 618 581;1691 581 618 619 582; 1692 582 619 620 583; 1765 620 657 658 621;1766 621 658 659 622; 1767 622 659 660 623; 1768 623 660 661 624;1769 624 661 662 625; 1770 625 662 663 626; 1771 626 663 664 627;1772 627 664 665 628; 1773 628 665 666 629; 1774 629 666 631 594;1775 594 631 632 595; 1776 595 632 633 596; 1777 596 633 634 597;1778 597 634 635 598; 1779 598 635 636 599; 1780 599 636 637 600;1781 600 637 638 601; 1782 601 638 639 602; 1783 602 639 640 603;1784 603 640 641 604; 1785 604 641 642 605; 1786 605 642 643 606;1787 606 643 644 607; 1788 607 644 645 608; 1789 608 645 646 609;1790 609 646 647 610; 1791 610 647 648 611; 1792 611 648 649 612;1793 612 649 650 613; 1794 613 650 651 614; 1795 614 651 652 615;1796 615 652 653 616; 1797 616 653 654 617; 1798 617 654 655 618;1799 618 655 656 619; 1800 619 656 657 620; 1801 657 693 694 658;1802 658 694 695 659; 1803 659 695 696 660; 1804 660 696 697 661;1805 661 697 698 662; 1806 662 698 699 663; 1807 663 699 700 664;1808 664 700 701 665; 1809 665 701 702 666; 1810 666 702 667 631;1811 631 667 668 632; 1812 632 668 669 633; 1813 633 669 670 634;1814 634 670 671 635; 1815 635 671 672 636; 1816 636 672 673 637;1817 637 673 674 638; 1818 638 674 675 639; 1819 639 675 676 640;1820 640 676 677 641; 1821 641 677 678 642; 1822 642 678 679 643;1823 643 679 680 644; 1824 644 680 681 645; 1825 645 681 682 646;1826 646 682 683 647; 1827 647 683 684 648; 1828 648 684 685 649;1829 649 685 686 650; 1830 650 686 687 651; 1831 651 687 688 652;1832 652 688 689 653; 1833 653 689 690 654; 1834 654 690 691 655;1835 655 691 692 656; 1836 656 692 693 657; 1837 693 729 730 694;1838 694 730 731 695; 1839 695 731 732 696; 1840 696 732 733 697;1841 697 733 734 698; 1842 698 734 735 699; 1843 699 735 736 700;1844 700 736 737 701; 1845 701 737 738 702; 1846 702 738 703 667;1847 667 703 704 668; 1848 668 704 705 669; 1849 669 705 706 670;1850 670 706 707 671; 1851 671 707 708 672; 1852 672 708 709 673;1853 673 709 710 674; 1854 674 710 711 675; 1855 675 711 712 676;1856 676 712 713 677; 1857 677 713 714 678; 1858 678 714 715 679;1859 679 715 716 680; 1860 680 716 717 681; 1861 681 717 718 682;1862 682 718 719 683; 1863 683 719 720 684; 1864 684 720 721 685;1865 685 721 722 686; 1866 686 722 723 687; 1867 687 723 724 688;1868 688 724 725 689; 1869 689 725 726 690; 1870 690 726 727 691;1871 691 727 728 692; 1872 692 728 729 693; 1873 729 765 766 730;1874 730 766 767 731; 1875 731 767 768 732; 1876 732 768 769 733;1877 733 769 770 734; 1878 734 770 771 735; 1879 735 771 772 736;1880 736 772 773 737; 1881 737 773 774 738; 1882 738 774 739 703;1883 703 739 740 704; 1884 704 740 741 705; 1885 705 741 742 706;1886 706 742 743 707; 1887 707 743 744 708; 1888 708 744 745 709;1889 709 745 746 710; 1890 710 746 747 711; 1891 711 747 748 712;1892 712 748 749 713; 1893 713 749 750 714; 1894 714 750 751 715;1895 715 751 752 716; 1896 716 752 753 717; 1897 717 753 754 718;1898 718 754 755 719; 1899 719 755 756 720; 1900 720 756 757 721;1901 721 757 758 722; 1902 722 758 759 723; 1903 723 759 760 724;1904 724 760 761 725; 1905 725 761 762 726; 1906 726 762 763 727;1907 727 763 764 728; 1908 728 764 765 729; 1909 765 801 802 766;1910 766 802 803 767; 1911 767 803 804 768; 1912 768 804 805 769;1913 769 805 806 770; 1914 770 806 807 771; 1915 771 807 808 772;1916 772 808 809 773; 1917 773 809 810 774; 1918 774 810 775 739;1919 739 775 776 740; 1920 740 776 777 741; 1921 741 777 778 742;1922 742 778 779 743; 1923 743 779 780 744; 1924 744 780 781 745;1925 745 781 782 746; 1926 746 782 783 747; 1927 747 783 784 748;1928 748 784 785 749; 1929 749 785 786 750; 1930 750 786 787 751;1931 751 787 788 752; 1932 752 788 789 753; 1933 753 789 790 754;1934 754 790 791 755; 1935 755 791 792 756; 1936 756 792 793 757;1937 757 793 794 758; 1938 758 794 795 759; 1939 759 795 796 760;1940 760 796 797 761; 1941 761 797 798 762; 1942 762 798 799 763;1943 763 799 800 764; 1944 764 800 801 765; 1945 801 837 838 802;1946 802 838 839 803; 1947 803 839 840 804; 1948 804 840 841 805;1949 805 841 842 806; 1950 806 842 843 807; 1951 807 843 844 808;1952 808 844 845 809; 1953 809 845 846 810; 1954 810 846 811 775;1955 775 811 812 776; 1956 776 812 813 777; 1957 777 813 814 778;1958 778 814 815 779; 1959 779 815 816 780; 1960 780 816 817 781;1961 781 817 818 782; 1962 782 818 819 783; 1963 783 819 820 784;1964 784 820 821 785; 1965 785 821 822 786; 1966 786 822 823 787;1967 787 823 824 788; 1968 788 824 825 789; 1969 789 825 826 790;1970 790 826 827 791; 1971 791 827 828 792; 1972 792 828 829 793;1973 793 829 830 794; 1974 794 830 831 795; 1975 795 831 832 796;1976 796 832 833 797; 1977 797 833 834 798; 1978 798 834 835 799;1979 799 835 836 800; 1980 800 836 837 801; 1981 837 873 874 838;1982 838 874 875 839; 1983 839 875 876 840; 1984 840 876 877 841;1985 841 877 878 842; 1986 842 878 879 843; 1987 843 879 880 844;1988 844 880 881 845; 1989 845 881 882 846; 1990 846 882 847 811;1991 811 847 848 812; 1992 812 848 849 813; 1993 813 849 850 814;1994 814 850 851 815; 1995 815 851 852 816; 1996 816 852 853 817;1997 817 853 854 818; 1998 818 854 855 819; 1999 819 855 856 820;2000 820 856 857 821; 2001 821 857 858 822; 2002 822 858 859 823;2003 823 859 860 824; 2004 824 860 861 825; 2005 825 861 862 826;2006 826 862 863 827; 2007 827 863 864 828; 2008 828 864 865 829;2009 829 865 866 830; 2010 830 866 867 831; 2011 831 867 868 832;2012 832 868 869 833; 2013 833 869 870 834; 2014 834 870 871 835;2015 835 871 872 836; 2016 836 872 873 837; 2017 873 909 910 874;2018 874 910 911 875; 2019 875 911 912 876; 2020 876 912 913 877;2021 877 913 914 878; 2022 878 914 915 879; 2023 879 915 916 880;2024 880 916 917 881; 2025 881 917 918 882; 2026 882 918 883 847;2027 847 883 884 848; 2028 848 884 885 849; 2029 849 885 886 850;2030 850 886 887 851; 2031 851 887 888 852; 2032 852 888 889 853;2033 853 889 890 854; 2034 854 890 891 855; 2035 855 891 892 856;2036 856 892 893 857; 2037 857 893 894 858; 2038 858 894 895 859;2039 859 895 896 860; 2040 860 896 897 861; 2041 861 897 898 862;2042 862 898 899 863; 2043 863 899 900 864; 2044 864 900 901 865;2045 865 901 902 866; 2046 866 902 903 867; 2047 867 903 904 868;2048 868 904 905 869; 2049 869 905 906 870; 2050 870 906 907 871;2051 871 907 908 872; 2052 872 908 909 873; 2053 909 945 946 910;2054 910 946 947 911; 2055 911 947 948 912; 2056 912 948 949 913;2057 913 949 950 914; 2058 914 950 951 915; 2059 915 951 952 916;2060 916 952 953 917; 2061 917 953 954 918; 2062 918 954 919 883;2063 883 919 920 884; 2064 884 920 921 885; 2065 885 921 922 886;2066 886 922 923 887; 2067 887 923 924 888; 2068 888 924 925 889;2069 889 925 926 890; 2070 890 926 927 891; 2071 891 927 928 892;2072 892 928 929 893; 2073 893 929 930 894; 2074 894 930 931 895;2075 895 931 932 896; 2076 896 932 933 897; 2077 897 933 934 898;2078 898 934 935 899; 2079 899 935 936 900; 2080 900 936 937 901;2081 901 937 938 902; 2082 902 938 939 903; 2083 903 939 940 904;2084 904 940 941 905; 2085 905 941 942 906; 2086 906 942 943 907;2087 907 943 944 908; 2088 908 944 945 909; 2089 945 981 982 946;2090 946 982 983 947; 2091 947 983 984 948; 2092 948 984 985 949;2093 949 985 986 950; 2094 950 986 987 951; 2095 951 987 988 952;2096 952 988 989 953; 2097 953 989 990 954; 2098 954 990 955 919;2099 919 955 956 920; 2100 920 956 957 921; 2101 921 957 958 922;2102 922 958 959 923; 2103 923 959 960 924; 2104 924 960 961 925;2105 925 961 962 926; 2106 926 962 963 927; 2107 927 963 964 928;2108 928 964 965 929; 2109 929 965 966 930; 2110 930 966 967 931;2111 931 967 968 932; 2112 932 968 969 933; 2113 933 969 970 934;2114 934 970 971 935; 2115 935 971 972 936; 2116 936 972 973 937;2117 937 973 974 938; 2118 938 974 975 939; 2119 939 975 976 940;2120 940 976 977 941; 2121 941 977 978 942; 2122 942 978 979 943;2123 943 979 980 944; 2124 944 980 981 945; 2125 981 1017 1018 982;2126 982 1018 1019 983; 2127 983 1019 1020 984; 2128 984 1020 1021 985;2129 985 1021 1022 986; 2130 986 1022 1023 987; 2131 987 1023 1024 988;2132 988 1024 1025 989; 2133 989 1025 1026 990; 2134 990 1026 991 955;2135 955 991 992 956; 2136 956 992 993 957; 2137 957 993 994 958;2138 958 994 995 959; 2139 959 995 996 960; 2140 960 996 997 961;2141 961 997 998 962; 2142 962 998 999 963; 2143 963 999 1000 964;2144 964 1000 1001 965; 2145 965 1001 1002 966; 2146 966 1002 1003 967;2147 967 1003 1004 968; 2148 968 1004 1005 969; 2149 969 1005 1006 970;2150 970 1006 1007 971; 2151 971 1007 1008 972; 2152 972 1008 1009 973;2153 973 1009 1010 974; 2154 974 1010 1011 975; 2155 975 1011 1012 976;2156 976 1012 1013 977; 2157 977 1013 1014 978; 2158 978 1014 1015 979;2159 979 1015 1016 980; 2160 980 1016 1017 981; 2161 1017 1053 1054 1018;2162 1018 1054 1055 1019; 2163 1019 1055 1056 1020; 2164 1020 1056 1057 1021;2165 1021 1057 1058 1022; 2166 1022 1058 1059 1023; 2167 1023 1059 1060 1024;2168 1024 1060 1061 1025; 2169 1025 1061 1062 1026; 2170 1026 1062 1027 991;2171 991 1027 1028 992; 2172 992 1028 1029 993; 2173 993 1029 1030 994;2174 994 1030 1031 995; 2175 995 1031 1032 996; 2176 996 1032 1033 997;2177 997 1033 1034 998; 2178 998 1034 1035 999; 2179 999 1035 1036 1000;2180 1000 1036 1037 1001; 2181 1001 1037 1038 1002; 2182 1002 1038 1039 1003;2183 1003 1039 1040 1004; 2184 1004 1040 1041 1005; 2185 1005 1041 1042 1006;2186 1006 1042 1043 1007; 2187 1007 1043 1044 1008; 2188 1008 1044 1045 1009;2189 1009 1045 1046 1010; 2190 1010 1046 1047 1011; 2191 1011 1047 1048 1012;2192 1012 1048 1049 1013; 2193 1013 1049 1050 1014; 2194 1014 1050 1051 1015;2195 1015 1051 1052 1016; 2196 1016 1052 1053 1017; 2197 1053 1089 1090 1054;2198 1054 1090 1091 1055; 2199 1055 1091 1092 1056; 2200 1056 1092 1093 1057;2201 1057 1093 1094 1058; 2202 1058 1094 1095 1059; 2203 1059 1095 1096 1060;2204 1060 1096 1097 1061; 2205 1061 1097 1098 1062; 2206 1062 1098 1063 1027;2207 1027 1063 1064 1028; 2208 1028 1064 1065 1029; 2209 1029 1065 1066 1030;2210 1030 1066 1067 1031; 2211 1031 1067 1068 1032; 2212 1032 1068 1069 1033;2213 1033 1069 1070 1034; 2214 1034 1070 1071 1035; 2215 1035 1071 1072 1036;2216 1036 1072 1073 1037; 2217 1037 1073 1074 1038; 2218 1038 1074 1075 1039;2219 1039 1075 1076 1040; 2220 1040 1076 1077 1041; 2221 1041 1077 1078 1042;2222 1042 1078 1079 1043; 2223 1043 1079 1080 1044; 2224 1044 1080 1081 1045;2225 1045 1081 1082 1046; 2226 1046 1082 1083 1047; 2227 1047 1083 1084 1048;2228 1048 1084 1085 1049; 2229 1049 1085 1086 1050; 2230 1050 1086 1087 1051;2231 1051 1087 1088 1052; 2232 1052 1088 1089 1053; 2233 1089 1125 1126 1090;2234 1090 1126 1127 1091; 2235 1091 1127 1128 1092; 2236 1092 1128 1129 1093;2237 1093 1129 1130 1094; 2238 1094 1130 1131 1095; 2239 1095 1131 1132 1096;2240 1096 1132 1133 1097; 2241 1097 1133 1134 1098; 2242 1098 1134 1099 1063;2243 1063 1099 1100 1064; 2244 1064 1100 1101 1065; 2245 1065 1101 1102 1066;2246 1066 1102 1103 1067; 2247 1067 1103 1104 1068; 2248 1068 1104 1105 1069;2249 1069 1105 1106 1070; 2250 1070 1106 1107 1071; 2251 1071 1107 1108 1072;2252 1072 1108 1109 1073; 2253 1073 1109 1110 1074; 2254 1074 1110 1111 1075;2255 1075 1111 1112 1076; 2256 1076 1112 1113 1077; 2257 1077 1113 1114 1078;2258 1078 1114 1115 1079; 2259 1079 1115 1116 1080; 2260 1080 1116 1117 1081;2261 1081 1117 1118 1082; 2262 1082 1118 1119 1083; 2263 1083 1119 1120 1084;2264 1084 1120 1121 1085; 2265 1085 1121 1122 1086; 2266 1086 1122 1123 1087;2267 1087 1123 1124 1088; 2268 1088 1124 1125 1089; 2269 1125 1161 1162 1126;2270 1126 1162 1163 1127; 2271 1127 1163 1164 1128; 2272 1128 1164 1165 1129;2273 1129 1165 1166 1130; 2274 1130 1166 1167 1131; 2275 1131 1167 1168 1132;2276 1132 1168 1169 1133; 2277 1133 1169 1170 1134; 2278 1134 1170 1135 1099;2279 1099 1135 1136 1100; 2280 1100 1136 1137 1101; 2281 1101 1137 1138 1102;2282 1102 1138 1139 1103; 2283 1103 1139 1140 1104; 2284 1104 1140 1141 1105;2285 1105 1141 1142 1106; 2286 1106 1142 1143 1107; 2287 1107 1143 1144 1108;2288 1108 1144 1145 1109; 2289 1109 1145 1146 1110; 2290 1110 1146 1147 1111;2291 1111 1147 1148 1112; 2292 1112 1148 1149 1113; 2293 1113 1149 1150 1114;2294 1114 1150 1151 1115; 2295 1115 1151 1152 1116; 2296 1116 1152 1153 1117;2297 1117 1153 1154 1118; 2298 1118 1154 1155 1119; 2299 1119 1155 1156 1120;2300 1120 1156 1157 1121; 2301 1121 1157 1158 1122; 2302 1122 1158 1159 1123;2303 1123 1159 1160 1124; 2304 1124 1160 1161 1125; 2305 1161 1197 1198 1162;2306 1162 1198 1199 1163; 2307 1163 1199 1200 1164; 2308 1164 1200 1201 1165;2309 1165 1201 1202 1166; 2310 1166 1202 1203 1167; 2311 1167 1203 1204 1168;2312 1168 1204 1205 1169; 2313 1169 1205 1206 1170; 2314 1170 1206 1171 1135;2315 1135 1171 1172 1136; 2316 1136 1172 1173 1137; 2317 1137 1173 1174 1138;2318 1138 1174 1175 1139; 2319 1139 1175 1176 1140; 2320 1140 1176 1177 1141;2321 1141 1177 1178 1142; 2322 1142 1178 1179 1143; 2323 1143 1179 1180 1144;2324 1144 1180 1181 1145; 2325 1145 1181 1182 1146; 2326 1146 1182 1183 1147;2327 1147 1183 1184 1148; 2328 1148 1184 1185 1149; 2329 1149 1185 1186 1150;2330 1150 1186 1187 1151; 2331 1151 1187 1188 1152; 2332 1152 1188 1189 1153;2333 1153 1189 1190 1154; 2334 1154 1190 1191 1155; 2335 1155 1191 1192 1156;2336 1156 1192 1193 1157; 2337 1157 1193 1194 1158; 2338 1158 1194 1195 1159;2339 1159 1195 1196 1160; 2340 1160 1196 1197 1161; 2341 1197 1233 1234 1198;2342 1198 1234 1235 1199; 2343 1199 1235 1236 1200; 2344 1200 1236 1237 1201;2345 1201 1237 1238 1202; 2346 1202 1238 1239 1203; 2347 1203 1239 1240 1204;2348 1204 1240 1241 1205; 2349 1205 1241 1242 1206; 2350 1206 1242 1207 1171;2351 1171 1207 1208 1172; 2352 1172 1208 1209 1173; 2353 1173 1209 1210 1174;2354 1174 1210 1211 1175; 2355 1175 1211 1212 1176; 2356 1176 1212 1213 1177;2357 1177 1213 1214 1178; 2358 1178 1214 1215 1179; 2359 1179 1215 1216 1180;2360 1180 1216 1217 1181; 2361 1181 1217 1218 1182; 2362 1182 1218 1219 1183;2363 1183 1219 1220 1184; 2364 1184 1220 1221 1185; 2365 1185 1221 1222 1186;2366 1186 1222 1223 1187; 2367 1187 1223 1224 1188; 2368 1188 1224 1225 1189;2369 1189 1225 1226 1190; 2370 1190 1226 1227 1191; 2371 1191 1227 1228 1192;2372 1192 1228 1229 1193; 2373 1193 1229 1230 1194; 2374 1194 1230 1231 1195;2375 1195 1231 1232 1196; 2376 1196 1232 1233 1197; 2377 1233 1269 1270 1234;2378 1234 1270 1271 1235; 2379 1235 1271 1272 1236; 2380 1236 1272 1273 1237;2381 1237 1273 1274 1238; 2382 1238 1274 1275 1239; 2383 1239 1275 1276 1240;2384 1240 1276 1277 1241; 2385 1241 1277 1278 1242; 2386 1242 1278 1243 1207;2387 1207 1243 1244 1208; 2388 1208 1244 1245 1209; 2389 1209 1245 1246 1210;2390 1210 1246 1247 1211; 2391 1211 1247 1248 1212; 2392 1212 1248 1249 1213;2393 1213 1249 1250 1214; 2394 1214 1250 1251 1215; 2395 1215 1251 1252 1216;2396 1216 1252 1253 1217; 2397 1217 1253 1254 1218; 2398 1218 1254 1255 1219;2399 1219 1255 1256 1220; 2400 1220 1256 1257 1221; 2401 1221 1257 1258 1222;2402 1222 1258 1259 1223; 2403 1223 1259 1260 1224; 2404 1224 1260 1261 1225;2405 1225 1261 1262 1226; 2406 1226 1262 1263 1227; 2407 1227 1263 1264 1228;2408 1228 1264 1265 1229; 2409 1229 1265 1266 1230; 2410 1230 1266 1267 1231;2411 1231 1267 1268 1232; 2412 1232 1268 1269 1233; 2413 1269 1305 1306 1270;2414 1270 1306 1307 1271; 2415 1271 1307 1308 1272; 2416 1272 1308 1309 1273;2417 1273 1309 1310 1274; 2418 1274 1310 1311 1275; 2419 1275 1311 1312 1276;2420 1276 1312 1313 1277; 2421 1277 1313 1314 1278; 2422 1278 1314 1279 1243;2423 1243 1279 1280 1244; 2424 1244 1280 1281 1245; 2425 1245 1281 1282 1246;2426 1246 1282 1283 1247; 2427 1247 1283 1284 1248; 2428 1248 1284 1285 1249;2429 1249 1285 1286 1250; 2430 1250 1286 1287 1251; 2431 1251 1287 1288 1252;2432 1252 1288 1289 1253; 2433 1253 1289 1290 1254; 2434 1254 1290 1291 1255;2435 1255 1291 1292 1256; 2436 1256 1292 1293 1257; 2437 1257 1293 1294 1258;2438 1258 1294 1295 1259; 2439 1259 1295 1296 1260; 2440 1260 1296 1297 1261;2441 1261 1297 1298 1262; 2442 1262 1298 1299 1263; 2443 1263 1299 1300 1264;2444 1264 1300 1301 1265; 2445 1265 1301 1302 1266; 2446 1266 1302 1303 1267;2447 1267 1303 1304 1268; 2448 1268 1304 1305 1269; 2449 1305 1341 1342 1306;2450 1306 1342 1343 1307; 2451 1307 1343 1344 1308; 2452 1308 1344 1345 1309;2453 1309 1345 1346 1310; 2454 1310 1346 1347 1311; 2455 1311 1347 1348 1312;2456 1312 1348 1349 1313; 2457 1313 1349 1350 1314; 2458 1314 1350 1315 1279;2459 1279 1315 1316 1280; 2460 1280 1316 1317 1281; 2461 1281 1317 1318 1282;2462 1282 1318 1319 1283; 2463 1283 1319 1320 1284; 2464 1284 1320 1321 1285;2465 1285 1321 1322 1286; 2466 1286 1322 1323 1287; 2467 1287 1323 1324 1288;2468 1288 1324 1325 1289; 2469 1289 1325 1326 1290; 2470 1290 1326 1327 1291;2471 1291 1327 1328 1292; 2472 1292 1328 1329 1293; 2473 1293 1329 1330 1294;2474 1294 1330 1331 1295; 2475 1295 1331 1332 1296; 2476 1296 1332 1333 1297;2477 1297 1333 1334 1298; 2478 1298 1334 1335 1299; 2479 1299 1335 1336 1300;2480 1300 1336 1337 1301; 2481 1301 1337 1338 1302; 2482 1302 1338 1339 1303;2483 1303 1339 1340 1304; 2484 1304 1340 1341 1305; 2485 1341 1377 1378 1342;2486 1342 1378 1379 1343; 2487 1343 1379 1380 1344; 2488 1344 1380 1381 1345;2489 1345 1381 1382 1346; 2490 1346 1382 1383 1347; 2491 1347 1383 1384 1348;2492 1348 1384 1385 1349; 2493 1349 1385 1386 1350; 2494 1350 1386 1351 1315;2495 1315 1351 1352 1316; 2496 1316 1352 1353 1317; 2497 1317 1353 1354 1318;2498 1318 1354 1355 1319; 2499 1319 1355 1356 1320; 2500 1320 1356 1357 1321;2501 1321 1357 1358 1322; 2502 1322 1358 1359 1323; 2503 1323 1359 1360 1324;2504 1324 1360 1361 1325; 2505 1325 1361 1362 1326; 2506 1326 1362 1363 1327;2507 1327 1363 1364 1328; 2508 1328 1364 1365 1329; 2509 1329 1365 1366 1330;2510 1330 1366 1367 1331; 2511 1331 1367 1368 1332; 2512 1332 1368 1369 1333;2513 1333 1369 1370 1334; 2514 1334 1370 1371 1335; 2515 1335 1371 1372 1336;2516 1336 1372 1373 1337; 2517 1337 1373 1374 1338; 2518 1338 1374 1375 1339;2519 1339 1375 1376 1340; 2520 1340 1376 1377 1341; 2521 1377 1413 1414 1378;2522 1378 1414 1415 1379; 2523 1379 1415 1416 1380; 2524 1380 1416 1417 1381;2525 1381 1417 1418 1382; 2526 1382 1418 1419 1383; 2527 1383 1419 1420 1384;2528 1384 1420 1421 1385; 2529 1385 1421 1422 1386; 2530 1386 1422 1387 1351;2531 1351 1387 1388 1352; 2532 1352 1388 1389 1353; 2533 1353 1389 1390 1354;2534 1354 1390 1391 1355; 2535 1355 1391 1392 1356; 2536 1356 1392 1393 1357;2537 1357 1393 1394 1358; 2538 1358 1394 1395 1359; 2539 1359 1395 1396 1360;2540 1360 1396 1397 1361; 2541 1361 1397 1398 1362; 2542 1362 1398 1399 1363;2543 1363 1399 1400 1364; 2544 1364 1400 1401 1365; 2545 1365 1401 1402 1366;2546 1366 1402 1403 1367; 2547 1367 1403 1404 1368; 2548 1368 1404 1405 1369;2549 1369 1405 1406 1370; 2550 1370 1406 1407 1371; 2551 1371 1407 1408 1372;2552 1372 1408 1409 1373; 2553 1373 1409 1410 1374; 2554 1374 1410 1411 1375;2555 1375 1411 1412 1376; 2556 1376 1412 1413 1377; 2557 1413 1449 1450 1414;2558 1414 1450 1451 1415; 2559 1415 1451 1452 1416; 2560 1416 1452 1453 1417;2561 1417 1453 1454 1418; 2562 1418 1454 1455 1419; 2563 1419 1455 1456 1420;2564 1420 1456 1457 1421; 2565 1421 1457 1458 1422; 2566 1422 1458 1423 1387;2567 1387 1423 1424 1388; 2568 1388 1424 1425 1389; 2569 1389 1425 1426 1390;2570 1390 1426 1427 1391; 2571 1391 1427 1428 1392; 2572 1392 1428 1429 1393;2573 1393 1429 1430 1394; 2574 1394 1430 1431 1395; 2575 1395 1431 1432 1396;2576 1396 1432 1433 1397; 2577 1397 1433 1434 1398; 2578 1398 1434 1435 1399;2579 1399 1435 1436 1400; 2580 1400 1436 1437 1401; 2581 1401 1437 1438 1402;2582 1402 1438 1439 1403; 2583 1403 1439 1440 1404; 2584 1404 1440 1441 1405;2585 1405 1441 1442 1406; 2586 1406 1442 1443 1407; 2587 1407 1443 1444 1408;2588 1408 1444 1445 1409; 2589 1409 1445 1446 1410; 2590 1410 1446 1447 1411;2591 1411 1447 1448 1412; 2592 1412 1448 1449 1413; 2593 1449 1485 1486 1450;2594 1450 1486 1487 1451; 2595 1451 1487 1488 1452; 2596 1452 1488 1489 1453;2597 1453 1489 1490 1454; 2598 1454 1490 1491 1455; 2599 1455 1491 1492 1456;2600 1456 1492 1493 1457; 2601 1457 1493 1494 1458; 2602 1458 1494 1459 1423;2603 1423 1459 1460 1424; 2604 1424 1460 1461 1425; 2605 1425 1461 1462 1426;2606 1426 1462 1463 1427; 2607 1427 1463 1464 1428; 2608 1428 1464 1465 1429;2609 1429 1465 1466 1430; 2610 1430 1466 1467 1431; 2611 1431 1467 1468 1432;2612 1432 1468 1469 1433; 2613 1433 1469 1470 1434; 2614 1434 1470 1471 1435;2615 1435 1471 1472 1436; 2616 1436 1472 1473 1437; 2617 1437 1473 1474 1438;2618 1438 1474 1475 1439; 2619 1439 1475 1476 1440; 2620 1440 1476 1477 1441;2621 1441 1477 1478 1442; 2622 1442 1478 1479 1443; 2623 1443 1479 1480 1444;2624 1444 1480 1481 1445; 2625 1445 1481 1482 1446; 2626 1446 1482 1483 1447;2627 1447 1483 1484 1448; 2628 1448 1484 1485 1449; 2629 1485 1521 1522 1486;2630 1486 1522 1523 1487; 2631 1487 1523 1524 1488; 2632 1488 1524 1525 1489;2633 1489 1525 1526 1490; 2634 1490 1526 1527 1491; 2635 1491 1527 1528 1492;2636 1492 1528 1529 1493; 2637 1493 1529 1530 1494; 2638 1494 1530 1495 1459;2639 1459 1495 1496 1460; 2640 1460 1496 1497 1461; 2641 1461 1497 1498 1462;2642 1462 1498 1499 1463; 2643 1463 1499 1500 1464; 2644 1464 1500 1501 1465;2645 1465 1501 1502 1466; 2646 1466 1502 1503 1467; 2647 1467 1503 1504 1468;2648 1468 1504 1505 1469; 2649 1469 1505 1506 1470; 2650 1470 1506 1507 1471;2651 1471 1507 1508 1472; 2652 1472 1508 1509 1473; 2653 1473 1509 1510 1474;2654 1474 1510 1511 1475; 2655 1475 1511 1512 1476; 2656 1476 1512 1513 1477;2657 1477 1513 1514 1478; 2658 1478 1514 1515 1479; 2659 1479 1515 1516 1480;2660 1480 1516 1517 1481; 2661 1481 1517 1518 1482; 2662 1482 1518 1519 1483;2663 1483 1519 1520 1484; 2664 1484 1520 1521 1485; 2665 1521 1557 1558 1522;2666 1522 1558 1559 1523; 2667 1523 1559 1560 1524; 2668 1524 1560 1561 1525;2669 1525 1561 1562 1526; 2670 1526 1562 1563 1527; 2671 1527 1563 1564 1528;2672 1528 1564 1565 1529; 2673 1529 1565 1566 1530; 2674 1530 1566 1531 1495;2675 1495 1531 1532 1496; 2676 1496 1532 1533 1497; 2677 1497 1533 1534 1498;2678 1498 1534 1535 1499; 2679 1499 1535 1536 1500; 2680 1500 1536 1537 1501;2681 1501 1537 1538 1502; 2682 1502 1538 1539 1503; 2683 1503 1539 1540 1504;2684 1504 1540 1541 1505; 2685 1505 1541 1542 1506; 2686 1506 1542 1543 1507;2687 1507 1543 1544 1508; 2688 1508 1544 1545 1509; 2689 1509 1545 1546 1510;2690 1510 1546 1547 1511; 2691 1511 1547 1548 1512; 2692 1512 1548 1549 1513;2693 1513 1549 1550 1514; 2694 1514 1550 1551 1515; 2695 1515 1551 1552 1516;2696 1516 1552 1553 1517; 2697 1517 1553 1554 1518; 2698 1518 1554 1555 1519;2699 1519 1555 1556 1520; 2700 1520 1556 1557 1521; 2701 1557 1593 1594 1558;2702 1558 1594 1595 1559; 2703 1559 1595 1596 1560; 2704 1560 1596 1597 1561;2705 1561 1597 1598 1562; 2706 1562 1598 1599 1563; 2707 1563 1599 1600 1564;2708 1564 1600 1601 1565; 2709 1565 1601 1602 1566; 2710 1566 1602 1567 1531;2711 1531 1567 1568 1532; 2712 1532 1568 1569 1533; 2713 1533 1569 1570 1534;2714 1534 1570 1571 1535; 2715 1535 1571 1572 1536; 2716 1536 1572 1573 1537;2717 1537 1573 1574 1538; 2718 1538 1574 1575 1539; 2719 1539 1575 1576 1540;2720 1540 1576 1577 1541; 2721 1541 1577 1578 1542; 2722 1542 1578 1579 1543;2723 1543 1579 1580 1544; 2724 1544 1580 1581 1545; 2725 1545 1581 1582 1546;2726 1546 1582 1583 1547; 2727 1547 1583 1584 1548; 2728 1548 1584 1585 1549;2729 1549 1585 1586 1550; 2730 1550 1586 1587 1551; 2731 1551 1587 1588 1552;2732 1552 1588 1589 1553; 2733 1553 1589 1590 1554; 2734 1554 1590 1591 1555;2735 1555 1591 1592 1556; 2736 1556 1592 1593 1557; 2737 1593 1629 1630 1594;2738 1594 1630 1631 1595; 2739 1595 1631 1632 1596; 2740 1596 1632 1633 1597;2741 1597 1633 1634 1598; 2742 1598 1634 1635 1599; 2743 1599 1635 1636 1600;2744 1600 1636 1637 1601; 2745 1601 1637 1638 1602; 2746 1602 1638 1603 1567;2747 1567 1603 1604 1568; 2748 1568 1604 1605 1569; 2749 1569 1605 1606 1570;2750 1570 1606 1607 1571; 2751 1571 1607 1608 1572; 2752 1572 1608 1609 1573;2753 1573 1609 1610 1574; 2754 1574 1610 1611 1575; 2755 1575 1611 1612 1576;2756 1576 1612 1613 1577; 2757 1577 1613 1614 1578; 2758 1578 1614 1615 1579;2759 1579 1615 1616 1580; 2760 1580 1616 1617 1581; 2761 1581 1617 1618 1582;2762 1582 1618 1619 1583; 2763 1583 1619 1620 1584; 2764 1584 1620 1621 1585;2765 1585 1621 1622 1586; 2766 1586 1622 1623 1587; 2767 1587 1623 1624 1588;2768 1588 1624 1625 1589; 2769 1589 1625 1626 1590; 2770 1590 1626 1627 1591;2771 1591 1627 1628 1592; 2772 1592 1628 1629 1593; 2773 1629 1665 1666 1630;2774 1630 1666 1667 1631; 2775 1631 1667 1668 1632; 2776 1632 1668 1669 1633;2777 1633 1669 1670 1634; 2778 1634 1670 1671 1635; 2779 1635 1671 1672 1636;2780 1636 1672 1673 1637; 2781 1637 1673 1674 1638; 2782 1638 1674 1639 1603;2783 1603 1639 1640 1604; 2784 1604 1640 1641 1605; 2785 1605 1641 1642 1606;2786 1606 1642 1643 1607; 2787 1607 1643 1644 1608; 2788 1608 1644 1645 1609;2789 1609 1645 1646 1610; 2790 1610 1646 1647 1611; 2791 1611 1647 1648 1612;2792 1612 1648 1649 1613; 2793 1613 1649 1650 1614; 2794 1614 1650 1651 1615;2795 1615 1651 1652 1616; 2796 1616 1652 1653 1617; 2797 1617 1653 1654 1618;2798 1618 1654 1655 1619; 2799 1619 1655 1656 1620; 2800 1620 1656 1657 1621;2801 1621 1657 1658 1622; 2802 1622 1658 1659 1623; 2803 1623 1659 1660 1624;2804 1624 1660 1661 1625; 2805 1625 1661 1662 1626; 2806 1626 1662 1663 1627;2807 1627 1663 1664 1628; 2808 1628 1664 1665 1629; 2809 1665 1701 1702 1666;2810 1666 1702 1703 1667; 2811 1667 1703 1704 1668; 2812 1668 1704 1705 1669;2813 1669 1705 1706 1670; 2814 1670 1706 1707 1671; 2815 1671 1707 1708 1672;2816 1672 1708 1709 1673; 2817 1673 1709 1710 1674; 2818 1674 1710 1675 1639;2819 1639 1675 1676 1640; 2820 1640 1676 1677 1641; 2821 1641 1677 1678 1642;2822 1642 1678 1679 1643; 2823 1643 1679 1680 1644; 2824 1644 1680 1681 1645;2825 1645 1681 1682 1646; 2826 1646 1682 1683 1647; 2827 1647 1683 1684 1648;2828 1648 1684 1685 1649; 2829 1649 1685 1686 1650; 2830 1650 1686 1687 1651;2831 1651 1687 1688 1652; 2832 1652 1688 1689 1653; 2833 1653 1689 1690 1654;2834 1654 1690 1691 1655; 2835 1655 1691 1692 1656; 2836 1656 1692 1693 1657;2837 1657 1693 1694 1658; 2838 1658 1694 1695 1659; 2839 1659 1695 1696 1660;2840 1660 1696 1697 1661; 2841 1661 1697 1698 1662; 2842 1662 1698 1699 1663;2843 1663 1699 1700 1664; 2844 1664 1700 1701 1665; 2845 1701 1737 1738 1702;2846 1702 1738 1739 1703; 2847 1703 1739 1740 1704; 2848 1704 1740 1741 1705;2849 1705 1741 1742 1706; 2850 1706 1742 1743 1707; 2851 1707 1743 1744 1708;2852 1708 1744 1745 1709; 2853 1709 1745 1746 1710; 2854 1710 1746 1711 1675;2855 1675 1711 1712 1676; 2856 1676 1712 1713 1677; 2857 1677 1713 1714 1678;2858 1678 1714 1715 1679; 2859 1679 1715 1716 1680; 2860 1680 1716 1717 1681;2861 1681 1717 1718 1682; 2862 1682 1718 1719 1683; 2863 1683 1719 1720 1684;2864 1684 1720 1721 1685; 2865 1685 1721 1722 1686; 2866 1686 1722 1723 1687;2867 1687 1723 1724 1688; 2868 1688 1724 1725 1689; 2869 1689 1725 1726 1690;2870 1690 1726 1727 1691; 2871 1691 1727 1728 1692; 2872 1692 1728 1729 1693;2873 1693 1729 1730 1694; 2874 1694 1730 1731 1695; 2875 1695 1731 1732 1696;2876 1696 1732 1733 1697; 2877 1697 1733 1734 1698; 2878 1698 1734 1735 1699;2879 1699 1735 1736 1700; 2880 1700 1736 1737 1701; 2881 1737 1773 1774 1738;2882 1738 1774 1775 1739; 2883 1739 1775 1776 1740; 2884 1740 1776 1777 1741;2885 1741 1777 1778 1742; 2886 1742 1778 1779 1743; 2887 1743 1779 1780 1744;2888 1744 1780 1781 1745; 2889 1745 1781 1782 1746; 2890 1746 1782 1747 1711;2891 1711 1747 1748 1712; 2892 1712 1748 1749 1713; 2893 1713 1749 1750 1714;2894 1714 1750 1751 1715; 2895 1715 1751 1752 1716; 2896 1716 1752 1753 1717;2897 1717 1753 1754 1718; 2898 1718 1754 1755 1719; 2899 1719 1755 1756 1720;2900 1720 1756 1757 1721; 2901 1721 1757 1758 1722; 2902 1722 1758 1759 1723;2903 1723 1759 1760 1724; 2904 1724 1760 1761 1725; 2905 1725 1761 1762 1726;2906 1726 1762 1763 1727; 2907 1727 1763 1764 1728; 2908 1728 1764 1765 1729;2909 1729 1765 1766 1730; 2910 1730 1766 1767 1731; 2911 1731 1767 1768 1732;2912 1732 1768 1769 1733; 2913 1733 1769 1770 1734; 2914 1734 1770 1771 1735;2915 1735 1771 1772 1736; 2916 1736 1772 1773 1737; 2917 1773 1809 1810 1774;2918 1774 1810 1811 1775; 2919 1775 1811 1812 1776; 2920 1776 1812 1813 1777;2921 1777 1813 1814 1778; 2922 1778 1814 1815 1779; 2923 1779 1815 1816 1780;2924 1780 1816 1817 1781; 2925 1781 1817 1818 1782; 2926 1782 1818 1783 1747;2927 1747 1783 1784 1748; 2928 1748 1784 1785 1749; 2929 1749 1785 1786 1750;2930 1750 1786 1787 1751; 2931 1751 1787 1788 1752; 2932 1752 1788 1789 1753;2933 1753 1789 1790 1754; 2934 1754 1790 1791 1755; 2935 1755 1791 1792 1756;2936 1756 1792 1793 1757; 2937 1757 1793 1794 1758; 2938 1758 1794 1795 1759;2939 1759 1795 1796 1760; 2940 1760 1796 1797 1761; 2941 1761 1797 1798 1762;2942 1762 1798 1799 1763; 2943 1763 1799 1800 1764; 2944 1764 1800 1801 1765;2945 1765 1801 1802 1766; 2946 1766 1802 1803 1767; 2947 1767 1803 1804 1768;2948 1768 1804 1805 1769; 2949 1769 1805 1806 1770; 2950 1770 1806 1807 1771;2951 1771 1807 1808 1772; 2952 1772 1808 1809 1773; 2953 1809 1845 1846 1810;2954 1810 1846 1847 1811; 2955 1811 1847 1848 1812; 2956 1812 1848 1849 1813;2957 1813 1849 1850 1814; 2958 1814 1850 1851 1815; 2959 1815 1851 1852 1816;2960 1816 1852 1853 1817; 2961 1817 1853 1854 1818; 2962 1818 1854 1819 1783;2963 1783 1819 1820 1784; 2964 1784 1820 1821 1785; 2965 1785 1821 1822 1786;2966 1786 1822 1823 1787; 2967 1787 1823 1824 1788; 2968 1788 1824 1825 1789;2969 1789 1825 1826 1790; 2970 1790 1826 1827 1791; 2971 1791 1827 1828 1792;2972 1792 1828 1829 1793; 2973 1793 1829 1830 1794; 2974 1794 1830 1831 1795;2975 1795 1831 1832 1796; 2976 1796 1832 1833 1797; 2977 1797 1833 1834 1798;2978 1798 1834 1835 1799; 2979 1799 1835 1836 1800; 2980 1800 1836 1837 1801;2981 1801 1837 1838 1802; 2982 1802 1838 1839 1803; 2983 1803 1839 1840 1804;2984 1804 1840 1841 1805; 2985 1805 1841 1842 1806; 2986 1806 1842 1843 1807;2987 1807 1843 1844 1808; 2988 1808 1844 1845 1809; 2989 1845 1881 1882 1846;2990 1846 1882 1883 1847; 2991 1847 1883 1884 1848; 2992 1848 1884 1885 1849;2993 1849 1885 1886 1850; 2994 1850 1886 1887 1851; 2995 1851 1887 1888 1852;2996 1852 1888 1889 1853; 2997 1853 1889 1890 1854; 2998 1854 1890 1855 1819;2999 1819 1855 1856 1820; 3000 1820 1856 1857 1821; 3001 1821 1857 1858 1822;3002 1822 1858 1859 1823; 3003 1823 1859 1860 1824; 3004 1824 1860 1861 1825;3005 1825 1861 1862 1826; 3006 1826 1862 1863 1827; 3007 1827 1863 1864 1828;3008 1828 1864 1865 1829; 3009 1829 1865 1866 1830; 3010 1830 1866 1867 1831;3011 1831 1867 1868 1832; 3012 1832 1868 1869 1833; 3013 1833 1869 1870 1834;3014 1834 1870 1871 1835; 3015 1835 1871 1872 1836; 3016 1836 1872 1873 1837;3017 1837 1873 1874 1838; 3018 1838 1874 1875 1839; 3019 1839 1875 1876 1840;3020 1840 1876 1877 1841; 3021 1841 1877 1878 1842; 3022 1842 1878 1879 1843;3023 1843 1879 1880 1844; 3024 1844 1880 1881 1845; 3025 1881 1917 1918 1882;3026 1882 1918 1919 1883; 3027 1883 1919 1920 1884; 3028 1884 1920 1921 1885;3029 1885 1921 1922 1886; 3030 1886 1922 1923 1887; 3031 1887 1923 1924 1888;3032 1888 1924 1925 1889; 3033 1889 1925 1926 1890; 3034 1890 1926 1891 1855;3035 1855 1891 1892 1856; 3036 1856 1892 1893 1857; 3037 1857 1893 1894 1858;3038 1858 1894 1895 1859; 3039 1859 1895 1896 1860; 3040 1860 1896 1897 1861;3041 1861 1897 1898 1862; 3042 1862 1898 1899 1863; 3043 1863 1899 1900 1864;3044 1864 1900 1901 1865; 3045 1865 1901 1902 1866; 3046 1866 1902 1903 1867;3047 1867 1903 1904 1868; 3048 1868 1904 1905 1869; 3049 1869 1905 1906 1870;3050 1870 1906 1907 1871; 3051 1871 1907 1908 1872; 3052 1872 1908 1909 1873;3053 1873 1909 1910 1874; 3054 1874 1910 1911 1875; 3055 1875 1911 1912 1876;3056 1876 1912 1913 1877; 3057 1877 1913 1914 1878; 3058 1878 1914 1915 1879;3059 1879 1915 1916 1880; 3060 1880 1916 1917 1881; 3061 1917 1953 1954 1918;3062 1918 1954 1955 1919; 3063 1919 1955 1956 1920; 3064 1920 1956 1957 1921;3065 1921 1957 1958 1922; 3066 1922 1958 1959 1923; 3067 1923 1959 1960 1924;3068 1924 1960 1961 1925; 3069 1925 1961 1962 1926; 3070 1926 1962 1927 1891;3071 1891 1927 1928 1892; 3072 1892 1928 1929 1893; 3073 1893 1929 1930 1894;3074 1894 1930 1931 1895; 3075 1895 1931 1932 1896; 3076 1896 1932 1933 1897;3077 1897 1933 1934 1898; 3078 1898 1934 1935 1899; 3079 1899 1935 1936 1900;3080 1900 1936 1937 1901; 3081 1901 1937 1938 1902; 3082 1902 1938 1939 1903;3083 1903 1939 1940 1904; 3084 1904 1940 1941 1905; 3085 1905 1941 1942 1906;3086 1906 1942 1943 1907; 3087 1907 1943 1944 1908; 3088 1908 1944 1945 1909;3089 1909 1945 1946 1910; 3090 1910 1946 1947 1911; 3091 1911 1947 1948 1912;3092 1912 1948 1949 1913; 3093 1913 1949 1950 1914; 3094 1914 1950 1951 1915;3095 1915 1951 1952 1916; 3096 1916 1952 1953 1917; 3097 1953 1989 1990 1954;3098 1954 1990 1991 1955; 3099 1955 1991 1992 1956; 3100 1956 1992 1993 1957;3101 1957 1993 1994 1958; 3102 1958 1994 1995 1959; 3103 1959 1995 1996 1960;3104 1960 1996 1997 1961; 3105 1961 1997 1998 1962; 3106 1962 1998 1963 1927;3107 1927 1963 1964 1928; 3108 1928 1964 1965 1929; 3109 1929 1965 1966 1930;3110 1930 1966 1967 1931; 3111 1931 1967 1968 1932; 3112 1932 1968 1969 1933;3113 1933 1969 1970 1934; 3114 1934 1970 1971 1935; 3115 1935 1971 1972 1936;3116 1936 1972 1973 1937; 3117 1937 1973 1974 1938; 3118 1938 1974 1975 1939;3119 1939 1975 1976 1940; 3120 1940 1976 1977 1941; 3121 1941 1977 1978 1942;3122 1942 1978 1979 1943; 3123 1943 1979 1980 1944; 3124 1944 1980 1981 1945;3125 1945 1981 1982 1946; 3126 1946 1982 1983 1947; 3127 1947 1983 1984 1948;3128 1948 1984 1985 1949; 3129 1949 1985 1986 1950; 3130 1950 1986 1987 1951;3131 1951 1987 1988 1952; 3132 1952 1988 1989 1953; 3133 1989 2025 2026 1990;3134 1990 2026 2027 1991; 3135 1991 2027 2028 1992; 3136 1992 2028 2029 1993;3137 1993 2029 2030 1994; 3138 1994 2030 2031 1995; 3139 1995 2031 2032 1996;3140 1996 2032 2033 1997; 3141 1997 2033 2034 1998; 3142 1998 2034 1999 1963;3143 1963 1999 2000 1964; 3144 1964 2000 2001 1965; 3145 1965 2001 2002 1966;3146 1966 2002 2003 1967; 3147 1967 2003 2004 1968; 3148 1968 2004 2005 1969;3149 1969 2005 2006 1970; 3150 1970 2006 2007 1971; 3151 1971 2007 2008 1972;3152 1972 2008 2009 1973; 3153 1973 2009 2010 1974; 3154 1974 2010 2011 1975;3155 1975 2011 2012 1976; 3156 1976 2012 2013 1977; 3157 1977 2013 2014 1978;3158 1978 2014 2015 1979; 3159 1979 2015 2016 1980; 3160 1980 2016 2017 1981;3161 1981 2017 2018 1982; 3162 1982 2018 2019 1983; 3163 1983 2019 2020 1984;3164 1984 2020 2021 1985; 3165 1985 2021 2022 1986; 3166 1986 2022 2023 1987;3167 1987 2023 2024 1988; 3168 1988 2024 2025 1989; 3169 2025 2061 2062 2026;3170 2026 2062 2063 2027; 3171 2027 2063 2064 2028; 3172 2028 2064 2065 2029;3173 2029 2065 2066 2030; 3174 2030 2066 2067 2031; 3175 2031 2067 2068 2032;3176 2032 2068 2069 2033; 3177 2033 2069 2070 2034; 3178 2034 2070 2035 1999;3179 1999 2035 2036 2000; 3180 2000 2036 2037 2001; 3181 2001 2037 2038 2002;3182 2002 2038 2039 2003; 3183 2003 2039 2040 2004; 3184 2004 2040 2041 2005;3185 2005 2041 2042 2006; 3186 2006 2042 2043 2007; 3187 2007 2043 2044 2008;3188 2008 2044 2045 2009; 3189 2009 2045 2046 2010; 3190 2010 2046 2047 2011;3191 2011 2047 2048 2012; 3192 2012 2048 2049 2013; 3193 2013 2049 2050 2014;3194 2014 2050 2051 2015; 3195 2015 2051 2052 2016; 3196 2016 2052 2053 2017;3197 2017 2053 2054 2018; 3198 2018 2054 2055 2019; 3199 2019 2055 2056 2020;3200 2020 2056 2057 2021; 3201 2021 2057 2058 2022; 3202 2022 2058 2059 2023;3203 2023 2059 2060 2024; 3204 2024 2060 2061 2025; 3205 2061 2097 2098 2062;3206 2062 2098 2099 2063; 3207 2063 2099 2100 2064; 3208 2064 2100 2101 2065;3209 2065 2101 2102 2066; 3210 2066 2102 2103 2067; 3211 2067 2103 2104 2068;3212 2068 2104 2105 2069; 3213 2069 2105 2106 2070; 3214 2070 2106 2071 2035;3215 2035 2071 2072 2036; 3216 2036 2072 2073 2037; 3217 2037 2073 2074 2038;3218 2038 2074 2075 2039; 3219 2039 2075 2076 2040; 3220 2040 2076 2077 2041;3221 2041 2077 2078 2042; 3222 2042 2078 2079 2043; 3223 2043 2079 2080 2044;3224 2044 2080 2081 2045; 3225 2045 2081 2082 2046; 3226 2046 2082 2083 2047;3227 2047 2083 2084 2048; 3228 2048 2084 2085 2049; 3229 2049 2085 2086 2050;3230 2050 2086 2087 2051; 3231 2051 2087 2088 2052; 3232 2052 2088 2089 2053;3233 2053 2089 2090 2054; 3234 2054 2090 2091 2055; 3235 2055 2091 2092 2056;3236 2056 2092 2093 2057; 3237 2057 2093 2094 2058; 3238 2058 2094 2095 2059;3239 2059 2095 2096 2060; 3240 2060 2096 2097 2061; 3241 2097 2133 2134 2098;3242 2098 2134 2135 2099; 3243 2099 2135 2136 2100; 3244 2100 2136 2137 2101;3245 2101 2137 2138 2102; 3246 2102 2138 2139 2103; 3247 2103 2139 2140 2104;3248 2104 2140 2141 2105; 3249 2105 2141 2142 2106; 3250 2106 2142 2107 2071;3251 2071 2107 2108 2072; 3252 2072 2108 2109 2073; 3253 2073 2109 2110 2074;3254 2074 2110 2111 2075; 3255 2075 2111 2112 2076; 3256 2076 2112 2113 2077;3257 2077 2113 2114 2078; 3258 2078 2114 2115 2079; 3259 2079 2115 2116 2080;3260 2080 2116 2117 2081; 3261 2081 2117 2118 2082; 3262 2082 2118 2119 2083;3263 2083 2119 2120 2084; 3264 2084 2120 2121 2085; 3265 2085 2121 2122 2086;3266 2086 2122 2123 2087; 3267 2087 2123 2124 2088; 3268 2088 2124 2125 2089;3269 2089 2125 2126 2090; 3270 2090 2126 2127 2091; 3271 2091 2127 2128 2092;3272 2092 2128 2129 2093; 3273 2093 2129 2130 2094; 3274 2094 2130 2131 2095;3275 2095 2131 2132 2096; 3276 2096 2132 2133 2097; 3277 2133 2169 2170 2134;3278 2134 2170 2171 2135; 3279 2135 2171 2172 2136; 3280 2136 2172 2173 2137;3281 2137 2173 2174 2138; 3282 2138 2174 2175 2139; 3283 2139 2175 2176 2140;3284 2140 2176 2177 2141; 3285 2141 2177 2178 2142; 3286 2142 2178 2143 2107;3287 2107 2143 2144 2108; 3288 2108 2144 2145 2109; 3289 2109 2145 2146 2110;3290 2110 2146 2147 2111; 3291 2111 2147 2148 2112; 3292 2112 2148 2149 2113;3293 2113 2149 2150 2114; 3294 2114 2150 2151 2115; 3295 2115 2151 2152 2116;3296 2116 2152 2153 2117; 3297 2117 2153 2154 2118; 3298 2118 2154 2155 2119;3299 2119 2155 2156 2120; 3300 2120 2156 2157 2121; 3301 2121 2157 2158 2122;3302 2122 2158 2159 2123; 3303 2123 2159 2160 2124; 3304 2124 2160 2161 2125;3305 2125 2161 2162 2126; 3306 2126 2162 2163 2127; 3307 2127 2163 2164 2128;3308 2128 2164 2165 2129; 3309 2129 2165 2166 2130; 3310 2130 2166 2167 2131;3311 2131 2167 2168 2132; 3312 2132 2168 2169 2133; 3313 2169 2205 2206 2170;3314 2170 2206 2207 2171; 3315 2171 2207 2208 2172; 3316 2172 2208 2209 2173;3317 2173 2209 2210 2174; 3318 2174 2210 2211 2175; 3319 2175 2211 2212 2176;3320 2176 2212 2213 2177; 3321 2177 2213 2214 2178; 3322 2178 2214 2179 2143;3323 2143 2179 2180 2144; 3324 2144 2180 2181 2145; 3325 2145 2181 2182 2146;3326 2146 2182 2183 2147; 3327 2147 2183 2184 2148; 3328 2148 2184 2185 2149;3329 2149 2185 2186 2150; 3330 2150 2186 2187 2151; 3331 2151 2187 2188 2152;3332 2152 2188 2189 2153; 3333 2153 2189 2190 2154; 3334 2154 2190 2191 2155;3335 2155 2191 2192 2156; 3336 2156 2192 2193 2157; 3337 2157 2193 2194 2158;3338 2158 2194 2195 2159; 3339 2159 2195 2196 2160; 3340 2160 2196 2197 2161;3341 2161 2197 2198 2162; 3342 2162 2198 2199 2163; 3343 2163 2199 2200 2164;3344 2164 2200 2201 2165; 3345 2165 2201 2202 2166; 3346 2166 2202 2203 2167;3347 2167 2203 2204 2168; 3348 2168 2204 2205 2169; 3349 2205 2241 2242 2206;3350 2206 2242 2243 2207; 3351 2207 2243 2244 2208; 3352 2208 2244 2245 2209;3353 2209 2245 2246 2210; 3354 2210 2246 2247 2211; 3355 2211 2247 2248 2212;3356 2212 2248 2249 2213; 3357 2213 2249 2250 2214; 3358 2214 2250 2215 2179;3359 2179 2215 2216 2180; 3360 2180 2216 2217 2181; 3361 2181 2217 2218 2182;3362 2182 2218 2219 2183; 3363 2183 2219 2220 2184; 3364 2184 2220 2221 2185;3365 2185 2221 2222 2186; 3366 2186 2222 2223 2187; 3367 2187 2223 2224 2188;3368 2188 2224 2225 2189; 3369 2189 2225 2226 2190; 3370 2190 2226 2227 2191;3371 2191 2227 2228 2192; 3372 2192 2228 2229 2193; 3373 2193 2229 2230 2194;3374 2194 2230 2231 2195; 3375 2195 2231 2232 2196; 3376 2196 2232 2233 2197;3377 2197 2233 2234 2198; 3378 2198 2234 2235 2199; 3379 2199 2235 2236 2200;3380 2200 2236 2237 2201; 3381 2201 2237 2238 2202; 3382 2202 2238 2239 2203;3383 2203 2239 2240 2204; 3384 2204 2240 2241 2205; 3385 2241 2277 2278 2242;3386 2242 2278 2279 2243; 3387 2243 2279 2280 2244; 3388 2244 2280 2281 2245;3389 2245 2281 2282 2246; 3390 2246 2282 2283 2247; 3391 2247 2283 2284 2248;3392 2248 2284 2285 2249; 3393 2249 2285 2286 2250; 3394 2250 2286 2251 2215;3395 2215 2251 2252 2216; 3396 2216 2252 2253 2217; 3397 2217 2253 2254 2218;3398 2218 2254 2255 2219; 3399 2219 2255 2256 2220; 3400 2220 2256 2257 2221;3401 2221 2257 2258 2222; 3402 2222 2258 2259 2223; 3403 2223 2259 2260 2224;3404 2224 2260 2261 2225; 3405 2225 2261 2262 2226; 3406 2226 2262 2263 2227;3407 2227 2263 2264 2228; 3408 2228 2264 2265 2229; 3409 2229 2265 2266 2230;3410 2230 2266 2267 2231; 3411 2231 2267 2268 2232; 3412 2232 2268 2269 2233;3413 2233 2269 2270 2234; 3414 2234 2270 2271 2235; 3415 2235 2271 2272 2236;3416 2236 2272 2273 2237; 3417 2237 2273 2274 2238; 3418 2238 2274 2275 2239;3419 2239 2275 2276 2240; 3420 2240 2276 2277 2241; 3421 2277 2313 2314 2278;3422 2278 2314 2315 2279; 3423 2279 2315 2316 2280; 3424 2280 2316 2317 2281;3425 2281 2317 2318 2282; 3426 2282 2318 2319 2283; 3427 2283 2319 2320 2284;3428 2284 2320 2321 2285; 3429 2285 2321 2322 2286; 3430 2286 2322 2287 2251;3431 2251 2287 2288 2252; 3432 2252 2288 2289 2253; 3433 2253 2289 2290 2254;3434 2254 2290 2291 2255; 3435 2255 2291 2292 2256; 3436 2256 2292 2293 2257;3437 2257 2293 2294 2258; 3438 2258 2294 2295 2259; 3439 2259 2295 2296 2260;3440 2260 2296 2297 2261; 3441 2261 2297 2298 2262; 3442 2262 2298 2299 2263;3443 2263 2299 2300 2264; 3444 2264 2300 2301 2265; 3445 2265 2301 2302 2266;3446 2266 2302 2303 2267; 3447 2267 2303 2304 2268; 3448 2268 2304 2305 2269;3449 2269 2305 2306 2270; 3450 2270 2306 2307 2271; 3451 2271 2307 2308 2272;3452 2272 2308 2309 2273; 3453 2273 2309 2310 2274; 3454 2274 2310 2311 2275;3455 2275 2311 2312 2276; 3456 2276 2312 2313 2277; 3457 2313 2349 2350 2314;3458 2314 2350 2351 2315; 3459 2315 2351 2352 2316; 3460 2316 2352 2353 2317;3461 2317 2353 2354 2318; 3462 2318 2354 2355 2319; 3463 2319 2355 2356 2320;3464 2320 2356 2357 2321; 3465 2321 2357 2358 2322; 3466 2322 2358 2323 2287;3467 2287 2323 2324 2288; 3468 2288 2324 2325 2289; 3469 2289 2325 2326 2290;3470 2290 2326 2327 2291; 3471 2291 2327 2328 2292; 3472 2292 2328 2329 2293;3473 2293 2329 2330 2294; 3474 2294 2330 2331 2295; 3475 2295 2331 2332 2296;3476 2296 2332 2333 2297; 3477 2297 2333 2334 2298; 3478 2298 2334 2335 2299;3479 2299 2335 2336 2300; 3480 2300 2336 2337 2301; 3481 2301 2337 2338 2302;3482 2302 2338 2339 2303; 3483 2303 2339 2340 2304; 3484 2304 2340 2341 2305;3485 2305 2341 2342 2306; 3486 2306 2342 2343 2307; 3487 2307 2343 2344 2308;3488 2308 2344 2345 2309; 3489 2309 2345 2346 2310; 3490 2310 2346 2347 2311;3491 2311 2347 2348 2312; 3492 2312 2348 2349 2313; 3493 2349 2385 2386 2350;3494 2350 2386 2387 2351; 3495 2351 2387 2388 2352; 3496 2352 2388 2389 2353;3497 2353 2389 2390 2354; 3498 2354 2390 2391 2355; 3499 2355 2391 2392 2356;3500 2356 2392 2393 2357; 3501 2357 2393 2394 2358; 3502 2358 2394 2359 2323;3503 2323 2359 2360 2324; 3504 2324 2360 2361 2325; 3505 2325 2361 2362 2326;3506 2326 2362 2363 2327; 3507 2327 2363 2364 2328; 3508 2328 2364 2365 2329;3509 2329 2365 2366 2330; 3510 2330 2366 2367 2331; 3511 2331 2367 2368 2332;3512 2332 2368 2369 2333; 3513 2333 2369 2370 2334; 3514 2334 2370 2371 2335;3515 2335 2371 2372 2336; 3516 2336 2372 2373 2337; 3517 2337 2373 2374 2338;3518 2338 2374 2375 2339; 3519 2339 2375 2376 2340; 3520 2340 2376 2377 2341;3521 2341 2377 2378 2342; 3522 2342 2378 2379 2343; 3523 2343 2379 2380 2344;3524 2344 2380 2381 2345; 3525 2345 2381 2382 2346; 3526 2346 2382 2383 2347;3527 2347 2383 2384 2348; 3528 2348 2384 2385 2349; 3529 2385 2421 2422 2386;3530 2386 2422 2423 2387; 3531 2387 2423 2424 2388; 3532 2388 2424 2425 2389;3533 2389 2425 2426 2390; 3534 2390 2426 2427 2391; 3535 2391 2427 2428 2392;3536 2392 2428 2429 2393; 3537 2393 2429 2430 2394; 3538 2394 2430 2395 2359;3539 2359 2395 2396 2360; 3540 2360 2396 2397 2361; 3541 2361 2397 2398 2362;3542 2362 2398 2399 2363; 3543 2363 2399 2400 2364; 3544 2364 2400 2401 2365;3545 2365 2401 2402 2366; 3546 2366 2402 2403 2367; 3547 2367 2403 2404 2368;3548 2368 2404 2405 2369; 3549 2369 2405 2406 2370; 3550 2370 2406 2407 2371;3551 2371 2407 2408 2372; 3552 2372 2408 2409 2373; 3553 2373 2409 2410 2374;3554 2374 2410 2411 2375; 3555 2375 2411 2412 2376; 3556 2376 2412 2413 2377;3557 2377 2413 2414 2378; 3558 2378 2414 2415 2379; 3559 2379 2415 2416 2380;3560 2380 2416 2417 2381; 3561 2381 2417 2418 2382; 3562 2382 2418 2419 2383;3563 2383 2419 2420 2384; 3564 2384 2420 2421 2385; 3565 2421 2457 2458 2422;3566 2422 2458 2459 2423; 3567 2423 2459 2460 2424; 3568 2424 2460 2461 2425;3569 2425 2461 2462 2426; 3570 2426 2462 2463 2427; 3571 2427 2463 2464 2428;3572 2428 2464 2465 2429; 3573 2429 2465 2466 2430; 3574 2430 2466 2431 2395;3575 2395 2431 2432 2396; 3576 2396 2432 2433 2397; 3577 2397 2433 2434 2398;3578 2398 2434 2435 2399; 3579 2399 2435 2436 2400; 3580 2400 2436 2437 2401;3581 2401 2437 2438 2402; 3582 2402 2438 2439 2403; 3583 2403 2439 2440 2404;3584 2404 2440 2441 2405; 3585 2405 2441 2442 2406; 3586 2406 2442 2443 2407;3587 2407 2443 2444 2408; 3588 2408 2444 2445 2409; 3589 2409 2445 2446 2410;3590 2410 2446 2447 2411; 3591 2411 2447 2448 2412; 3592 2412 2448 2449 2413;3593 2413 2449 2450 2414; 3594 2414 2450 2451 2415; 3595 2415 2451 2452 2416;3596 2416 2452 2453 2417; 3597 2417 2453 2454 2418; 3598 2418 2454 2455 2419;3599 2419 2455 2456 2420; 3600 2420 2456 2457 2421; 3601 2457 2493 2494 2458;3602 2458 2494 2495 2459; 3603 2459 2495 2496 2460; 3604 2460 2496 2497 2461;3605 2461 2497 2498 2462; 3606 2462 2498 2499 2463; 3607 2463 2499 2500 2464;3608 2464 2500 2501 2465; 3609 2465 2501 2502 2466; 3610 2466 2502 2467 2431;3611 2431 2467 2468 2432; 3612 2432 2468 2469 2433; 3613 2433 2469 2470 2434;3614 2434 2470 2471 2435; 3615 2435 2471 2472 2436; 3616 2436 2472 2473 2437;3617 2437 2473 2474 2438; 3618 2438 2474 2475 2439; 3619 2439 2475 2476 2440;3620 2440 2476 2477 2441; 3621 2441 2477 2478 2442; 3622 2442 2478 2479 2443;3623 2443 2479 2480 2444; 3624 2444 2480 2481 2445; 3625 2445 2481 2482 2446;3626 2446 2482 2483 2447; 3627 2447 2483 2484 2448; 3628 2448 2484 2485 2449;3629 2449 2485 2486 2450; 3630 2450 2486 2487 2451; 3631 2451 2487 2488 2452;3632 2452 2488 2489 2453; 3633 2453 2489 2490 2454; 3634 2454 2490 2491 2455;3635 2455 2491 2492 2456; 3636 2456 2492 2493 2457; 3637 2493 2529 2530 2494;3638 2494 2530 2531 2495; 3639 2495 2531 2532 2496; 3640 2496 2532 2533 2497;3641 2497 2533 2534 2498; 3642 2498 2534 2535 2499; 3643 2499 2535 2536 2500;3644 2500 2536 2537 2501; 3645 2501 2537 2538 2502; 3646 2502 2538 2503 2467;3647 2467 2503 2504 2468; 3648 2468 2504 2505 2469; 3649 2469 2505 2506 2470;3650 2470 2506 2507 2471; 3651 2471 2507 2508 2472; 3652 2472 2508 2509 2473;3653 2473 2509 2510 2474; 3654 2474 2510 2511 2475; 3655 2475 2511 2512 2476;3656 2476 2512 2513 2477; 3657 2477 2513 2514 2478; 3658 2478 2514 2515 2479;3659 2479 2515 2516 2480; 3660 2480 2516 2517 2481; 3661 2481 2517 2518 2482;3662 2482 2518 2519 2483; 3663 2483 2519 2520 2484; 3664 2484 2520 2521 2485;3665 2485 2521 2522 2486; 3666 2486 2522 2523 2487; 3667 2487 2523 2524 2488;3668 2488 2524 2525 2489; 3669 2489 2525 2526 2490; 3670 2490 2526 2527 2491;3671 2491 2527 2528 2492; 3672 2492 2528 2529 2493; 3673 2529 2565 2566 2530;3674 2530 2566 2567 2531; 3675 2531 2567 2568 2532; 3676 2532 2568 2569 2533;3677 2533 2569 2570 2534; 3678 2534 2570 2571 2535; 3679 2535 2571 2572 2536;3680 2536 2572 2573 2537; 3681 2537 2573 2574 2538; 3682 2538 2574 2539 2503;3683 2503 2539 2540 2504; 3684 2504 2540 2541 2505; 3685 2505 2541 2542 2506;3686 2506 2542 2543 2507; 3687 2507 2543 2544 2508; 3688 2508 2544 2545 2509;3689 2509 2545 2546 2510; 3690 2510 2546 2547 2511; 3691 2511 2547 2548 2512;3692 2512 2548 2549 2513; 3693 2513 2549 2550 2514; 3694 2514 2550 2551 2515;3695 2515 2551 2552 2516; 3696 2516 2552 2553 2517; 3697 2517 2553 2554 2518;3698 2518 2554 2555 2519; 3699 2519 2555 2556 2520; 3700 2520 2556 2557 2521;3701 2521 2557 2558 2522; 3702 2522 2558 2559 2523; 3703 2523 2559 2560 2524;3704 2524 2560 2561 2525; 3705 2525 2561 2562 2526; 3706 2526 2562 2563 2527;3707 2527 2563 2564 2528; 3708 2528 2564 2565 2529; 3709 2565 2601 2602 2566;3710 2566 2602 2603 2567; 3711 2567 2603 2604 2568; 3712 2568 2604 2605 2569;3713 2569 2605 2606 2570; 3714 2570 2606 2607 2571; 3715 2571 2607 2608 2572;3716 2572 2608 2609 2573; 3717 2573 2609 2610 2574; 3718 2574 2610 2575 2539;3719 2539 2575 2576 2540; 3720 2540 2576 2577 2541; 3721 2541 2577 2578 2542;3722 2542 2578 2579 2543; 3723 2543 2579 2580 2544; 3724 2544 2580 2581 2545;3725 2545 2581 2582 2546; 3726 2546 2582 2583 2547; 3727 2547 2583 2584 2548;3728 2548 2584 2585 2549; 3729 2549 2585 2586 2550; 3730 2550 2586 2587 2551;3731 2551 2587 2588 2552; 3732 2552 2588 2589 2553; 3733 2553 2589 2590 2554;3734 2554 2590 2591 2555; 3735 2555 2591 2592 2556; 3736 2556 2592 2593 2557;3737 2557 2593 2594 2558; 3738 2558 2594 2595 2559; 3739 2559 2595 2596 2560;3740 2560 2596 2597 2561; 3741 2561 2597 2598 2562; 3742 2562 2598 2599 2563;3743 2563 2599 2600 2564; 3744 2564 2600 2601 2565; 3745 2601 2637 2638 2602;3746 2602 2638 2639 2603; 3747 2603 2639 2640 2604; 3748 2604 2640 2641 2605;3749 2605 2641 2642 2606; 3750 2606 2642 2643 2607; 3751 2607 2643 2644 2608;3752 2608 2644 2645 2609; 3753 2609 2645 2646 2610; 3754 2610 2646 2611 2575;3755 2575 2611 2612 2576; 3756 2576 2612 2613 2577; 3757 2577 2613 2614 2578;3758 2578 2614 2615 2579; 3759 2579 2615 2616 2580; 3760 2580 2616 2617 2581;3761 2581 2617 2618 2582; 3762 2582 2618 2619 2583; 3763 2583 2619 2620 2584;3764 2584 2620 2621 2585; 3765 2585 2621 2622 2586; 3766 2586 2622 2623 2587;3767 2587 2623 2624 2588; 3768 2588 2624 2625 2589; 3769 2589 2625 2626 2590;3770 2590 2626 2627 2591; 3771 2591 2627 2628 2592; 3772 2592 2628 2629 2593;3773 2593 2629 2630 2594; 3774 2594 2630 2631 2595; 3775 2595 2631 2632 2596;3776 2596 2632 2633 2597; 3777 2597 2633 2634 2598; 3778 2598 2634 2635 2599;3779 2599 2635 2636 2600; 3780 2600 2636 2637 2601; 3781 2637 2673 2674 2638;3782 2638 2674 2675 2639; 3783 2639 2675 2676 2640; 3784 2640 2676 2677 2641;3785 2641 2677 2678 2642; 3786 2642 2678 2679 2643; 3787 2643 2679 2680 2644;3788 2644 2680 2681 2645; 3789 2645 2681 2682 2646; 3790 2646 2682 2647 2611;3791 2611 2647 2648 2612; 3792 2612 2648 2649 2613; 3793 2613 2649 2650 2614;3794 2614 2650 2651 2615; 3795 2615 2651 2652 2616; 3796 2616 2652 2653 2617;3797 2617 2653 2654 2618; 3798 2618 2654 2655 2619; 3799 2619 2655 2656 2620;3800 2620 2656 2657 2621; 3801 2621 2657 2658 2622; 3802 2622 2658 2659 2623;3803 2623 2659 2660 2624; 3804 2624 2660 2661 2625; 3805 2625 2661 2662 2626;3806 2626 2662 2663 2627; 3807 2627 2663 2664 2628; 3808 2628 2664 2665 2629;3809 2629 2665 2666 2630; 3810 2630 2666 2667 2631; 3811 2631 2667 2668 2632;3812 2632 2668 2669 2633; 3813 2633 2669 2670 2634; 3814 2634 2670 2671 2635;3815 2635 2671 2672 2636; 3816 2636 2672 2673 2637; 3817 2673 2709 2710 2674;3818 2674 2710 2711 2675; 3819 2675 2711 2712 2676; 3820 2676 2712 2713 2677;3821 2677 2713 2714 2678; 3822 2678 2714 2715 2679; 3823 2679 2715 2716 2680;3824 2680 2716 2717 2681; 3825 2681 2717 2718 2682; 3826 2682 2718 2683 2647;3827 2647 2683 2684 2648; 3828 2648 2684 2685 2649; 3829 2649 2685 2686 2650;3830 2650 2686 2687 2651; 3831 2651 2687 2688 2652; 3832 2652 2688 2689 2653;3833 2653 2689 2690 2654; 3834 2654 2690 2691 2655; 3835 2655 2691 2692 2656;3836 2656 2692 2693 2657; 3837 2657 2693 2694 2658; 3838 2658 2694 2695 2659;3839 2659 2695 2696 2660; 3840 2660 2696 2697 2661; 3841 2661 2697 2698 2662;3842 2662 2698 2699 2663; 3843 2663 2699 2700 2664; 3844 2664 2700 2701 2665;3845 2665 2701 2702 2666; 3846 2666 2702 2703 2667; 3847 2667 2703 2704 2668;3848 2668 2704 2705 2669; 3849 2669 2705 2706 2670; 3850 2670 2706 2707 2671;3851 2671 2707 2708 2672; 3852 2672 2708 2709 2673; 3853 2709 2745 2746 2710;3854 2710 2746 2747 2711; 3855 2711 2747 2748 2712; 3856 2712 2748 2749 2713;3857 2713 2749 2750 2714; 3858 2714 2750 2751 2715; 3859 2715 2751 2752 2716;3860 2716 2752 2753 2717; 3861 2717 2753 2754 2718; 3862 2718 2754 2719 2683;3863 2683 2719 2720 2684; 3864 2684 2720 2721 2685; 3865 2685 2721 2722 2686;3866 2686 2722 2723 2687; 3867 2687 2723 2724 2688; 3868 2688 2724 2725 2689;3869 2689 2725 2726 2690; 3870 2690 2726 2727 2691; 3871 2691 2727 2728 2692;3872 2692 2728 2729 2693; 3873 2693 2729 2730 2694; 3874 2694 2730 2731 2695;3875 2695 2731 2732 2696; 3876 2696 2732 2733 2697; 3877 2697 2733 2734 2698;3878 2698 2734 2735 2699; 3879 2699 2735 2736 2700; 3880 2700 2736 2737 2701;3881 2701 2737 2738 2702; 3882 2702 2738 2739 2703; 3883 2703 2739 2740 2704;3884 2704 2740 2741 2705; 3885 2705 2741 2742 2706; 3886 2706 2742 2743 2707;3887 2707 2743 2744 2708; 3888 2708 2744 2745 2709; 3889 2745 2781 2782 2746;3890 2746 2782 2783 2747; 3891 2747 2783 2784 2748; 3892 2748 2784 2785 2749;3893 2749 2785 2786 2750; 3894 2750 2786 2787 2751; 3895 2751 2787 2788 2752;3896 2752 2788 2789 2753; 3897 2753 2789 2790 2754; 3898 2754 2790 2755 2719;3899 2719 2755 2756 2720; 3900 2720 2756 2757 2721; 3901 2721 2757 2758 2722;3902 2722 2758 2759 2723; 3903 2723 2759 2760 2724; 3904 2724 2760 2761 2725;3905 2725 2761 2762 2726; 3906 2726 2762 2763 2727; 3907 2727 2763 2764 2728;3908 2728 2764 2765 2729; 3909 2729 2765 2766 2730; 3910 2730 2766 2767 2731;3911 2731 2767 2768 2732; 3912 2732 2768 2769 2733; 3913 2733 2769 2770 2734;3914 2734 2770 2771 2735; 3915 2735 2771 2772 2736; 3916 2736 2772 2773 2737;3917 2737 2773 2774 2738; 3918 2738 2774 2775 2739; 3919 2739 2775 2776 2740;3920 2740 2776 2777 2741; 3921 2741 2777 2778 2742; 3922 2742 2778 2779 2743;3923 2743 2779 2780 2744; 3924 2744 2780 2781 2745; 3925 2781 2817 2818 2782;3926 2782 2818 2819 2783; 3927 2783 2819 2820 2784; 3928 2784 2820 2821 2785;3929 2785 2821 2822 2786; 3930 2786 2822 2823 2787; 3931 2787 2823 2824 2788;3932 2788 2824 2825 2789; 3933 2789 2825 2826 2790; 3934 2790 2826 2791 2755;3935 2755 2791 2792 2756; 3936 2756 2792 2793 2757; 3937 2757 2793 2794 2758;3938 2758 2794 2795 2759; 3939 2759 2795 2796 2760; 3940 2760 2796 2797 2761;3941 2761 2797 2798 2762; 3942 2762 2798 2799 2763; 3943 2763 2799 2800 2764;3944 2764 2800 2801 2765; 3945 2765 2801 2802 2766; 3946 2766 2802 2803 2767;3947 2767 2803 2804 2768; 3948 2768 2804 2805 2769; 3949 2769 2805 2806 2770;3950 2770 2806 2807 2771; 3951 2771 2807 2808 2772; 3952 2772 2808 2809 2773;3953 2773 2809 2810 2774; 3954 2774 2810 2811 2775; 3955 2775 2811 2812 2776;3956 2776 2812 2813 2777; 3957 2777 2813 2814 2778; 3958 2778 2814 2815 2779;3959 2779 2815 2816 2780; 3960 2780 2816 2817 2781; 3961 2817 2853 2854 2818;3962 2818 2854 2855 2819; 3963 2819 2855 2856 2820; 3964 2820 2856 2857 2821;3965 2821 2857 2858 2822; 3966 2822 2858 2859 2823; 3967 2823 2859 2860 2824;3968 2824 2860 2861 2825; 3969 2825 2861 2862 2826; 3970 2826 2862 2827 2791;3971 2791 2827 2828 2792; 3972 2792 2828 2829 2793; 3973 2793 2829 2830 2794;3974 2794 2830 2831 2795; 3975 2795 2831 2832 2796; 3976 2796 2832 2833 2797;3977 2797 2833 2834 2798; 3978 2798 2834 2835 2799; 3979 2799 2835 2836 2800;3980 2800 2836 2837 2801; 3981 2801 2837 2838 2802; 3982 2802 2838 2839 2803;3983 2803 2839 2840 2804; 3984 2804 2840 2841 2805; 3985 2805 2841 2842 2806;3986 2806 2842 2843 2807; 3987 2807 2843 2844 2808; 3988 2808 2844 2845 2809;3989 2809 2845 2846 2810; 3990 2810 2846 2847 2811; 3991 2811 2847 2848 2812;3992 2812 2848 2849 2813; 3993 2813 2849 2850 2814; 3994 2814 2850 2851 2815;3995 2815 2851 2852 2816; 3996 2816 2852 2853 2817; 3997 2853 2889 2890 2854;3998 2854 2890 2891 2855; 3999 2855 2891 2892 2856; 4000 2856 2892 2893 2857;4001 2857 2893 2894 2858; 4002 2858 2894 2895 2859; 4003 2859 2895 2896 2860;4004 2860 2896 2897 2861; 4005 2861 2897 2898 2862; 4006 2862 2898 2863 2827;4007 2827 2863 2864 2828; 4008 2828 2864 2865 2829; 4009 2829 2865 2866 2830;4010 2830 2866 2867 2831; 4011 2831 2867 2868 2832; 4012 2832 2868 2869 2833;4013 2833 2869 2870 2834; 4014 2834 2870 2871 2835; 4015 2835 2871 2872 2836;4016 2836 2872 2873 2837; 4017 2837 2873 2874 2838; 4018 2838 2874 2875 2839;4019 2839 2875 2876 2840; 4020 2840 2876 2877 2841; 4021 2841 2877 2878 2842;4022 2842 2878 2879 2843; 4023 2843 2879 2880 2844; 4024 2844 2880 2881 2845;4025 2845 2881 2882 2846; 4026 2846 2882 2883 2847; 4027 2847 2883 2884 2848;4028 2848 2884 2885 2849; 4029 2849 2885 2886 2850; 4030 2850 2886 2887 2851;4031 2851 2887 2888 2852; 4032 2852 2888 2889 2853; 4033 2889 2925 2926 2890;4034 2890 2926 2927 2891; 4035 2891 2927 2928 2892; 4036 2892 2928 2929 2893;4037 2893 2929 2930 2894; 4038 2894 2930 2931 2895; 4039 2895 2931 2932 2896;4040 2896 2932 2933 2897; 4041 2897 2933 2934 2898; 4042 2898 2934 2899 2863;4043 2863 2899 2900 2864; 4044 2864 2900 2901 2865; 4045 2865 2901 2902 2866;4046 2866 2902 2903 2867; 4047 2867 2903 2904 2868; 4048 2868 2904 2905 2869;4049 2869 2905 2906 2870; 4050 2870 2906 2907 2871; 4051 2871 2907 2908 2872;4052 2872 2908 2909 2873; 4053 2873 2909 2910 2874; 4054 2874 2910 2911 2875;4055 2875 2911 2912 2876; 4056 2876 2912 2913 2877; 4057 2877 2913 2914 2878;4058 2878 2914 2915 2879; 4059 2879 2915 2916 2880; 4060 2880 2916 2917 2881;4061 2881 2917 2918 2882; 4062 2882 2918 2919 2883; 4063 2883 2919 2920 2884;4064 2884 2920 2921 2885; 4065 2885 2921 2922 2886; 4066 2886 2922 2923 2887;4067 2887 2923 2924 2888; 4068 2888 2924 2925 2889; 4069 2925 2961 2962 2926;4070 2926 2962 2963 2927; 4071 2927 2963 2964 2928; 4072 2928 2964 2965 2929;4073 2929 2965 2966 2930; 4074 2930 2966 2967 2931; 4075 2931 2967 2968 2932;4076 2932 2968 2969 2933; 4077 2933 2969 2970 2934; 4078 2934 2970 2935 2899;4079 2899 2935 2936 2900; 4080 2900 2936 2937 2901; 4081 2901 2937 2938 2902;4082 2902 2938 2939 2903; 4083 2903 2939 2940 2904; 4084 2904 2940 2941 2905;4085 2905 2941 2942 2906; 4086 2906 2942 2943 2907; 4087 2907 2943 2944 2908;4088 2908 2944 2945 2909; 4089 2909 2945 2946 2910; 4090 2910 2946 2947 2911;4091 2911 2947 2948 2912; 4092 2912 2948 2949 2913; 4093 2913 2949 2950 2914;4094 2914 2950 2951 2915; 4095 2915 2951 2952 2916; 4096 2916 2952 2953 2917;4097 2917 2953 2954 2918; 4098 2918 2954 2955 2919; 4099 2919 2955 2956 2920;4100 2920 2956 2957 2921; 4101 2921 2957 2958 2922; 4102 2922 2958 2959 2923;4103 2923 2959 2960 2924; 4104 2924 2960 2961 2925; 4105 2961 2997 2998 2962;4106 2962 2998 2999 2963; 4107 2963 2999 3000 2964; 4108 2964 3000 3001 2965;4109 2965 3001 3002 2966; 4110 2966 3002 3003 2967; 4111 2967 3003 3004 2968;4112 2968 3004 3005 2969; 4113 2969 3005 3006 2970; 4114 2970 3006 2971 2935;4115 2935 2971 2972 2936; 4116 2936 2972 2973 2937; 4117 2937 2973 2974 2938;4118 2938 2974 2975 2939; 4119 2939 2975 2976 2940; 4120 2940 2976 2977 2941;4121 2941 2977 2978 2942; 4122 2942 2978 2979 2943; 4123 2943 2979 2980 2944;4124 2944 2980 2981 2945; 4125 2945 2981 2982 2946; 4126 2946 2982 2983 2947;4127 2947 2983 2984 2948; 4128 2948 2984 2985 2949; 4129 2949 2985 2986 2950;4130 2950 2986 2987 2951; 4131 2951 2987 2988 2952; 4132 2952 2988 2989 2953;4133 2953 2989 2990 2954; 4134 2954 2990 2991 2955; 4135 2955 2991 2992 2956;4136 2956 2992 2993 2957; 4137 2957 2993 2994 2958; 4138 2958 2994 2995 2959;4139 2959 2995 2996 2960; 4140 2960 2996 2997 2961; 4141 2997 3033 3034 2998;4142 2998 3034 3035 2999; 4143 2999 3035 3036 3000; 4144 3000 3036 3037 3001;4145 3001 3037 3038 3002; 4146 3002 3038 3039 3003; 4147 3003 3039 3040 3004;4148 3004 3040 3041 3005; 4149 3005 3041 3042 3006; 4150 3006 3042 3007 2971;4151 2971 3007 3008 2972; 4152 2972 3008 3009 2973; 4153 2973 3009 3010 2974;4154 2974 3010 3011 2975; 4155 2975 3011 3012 2976; 4156 2976 3012 3013 2977;4157 2977 3013 3014 2978; 4158 2978 3014 3015 2979; 4159 2979 3015 3016 2980;4160 2980 3016 3017 2981; 4161 2981 3017 3018 2982; 4162 2982 3018 3019 2983;4163 2983 3019 3020 2984; 4164 2984 3020 3021 2985; 4165 2985 3021 3022 2986;4166 2986 3022 3023 2987; 4167 2987 3023 3024 2988; 4168 2988 3024 3025 2989;4169 2989 3025 3026 2990; 4170 2990 3026 3027 2991; 4171 2991 3027 3028 2992;4172 2992 3028 3029 2993; 4173 2993 3029 3030 2994; 4174 2994 3030 3031 2995;4175 2995 3031 3032 2996; 4176 2996 3032 3033 2997; 4177 3033 3069 3070 3034;4178 3034 3070 3071 3035; 4179 3035 3071 3072 3036; 4180 3036 3072 3073 3037;4181 3037 3073 3074 3038; 4182 3038 3074 3075 3039; 4183 3039 3075 3076 3040;4184 3040 3076 3077 3041; 4185 3041 3077 3078 3042; 4186 3042 3078 3043 3007;4187 3007 3043 3044 3008; 4188 3008 3044 3045 3009; 4189 3009 3045 3046 3010;4190 3010 3046 3047 3011; 4191 3011 3047 3048 3012; 4192 3012 3048 3049 3013;4193 3013 3049 3050 3014; 4194 3014 3050 3051 3015; 4195 3015 3051 3052 3016;4196 3016 3052 3053 3017; 4197 3017 3053 3054 3018; 4198 3018 3054 3055 3019;4199 3019 3055 3056 3020; 4200 3020 3056 3057 3021; 4201 3021 3057 3058 3022;4202 3022 3058 3059 3023; 4203 3023 3059 3060 3024; 4204 3024 3060 3061 3025;4205 3025 3061 3062 3026; 4206 3026 3062 3063 3027; 4207 3027 3063 3064 3028;4208 3028 3064 3065 3029; 4209 3029 3065 3066 3030; 4210 3030 3066 3067 3031;4211 3031 3067 3068 3032; 4212 3032 3068 3069 3033; 4213 3069 3105 3106 3070;4214 3070 3106 3107 3071; 4215 3071 3107 3108 3072; 4216 3072 3108 3109 3073;4217 3073 3109 3110 3074; 4218 3074 3110 3111 3075; 4219 3075 3111 3112 3076;4220 3076 3112 3113 3077; 4221 3077 3113 3114 3078; 4222 3078 3114 3079 3043;4223 3043 3079 3080 3044; 4224 3044 3080 3081 3045; 4225 3045 3081 3082 3046;4226 3046 3082 3083 3047; 4227 3047 3083 3084 3048; 4228 3048 3084 3085 3049;4229 3049 3085 3086 3050; 4230 3050 3086 3087 3051; 4231 3051 3087 3088 3052;4232 3052 3088 3089 3053; 4233 3053 3089 3090 3054; 4234 3054 3090 3091 3055;4235 3055 3091 3092 3056; 4236 3056 3092 3093 3057; 4237 3057 3093 3094 3058;4238 3058 3094 3095 3059; 4239 3059 3095 3096 3060; 4240 3060 3096 3097 3061;4241 3061 3097 3098 3062; 4242 3062 3098 3099 3063; 4243 3063 3099 3100 3064;4244 3064 3100 3101 3065; 4245 3065 3101 3102 3066; 4246 3066 3102 3103 3067;4247 3067 3103 3104 3068; 4248 3068 3104 3105 3069; 4249 3105 3141 3142 3106;4250 3106 3142 3143 3107; 4251 3107 3143 3144 3108; 4252 3108 3144 3145 3109;4253 3109 3145 3146 3110; 4254 3110 3146 3147 3111; 4255 3111 3147 3148 3112;4256 3112 3148 3149 3113; 4257 3113 3149 3150 3114; 4258 3114 3150 3115 3079;4259 3079 3115 3116 3080; 4260 3080 3116 3117 3081; 4261 3081 3117 3118 3082;4262 3082 3118 3119 3083; 4263 3083 3119 3120 3084; 4264 3084 3120 3121 3085;4265 3085 3121 3122 3086; 4266 3086 3122 3123 3087; 4267 3087 3123 3124 3088;4268 3088 3124 3125 3089; 4269 3089 3125 3126 3090; 4270 3090 3126 3127 3091;4271 3091 3127 3128 3092; 4272 3092 3128 3129 3093; 4273 3093 3129 3130 3094;4274 3094 3130 3131 3095; 4275 3095 3131 3132 3096; 4276 3096 3132 3133 3097;4277 3097 3133 3134 3098; 4278 3098 3134 3135 3099; 4279 3099 3135 3136 3100;4280 3100 3136 3137 3101; 4281 3101 3137 3138 3102; 4282 3102 3138 3139 3103;4283 3103 3139 3140 3104; 4284 3104 3140 3141 3105; 4285 3141 3177 3178 3142;4286 3142 3178 3179 3143; 4287 3143 3179 3180 3144; 4288 3144 3180 3181 3145;4289 3145 3181 3182 3146; 4290 3146 3182 3183 3147; 4291 3147 3183 3184 3148;4292 3148 3184 3185 3149; 4293 3149 3185 3186 3150; 4294 3150 3186 3151 3115;4295 3115 3151 3152 3116; 4296 3116 3152 3153 3117; 4297 3117 3153 3154 3118;4298 3118 3154 3155 3119; 4299 3119 3155 3156 3120; 4300 3120 3156 3157 3121;4301 3121 3157 3158 3122; 4302 3122 3158 3159 3123; 4303 3123 3159 3160 3124;4304 3124 3160 3161 3125; 4305 3125 3161 3162 3126; 4306 3126 3162 3163 3127;4307 3127 3163 3164 3128; 4308 3128 3164 3165 3129; 4309 3129 3165 3166 3130;4310 3130 3166 3167 3131; 4311 3131 3167 3168 3132; 4312 3132 3168 3169 3133;4313 3133 3169 3170 3134; 4314 3134 3170 3171 3135; 4315 3135 3171 3172 3136;4316 3136 3172 3173 3137; 4317 3137 3173 3174 3138; 4318 3138 3174 3175 3139;4319 3139 3175 3176 3140; 4320 3140 3176 3177 3141; 4321 3177 3213 3214 3178;4322 3178 3214 3215 3179; 4323 3179 3215 3216 3180; 4324 3180 3216 3217 3181;4325 3181 3217 3218 3182; 4326 3182 3218 3219 3183; 4327 3183 3219 3220 3184;4328 3184 3220 3221 3185; 4329 3185 3221 3222 3186; 4330 3186 3222 3187 3151;4331 3151 3187 3188 3152; 4332 3152 3188 3189 3153; 4333 3153 3189 3190 3154;4334 3154 3190 3191 3155; 4335 3155 3191 3192 3156; 4336 3156 3192 3193 3157;4337 3157 3193 3194 3158; 4338 3158 3194 3195 3159; 4339 3159 3195 3196 3160;4340 3160 3196 3197 3161; 4341 3161 3197 3198 3162; 4342 3162 3198 3199 3163;4343 3163 3199 3200 3164; 4344 3164 3200 3201 3165; 4345 3165 3201 3202 3166;4346 3166 3202 3203 3167; 4347 3167 3203 3204 3168; 4348 3168 3204 3205 3169;4349 3169 3205 3206 3170; 4350 3170 3206 3207 3171; 4351 3171 3207 3208 3172;4352 3172 3208 3209 3173; 4353 3173 3209 3210 3174; 4354 3174 3210 3211 3175;4355 3175 3211 3212 3176; 4356 3176 3212 3213 3177; 4357 3213 3249 3250 3214;4358 3214 3250 3251 3215; 4359 3215 3251 3252 3216; 4360 3216 3252 3253 3217;4361 3217 3253 3254 3218; 4362 3218 3254 3255 3219; 4363 3219 3255 3256 3220;4364 3220 3256 3257 3221; 4365 3221 3257 3258 3222; 4366 3222 3258 3223 3187;4367 3187 3223 3224 3188; 4368 3188 3224 3225 3189; 4369 3189 3225 3226 3190;4370 3190 3226 3227 3191; 4371 3191 3227 3228 3192; 4372 3192 3228 3229 3193;4373 3193 3229 3230 3194; 4374 3194 3230 3231 3195; 4375 3195 3231 3232 3196;4376 3196 3232 3233 3197; 4377 3197 3233 3234 3198; 4378 3198 3234 3235 3199;4379 3199 3235 3236 3200; 4380 3200 3236 3237 3201; 4381 3201 3237 3238 3202;4382 3202 3238 3239 3203; 4383 3203 3239 3240 3204; 4384 3204 3240 3241 3205;4385 3205 3241 3242 3206; 4386 3206 3242 3243 3207; 4387 3207 3243 3244 3208;4388 3208 3244 3245 3209; 4389 3209 3245 3246 3210; 4390 3210 3246 3247 3211;4391 3211 3247 3248 3212; 4392 3212 3248 3249 3213; 4393 3249 3285 3286 3250;4394 3250 3286 3287 3251; 4395 3251 3287 3288 3252; 4396 3252 3288 3289 3253;4397 3253 3289 3290 3254; 4398 3254 3290 3291 3255; 4399 3255 3291 3292 3256;4400 3256 3292 3293 3257; 4401 3257 3293 3294 3258; 4402 3258 3294 3259 3223;4403 3223 3259 3260 3224; 4404 3224 3260 3261 3225; 4405 3225 3261 3262 3226;4406 3226 3262 3263 3227; 4407 3227 3263 3264 3228; 4408 3228 3264 3265 3229;4409 3229 3265 3266 3230; 4410 3230 3266 3267 3231; 4411 3231 3267 3268 3232;4412 3232 3268 3269 3233; 4413 3233 3269 3270 3234; 4414 3234 3270 3271 3235;4415 3235 3271 3272 3236; 4416 3236 3272 3273 3237; 4417 3237 3273 3274 3238;4418 3238 3274 3275 3239; 4419 3239 3275 3276 3240; 4420 3240 3276 3277 3241;4421 3241 3277 3278 3242; 4422 3242 3278 3279 3243; 4423 3243 3279 3280 3244;4424 3244 3280 3281 3245; 4425 3245 3281 3282 3246; 4426 3246 3282 3283 3247;4427 3247 3283 3284 3248; 4428 3248 3284 3285 3249; 4429 3285 3321 3322 3286;4430 3286 3322 3323 3287; 4431 3287 3323 3324 3288; 4432 3288 3324 3325 3289;4433 3289 3325 3326 3290; 4434 3290 3326 3327 3291; 4435 3291 3327 3328 3292;4436 3292 3328 3329 3293; 4437 3293 3329 3330 3294; 4438 3294 3330 3295 3259;4439 3259 3295 3296 3260; 4440 3260 3296 3297 3261; 4441 3261 3297 3298 3262;4442 3262 3298 3299 3263; 4443 3263 3299 3300 3264; 4444 3264 3300 3301 3265;4445 3265 3301 3302 3266; 4446 3266 3302 3303 3267; 4447 3267 3303 3304 3268;4448 3268 3304 3305 3269; 4449 3269 3305 3306 3270; 4450 3270 3306 3307 3271;4451 3271 3307 3308 3272; 4452 3272 3308 3309 3273; 4453 3273 3309 3310 3274;4454 3274 3310 3311 3275; 4455 3275 3311 3312 3276; 4456 3276 3312 3313 3277;4457 3277 3313 3314 3278; 4458 3278 3314 3315 3279; 4459 3279 3315 3316 3280;4460 3280 3316 3317 3281; 4461 3281 3317 3318 3282; 4462 3282 3318 3319 3283;4463 3283 3319 3320 3284; 4464 3284 3320 3321 3285; 4465 3321 3357 3358 3322;4466 3322 3358 3359 3323; 4467 3323 3359 3360 3324; 4468 3324 3360 3361 3325;4469 3325 3361 3362 3326; 4470 3326 3362 3363 3327; 4471 3327 3363 3364 3328;4472 3328 3364 3365 3329; 4473 3329 3365 3366 3330; 4474 3330 3366 3331 3295;4475 3295 3331 3332 3296; 4476 3296 3332 3333 3297; 4477 3297 3333 3334 3298;4478 3298 3334 3335 3299; 4479 3299 3335 3336 3300; 4480 3300 3336 3337 3301;4481 3301 3337 3338 3302; 4482 3302 3338 3339 3303; 4483 3303 3339 3340 3304;4484 3304 3340 3341 3305; 4485 3305 3341 3342 3306; 4486 3306 3342 3343 3307;4487 3307 3343 3344 3308; 4488 3308 3344 3345 3309; 4489 3309 3345 3346 3310;4490 3310 3346 3347 3311; 4491 3311 3347 3348 3312; 4492 3312 3348 3349 3313;4493 3313 3349 3350 3314; 4494 3314 3350 3351 3315; 4495 3315 3351 3352 3316;4496 3316 3352 3353 3317; 4497 3317 3353 3354 3318; 4498 3318 3354 3355 3319;4499 3319 3355 3356 3320; 4500 3320 3356 3357 3321; 4501 3357 3393 3394 3358;4502 3358 3394 3395 3359; 4503 3359 3395 3396 3360; 4504 3360 3396 3397 3361;4505 3361 3397 3398 3362; 4506 3362 3398 3399 3363; 4507 3363 3399 3400 3364;4508 3364 3400 3401 3365; 4509 3365 3401 3402 3366; 4510 3366 3402 3367 3331;4511 3331 3367 3368 3332; 4512 3332 3368 3369 3333; 4513 3333 3369 3370 3334;4514 3334 3370 3371 3335; 4515 3335 3371 3372 3336; 4516 3336 3372 3373 3337;4517 3337 3373 3374 3338; 4518 3338 3374 3375 3339; 4519 3339 3375 3376 3340;4520 3340 3376 3377 3341; 4521 3341 3377 3378 3342; 4522 3342 3378 3379 3343;4523 3343 3379 3380 3344; 4524 3344 3380 3381 3345; 4525 3345 3381 3382 3346;4526 3346 3382 3383 3347; 4527 3347 3383 3384 3348; 4528 3348 3384 3385 3349;4529 3349 3385 3386 3350; 4530 3350 3386 3387 3351; 4531 3351 3387 3388 3352;4532 3352 3388 3389 3353; 4533 3353 3389 3390 3354; 4534 3354 3390 3391 3355;4535 3355 3391 3392 3356; 4536 3356 3392 3393 3357; 4537 3393 3429 3430 3394;4538 3394 3430 3431 3395; 4539 3395 3431 3432 3396; 4540 3396 3432 3433 3397;4541 3397 3433 3434 3398; 4542 3398 3434 3435 3399; 4543 3399 3435 3436 3400;4544 3400 3436 3437 3401; 4545 3401 3437 3438 3402; 4546 3402 3438 3403 3367;4547 3367 3403 3404 3368; 4548 3368 3404 3405 3369; 4549 3369 3405 3406 3370;4550 3370 3406 3407 3371; 4551 3371 3407 3408 3372; 4552 3372 3408 3409 3373;4553 3373 3409 3410 3374; 4554 3374 3410 3411 3375; 4555 3375 3411 3412 3376;4556 3376 3412 3413 3377; 4557 3377 3413 3414 3378; 4558 3378 3414 3415 3379;4559 3379 3415 3416 3380; 4560 3380 3416 3417 3381; 4561 3381 3417 3418 3382;4562 3382 3418 3419 3383; 4563 3383 3419 3420 3384; 4564 3384 3420 3421 3385;4565 3385 3421 3422 3386; 4566 3386 3422 3423 3387; 4567 3387 3423 3424 3388;4568 3388 3424 3425 3389; 4569 3389 3425 3426 3390; 4570 3390 3426 3427 3391;4571 3391 3427 3428 3392; 4572 3392 3428 3429 3393; 4573 3429 3465 3466 3430;4574 3430 3466 3467 3431; 4575 3431 3467 3468 3432; 4576 3432 3468 3469 3433;4577 3433 3469 3470 3434; 4578 3434 3470 3471 3435; 4579 3435 3471 3472 3436;4580 3436 3472 3473 3437; 4581 3437 3473 3474 3438; 4582 3438 3474 3439 3403;4583 3403 3439 3440 3404; 4584 3404 3440 3441 3405; 4585 3405 3441 3442 3406;4586 3406 3442 3443 3407; 4587 3407 3443 3444 3408; 4588 3408 3444 3445 3409;4589 3409 3445 3446 3410; 4590 3410 3446 3447 3411; 4591 3411 3447 3448 3412;4592 3412 3448 3449 3413; 4593 3413 3449 3450 3414; 4594 3414 3450 3451 3415;4595 3415 3451 3452 3416; 4596 3416 3452 3453 3417; 4597 3417 3453 3454 3418;4598 3418 3454 3455 3419; 4599 3419 3455 3456 3420; 4600 3420 3456 3457 3421;4601 3421 3457 3458 3422; 4602 3422 3458 3459 3423; 4603 3423 3459 3460 3424;4604 3424 3460 3461 3425; 4605 3425 3461 3462 3426; 4606 3426 3462 3463 3427;4607 3427 3463 3464 3428; 4608 3428 3464 3465 3429; 4609 3465 3501 3502 3466;4610 3466 3502 3503 3467; 4611 3467 3503 3504 3468; 4612 3468 3504 3505 3469;4613 3469 3505 3506 3470; 4614 3470 3506 3507 3471; 4615 3471 3507 3508 3472;4616 3472 3508 3509 3473; 4617 3473 3509 3510 3474; 4618 3474 3510 3475 3439;4619 3439 3475 3476 3440; 4620 3440 3476 3477 3441; 4621 3441 3477 3478 3442;4622 3442 3478 3479 3443; 4623 3443 3479 3480 3444; 4624 3444 3480 3481 3445;4625 3445 3481 3482 3446; 4626 3446 3482 3483 3447; 4627 3447 3483 3484 3448;4628 3448 3484 3485 3449; 4629 3449 3485 3486 3450; 4630 3450 3486 3487 3451;4631 3451 3487 3488 3452; 4632 3452 3488 3489 3453; 4633 3453 3489 3490 3454;4634 3454 3490 3491 3455; 4635 3455 3491 3492 3456; 4636 3456 3492 3493 3457;4637 3457 3493 3494 3458; 4638 3458 3494 3495 3459; 4639 3459 3495 3496 3460;4640 3460 3496 3497 3461; 4641 3461 3497 3498 3462; 4642 3462 3498 3499 3463;4643 3463 3499 3500 3464; 4644 3464 3500 3501 3465; 4645 3501 3537 3538 3502;4646 3502 3538 3539 3503; 4647 3503 3539 3540 3504; 4648 3504 3540 3541 3505;4649 3505 3541 3542 3506; 4650 3506 3542 3543 3507; 4651 3507 3543 3544 3508;4652 3508 3544 3545 3509; 4653 3509 3545 3546 3510; 4654 3510 3546 3511 3475;4655 3475 3511 3512 3476; 4656 3476 3512 3513 3477; 4657 3477 3513 3514 3478;4658 3478 3514 3515 3479; 4659 3479 3515 3516 3480; 4660 3480 3516 3517 3481;4661 3481 3517 3518 3482; 4662 3482 3518 3519 3483; 4663 3483 3519 3520 3484;4664 3484 3520 3521 3485; 4665 3485 3521 3522 3486; 4666 3486 3522 3523 3487;4667 3487 3523 3524 3488; 4668 3488 3524 3525 3489; 4669 3489 3525 3526 3490;4670 3490 3526 3527 3491; 4671 3491 3527 3528 3492; 4672 3492 3528 3529 3493;4673 3493 3529 3530 3494; 4674 3494 3530 3531 3495; 4675 3495 3531 3532 3496;4676 3496 3532 3533 3497; 4677 3497 3533 3534 3498; 4678 3498 3534 3535 3499;4679 3499 3535 3536 3500; 4680 3500 3536 3537 3501; 4681 3537 3573 3574 3538;4682 3538 3574 3575 3539; 4683 3539 3575 3576 3540; 4684 3540 3576 3577 3541;4685 3541 3577 3578 3542; 4686 3542 3578 3579 3543; 4687 3543 3579 3580 3544;4688 3544 3580 3581 3545; 4689 3545 3581 3582 3546; 4690 3546 3582 3547 3511;4691 3511 3547 3548 3512; 4692 3512 3548 3549 3513; 4693 3513 3549 3550 3514;4694 3514 3550 3551 3515; 4695 3515 3551 3552 3516; 4696 3516 3552 3553 3517;4697 3517 3553 3554 3518; 4698 3518 3554 3555 3519; 4699 3519 3555 3556 3520;4700 3520 3556 3557 3521; 4701 3521 3557 3558 3522; 4702 3522 3558 3559 3523;4703 3523 3559 3560 3524; 4704 3524 3560 3561 3525; 4705 3525 3561 3562 3526;4706 3526 3562 3563 3527; 4707 3527 3563 3564 3528; 4708 3528 3564 3565 3529;4709 3529 3565 3566 3530; 4710 3530 3566 3567 3531; 4711 3531 3567 3568 3532;4712 3532 3568 3569 3533; 4713 3533 3569 3570 3534; 4714 3534 3570 3571 3535;4715 3535 3571 3572 3536; 4716 3536 3572 3573 3537; 4717 3573 3609 3610 3574;4718 3574 3610 3611 3575; 4719 3575 3611 3612 3576; 4720 3576 3612 3613 3577;4721 3577 3613 3614 3578; 4722 3578 3614 3615 3579; 4723 3579 3615 3616 3580;4724 3580 3616 3617 3581; 4725 3581 3617 3618 3582; 4726 3582 3618 3583 3547;4727 3547 3583 3584 3548; 4728 3548 3584 3585 3549; 4729 3549 3585 3586 3550;4730 3550 3586 3587 3551; 4731 3551 3587 3588 3552; 4732 3552 3588 3589 3553;4733 3553 3589 3590 3554; 4734 3554 3590 3591 3555; 4735 3555 3591 3592 3556;4736 3556 3592 3593 3557; 4737 3557 3593 3594 3558; 4738 3558 3594 3595 3559;4739 3559 3595 3596 3560; 4740 3560 3596 3597 3561; 4741 3561 3597 3598 3562;4742 3562 3598 3599 3563; 4743 3563 3599 3600 3564; 4744 3564 3600 3601 3565;4745 3565 3601 3602 3566; 4746 3566 3602 3603 3567; 4747 3567 3603 3604 3568;4748 3568 3604 3605 3569; 4749 3569 3605 3606 3570; 4750 3570 3606 3607 3571;4751 3571 3607 3608 3572; 4752 3572 3608 3609 3573; 4753 3609 3645 3646 3610;4754 3610 3646 3647 3611; 4755 3611 3647 3648 3612; 4756 3612 3648 3649 3613;4757 3613 3649 3650 3614; 4758 3614 3650 3651 3615; 4759 3615 3651 3652 3616;4760 3616 3652 3653 3617; 4761 3617 3653 3654 3618; 4762 3618 3654 3619 3583;4763 3583 3619 3620 3584; 4764 3584 3620 3621 3585; 4765 3585 3621 3622 3586;4766 3586 3622 3623 3587; 4767 3587 3623 3624 3588; 4768 3588 3624 3625 3589;4769 3589 3625 3626 3590; 4770 3590 3626 3627 3591; 4771 3591 3627 3628 3592;4772 3592 3628 3629 3593; 4773 3593 3629 3630 3594; 4774 3594 3630 3631 3595;4775 3595 3631 3632 3596; 4776 3596 3632 3633 3597; 4777 3597 3633 3634 3598;4778 3598 3634 3635 3599; 4779 3599 3635 3636 3600; 4780 3600 3636 3637 3601;4781 3601 3637 3638 3602; 4782 3602 3638 3639 3603; 4783 3603 3639 3640 3604;4784 3604 3640 3641 3605; 4785 3605 3641 3642 3606; 4786 3606 3642 3643 3607;4787 3607 3643 3644 3608; 4788 3608 3644 3645 3609; 4789 3645 3681 3682 3646;4790 3646 3682 3683 3647; 4791 3647 3683 3684 3648; 4792 3648 3684 3685 3649;4793 3649 3685 3686 3650; 4794 3650 3686 3687 3651; 4795 3651 3687 3688 3652;4796 3652 3688 3689 3653; 4797 3653 3689 3690 3654; 4798 3654 3690 3655 3619;4799 3619 3655 3656 3620; 4800 3620 3656 3657 3621; 4801 3621 3657 3658 3622;4802 3622 3658 3659 3623; 4803 3623 3659 3660 3624; 4804 3624 3660 3661 3625;4805 3625 3661 3662 3626; 4806 3626 3662 3663 3627; 4807 3627 3663 3664 3628;4808 3628 3664 3665 3629; 4809 3629 3665 3666 3630; 4810 3630 3666 3667 3631;4811 3631 3667 3668 3632; 4812 3632 3668 3669 3633; 4813 3633 3669 3670 3634;4814 3634 3670 3671 3635; 4815 3635 3671 3672 3636; 4816 3636 3672 3673 3637;4817 3637 3673 3674 3638; 4818 3638 3674 3675 3639; 4819 3639 3675 3676 3640;4820 3640 3676 3677 3641; 4821 3641 3677 3678 3642; 4822 3642 3678 3679 3643;4823 3643 3679 3680 3644; 4824 3644 3680 3681 3645; 4825 3681 3717 3718 3682;4826 3682 3718 3719 3683; 4827 3683 3719 3720 3684; 4828 3684 3720 3721 3685;4829 3685 3721 3722 3686; 4830 3686 3722 3723 3687; 4831 3687 3723 3724 3688;4832 3688 3724 3725 3689; 4833 3689 3725 3726 3690; 4834 3690 3726 3691 3655;4835 3655 3691 3692 3656; 4836 3656 3692 3693 3657; 4837 3657 3693 3694 3658;4838 3658 3694 3695 3659; 4839 3659 3695 3696 3660; 4840 3660 3696 3697 3661;4841 3661 3697 3698 3662; 4842 3662 3698 3699 3663; 4843 3663 3699 3700 3664;4844 3664 3700 3701 3665; 4845 3665 3701 3702 3666; 4846 3666 3702 3703 3667;4847 3667 3703 3704 3668; 4848 3668 3704 3705 3669; 4849 3669 3705 3706 3670;4850 3670 3706 3707 3671; 4851 3671 3707 3708 3672; 4852 3672 3708 3709 3673;4853 3673 3709 3710 3674; 4854 3674 3710 3711 3675; 4855 3675 3711 3712 3676;4856 3676 3712 3713 3677; 4857 3677 3713 3714 3678; 4858 3678 3714 3715 3679;4859 3679 3715 3716 3680; 4860 3680 3716 3717 3681; 4861 3717 3753 3754 3718;4862 3718 3754 3755 3719; 4863 3719 3755 3756 3720; 4864 3720 3756 3757 3721;4865 3721 3757 3758 3722; 4866 3722 3758 3759 3723; 4867 3723 3759 3760 3724;4868 3724 3760 3761 3725; 4869 3725 3761 3762 3726; 4870 3726 3762 3727 3691;4871 3691 3727 3728 3692; 4872 3692 3728 3729 3693; 4873 3693 3729 3730 3694;4874 3694 3730 3731 3695; 4875 3695 3731 3732 3696; 4876 3696 3732 3733 3697;4877 3697 3733 3734 3698; 4878 3698 3734 3735 3699; 4879 3699 3735 3736 3700;4880 3700 3736 3737 3701; 4881 3701 3737 3738 3702; 4882 3702 3738 3739 3703;4883 3703 3739 3740 3704; 4884 3704 3740 3741 3705; 4885 3705 3741 3742 3706;4886 3706 3742 3743 3707; 4887 3707 3743 3744 3708; 4888 3708 3744 3745 3709;4889 3709 3745 3746 3710; 4890 3710 3746 3747 3711; 4891 3711 3747 3748 3712;4892 3712 3748 3749 3713; 4893 3713 3749 3750 3714; 4894 3714 3750 3751 3715;4895 3715 3751 3752 3716; 4896 3716 3752 3753 3717; 4897 3753 3789 3790 3754;4898 3754 3790 3791 3755; 4899 3755 3791 3792 3756; 4900 3756 3792 3793 3757;4901 3757 3793 3794 3758; 4902 3758 3794 3795 3759; 4903 3759 3795 3796 3760;4904 3760 3796 3797 3761; 4905 3761 3797 3798 3762; 4906 3762 3798 3763 3727;4907 3727 3763 3764 3728; 4908 3728 3764 3765 3729; 4909 3729 3765 3766 3730;4910 3730 3766 3767 3731; 4911 3731 3767 3768 3732; 4912 3732 3768 3769 3733;4913 3733 3769 3770 3734; 4914 3734 3770 3771 3735; 4915 3735 3771 3772 3736;4916 3736 3772 3773 3737; 4917 3737 3773 3774 3738; 4918 3738 3774 3775 3739;4919 3739 3775 3776 3740; 4920 3740 3776 3777 3741; 4921 3741 3777 3778 3742;4922 3742 3778 3779 3743; 4923 3743 3779 3780 3744; 4924 3744 3780 3781 3745;4925 3745 3781 3782 3746; 4926 3746 3782 3783 3747; 4927 3747 3783 3784 3748;4928 3748 3784 3785 3749; 4929 3749 3785 3786 3750; 4930 3750 3786 3787 3751;4931 3751 3787 3788 3752; 4932 3752 3788 3789 3753; 4933 3789 3825 3826 3790;4934 3790 3826 3827 3791; 4935 3791 3827 3828 3792; 4936 3792 3828 3829 3793;4937 3793 3829 3830 3794; 4938 3794 3830 3831 3795; 4939 3795 3831 3832 3796;4940 3796 3832 3833 3797; 4941 3797 3833 3834 3798; 4942 3798 3834 3799 3763;4943 3763 3799 3800 3764; 4944 3764 3800 3801 3765; 4945 3765 3801 3802 3766;4946 3766 3802 3803 3767; 4947 3767 3803 3804 3768; 4948 3768 3804 3805 3769;4949 3769 3805 3806 3770; 4950 3770 3806 3807 3771; 4951 3771 3807 3808 3772;4952 3772 3808 3809 3773; 4953 3773 3809 3810 3774; 4954 3774 3810 3811 3775;4955 3775 3811 3812 3776; 4956 3776 3812 3813 3777; 4957 3777 3813 3814 3778;4958 3778 3814 3815 3779; 4959 3779 3815 3816 3780; 4960 3780 3816 3817 3781;4961 3781 3817 3818 3782; 4962 3782 3818 3819 3783; 4963 3783 3819 3820 3784;4964 3784 3820 3821 3785; 4965 3785 3821 3822 3786; 4966 3786 3822 3823 3787;4967 3787 3823 3824 3788; 4968 3788 3824 3825 3789; 4969 3825 3861 3862 3826;4970 3826 3862 3863 3827; 4971 3827 3863 3864 3828; 4972 3828 3864 3865 3829;4973 3829 3865 3866 3830; 4974 3830 3866 3867 3831; 4975 3831 3867 3868 3832;4976 3832 3868 3869 3833; 4977 3833 3869 3870 3834; 4978 3834 3870 3835 3799;4979 3799 3835 3836 3800; 4980 3800 3836 3837 3801; 4981 3801 3837 3838 3802;4982 3802 3838 3839 3803; 4983 3803 3839 3840 3804; 4984 3804 3840 3841 3805;4985 3805 3841 3842 3806; 4986 3806 3842 3843 3807; 4987 3807 3843 3844 3808;4988 3808 3844 3845 3809; 4989 3809 3845 3846 3810; 4990 3810 3846 3847 3811;4991 3811 3847 3848 3812; 4992 3812 3848 3849 3813; 4993 3813 3849 3850 3814;4994 3814 3850 3851 3815; 4995 3815 3851 3852 3816; 4996 3816 3852 3853 3817;4997 3817 3853 3854 3818; 4998 3818 3854 3855 3819; 4999 3819 3855 3856 3820;5000 3820 3856 3857 3821; 5001 3821 3857 3858 3822; 5002 3822 3858 3859 3823;5003 3823 3859 3860 3824; 5004 3824 3860 3861 3825; 5005 3861 3897 3898 3862;5006 3862 3898 3899 3863; 5007 3863 3899 3900 3864; 5008 3864 3900 3901 3865;5009 3865 3901 3902 3866; 5010 3866 3902 3903 3867; 5011 3867 3903 3904 3868;5012 3868 3904 3905 3869; 5013 3869 3905 3906 3870; 5014 3870 3906 3871 3835;5015 3835 3871 3872 3836; 5016 3836 3872 3873 3837; 5017 3837 3873 3874 3838;5018 3838 3874 3875 3839; 5019 3839 3875 3876 3840; 5020 3840 3876 3877 3841;5021 3841 3877 3878 3842; 5022 3842 3878 3879 3843; 5023 3843 3879 3880 3844;5024 3844 3880 3881 3845; 5025 3845 3881 3882 3846; 5026 3846 3882 3883 3847;5027 3847 3883 3884 3848; 5028 3848 3884 3885 3849; 5029 3849 3885 3886 3850;5030 3850 3886 3887 3851; 5031 3851 3887 3888 3852; 5032 3852 3888 3889 3853;5033 3853 3889 3890 3854; 5034 3854 3890 3891 3855; 5035 3855 3891 3892 3856;5036 3856 3892 3893 3857; 5037 3857 3893 3894 3858; 5038 3858 3894 3895 3859;5039 3859 3895 3896 3860; 5040 3860 3896 3897 3861; 5041 3897 3933 3934 3898;5042 3898 3934 3935 3899; 5043 3899 3935 3936 3900; 5044 3900 3936 3937 3901;5045 3901 3937 3938 3902; 5046 3902 3938 3939 3903; 5047 3903 3939 3940 3904;5048 3904 3940 3941 3905; 5049 3905 3941 3942 3906; 5050 3906 3942 3907 3871;5051 3871 3907 3908 3872; 5052 3872 3908 3909 3873; 5053 3873 3909 3910 3874;5054 3874 3910 3911 3875; 5055 3875 3911 3912 3876; 5056 3876 3912 3913 3877;5057 3877 3913 3914 3878; 5058 3878 3914 3915 3879; 5059 3879 3915 3916 3880;5060 3880 3916 3917 3881; 5061 3881 3917 3918 3882; 5062 3882 3918 3919 3883;5063 3883 3919 3920 3884; 5064 3884 3920 3921 3885; 5065 3885 3921 3922 3886;5066 3886 3922 3923 3887; 5067 3887 3923 3924 3888; 5068 3888 3924 3925 3889;5069 3889 3925 3926 3890; 5070 3890 3926 3927 3891; 5071 3891 3927 3928 3892;5072 3892 3928 3929 3893; 5073 3893 3929 3930 3894; 5074 3894 3930 3931 3895;5075 3895 3931 3932 3896; 5076 3896 3932 3933 3897; 5077 3933 3969 3970 3934;5078 3934 3970 3971 3935; 5079 3935 3971 3972 3936; 5080 3936 3972 3973 3937;5081 3937 3973 3974 3938; 5082 3938 3974 3975 3939; 5083 3939 3975 3976 3940;5084 3940 3976 3977 3941; 5085 3941 3977 3978 3942; 5086 3942 3978 3943 3907;5087 3907 3943 3944 3908; 5088 3908 3944 3945 3909; 5089 3909 3945 3946 3910;5090 3910 3946 3947 3911; 5091 3911 3947 3948 3912; 5092 3912 3948 3949 3913;5093 3913 3949 3950 3914; 5094 3914 3950 3951 3915; 5095 3915 3951 3952 3916;5096 3916 3952 3953 3917; 5097 3917 3953 3954 3918; 5098 3918 3954 3955 3919;5099 3919 3955 3956 3920; 5100 3920 3956 3957 3921; 5101 3921 3957 3958 3922;5102 3922 3958 3959 3923; 5103 3923 3959 3960 3924; 5104 3924 3960 3961 3925;5105 3925 3961 3962 3926; 5106 3926 3962 3963 3927; 5107 3927 3963 3964 3928;5108 3928 3964 3965 3929; 5109 3929 3965 3966 3930; 5110 3930 3966 3967 3931;5111 3931 3967 3968 3932; 5112 3932 3968 3969 3933; 5113 3969 4005 4006 3970;5114 3970 4006 4007 3971; 5115 3971 4007 4008 3972; 5116 3972 4008 4009 3973;5117 3973 4009 4010 3974; 5118 3974 4010 4011 3975; 5119 3975 4011 4012 3976;5120 3976 4012 4013 3977; 5121 3977 4013 4014 3978; 5122 3978 4014 3979 3943;5123 3943 3979 3980 3944; 5124 3944 3980 3981 3945; 5125 3945 3981 3982 3946;5126 3946 3982 3983 3947; 5127 3947 3983 3984 3948; 5128 3948 3984 3985 3949;5129 3949 3985 3986 3950; 5130 3950 3986 3987 3951; 5131 3951 3987 3988 3952;5132 3952 3988 3989 3953; 5133 3953 3989 3990 3954; 5134 3954 3990 3991 3955;5135 3955 3991 3992 3956; 5136 3956 3992 3993 3957; 5137 3957 3993 3994 3958;5138 3958 3994 3995 3959; 5139 3959 3995 3996 3960; 5140 3960 3996 3997 3961;5141 3961 3997 3998 3962; 5142 3962 3998 3999 3963; 5143 3963 3999 4000 3964;5144 3964 4000 4001 3965; 5145 3965 4001 4002 3966; 5146 3966 4002 4003 3967;5147 3967 4003 4004 3968; 5148 3968 4004 4005 3969; 5149 4005 4041 4042 4006;5150 4006 4042 4043 4007; 5151 4007 4043 4044 4008; 5152 4008 4044 4045 4009;5153 4009 4045 4046 4010; 5154 4010 4046 4047 4011; 5155 4011 4047 4048 4012;5156 4012 4048 4049 4013; 5157 4013 4049 4050 4014; 5158 4014 4050 4015 3979;5159 3979 4015 4016 3980; 5160 3980 4016 4017 3981; 5161 3981 4017 4018 3982;5162 3982 4018 4019 3983; 5163 3983 4019 4020 3984; 5164 3984 4020 4021 3985;5165 3985 4021 4022 3986; 5166 3986 4022 4023 3987; 5167 3987 4023 4024 3988;5168 3988 4024 4025 3989; 5169 3989 4025 4026 3990; 5170 3990 4026 4027 3991;5171 3991 4027 4028 3992; 5172 3992 4028 4029 3993; 5173 3993 4029 4030 3994;5174 3994 4030 4031 3995; 5175 3995 4031 4032 3996; 5176 3996 4032 4033 3997;5177 3997 4033 4034 3998; 5178 3998 4034 4035 3999; 5179 3999 4035 4036 4000;5180 4000 4036 4037 4001; 5181 4001 4037 4038 4002; 5182 4002 4038 4039 4003;5183 4003 4039 4040 4004; 5184 4004 4040 4041 4005; 5185 4041 4077 4078 4042;5186 4042 4078 4079 4043; 5187 4043 4079 4080 4044; 5188 4044 4080 4081 4045;5189 4045 4081 4082 4046; 5190 4046 4082 4083 4047; 5191 4047 4083 4084 4048;5192 4048 4084 4085 4049; 5193 4049 4085 4086 4050; 5194 4050 4086 4051 4015;5195 4015 4051 4052 4016; 5196 4016 4052 4053 4017; 5197 4017 4053 4054 4018;5198 4018 4054 4055 4019; 5199 4019 4055 4056 4020; 5200 4020 4056 4057 4021;5201 4021 4057 4058 4022; 5202 4022 4058 4059 4023; 5203 4023 4059 4060 4024;5204 4024 4060 4061 4025; 5205 4025 4061 4062 4026; 5206 4026 4062 4063 4027;5207 4027 4063 4064 4028; 5208 4028 4064 4065 4029; 5209 4029 4065 4066 4030;5210 4030 4066 4067 4031; 5211 4031 4067 4068 4032; 5212 4032 4068 4069 4033;5213 4033 4069 4070 4034; 5214 4034 4070 4071 4035; 5215 4035 4071 4072 4036;5216 4036 4072 4073 4037; 5217 4037 4073 4074 4038; 5218 4038 4074 4075 4039;5219 4039 4075 4076 4040; 5220 4040 4076 4077 4041; 5221 4077 4113 4114 4078;5222 4078 4114 4115 4079; 5223 4079 4115 4116 4080; 5224 4080 4116 4117 4081;5225 4081 4117 4118 4082; 5226 4082 4118 4119 4083; 5227 4083 4119 4120 4084;5228 4084 4120 4121 4085; 5229 4085 4121 4122 4086; 5230 4086 4122 4087 4051;5231 4051 4087 4088 4052; 5232 4052 4088 4089 4053; 5233 4053 4089 4090 4054;5234 4054 4090 4091 4055; 5235 4055 4091 4092 4056; 5236 4056 4092 4093 4057;5237 4057 4093 4094 4058; 5238 4058 4094 4095 4059; 5239 4059 4095 4096 4060;5240 4060 4096 4097 4061; 5241 4061 4097 4098 4062; 5242 4062 4098 4099 4063;5243 4063 4099 4100 4064; 5244 4064 4100 4101 4065; 5245 4065 4101 4102 4066;5246 4066 4102 4103 4067; 5247 4067 4103 4104 4068; 5248 4068 4104 4105 4069;5249 4069 4105 4106 4070; 5250 4070 4106 4107 4071; 5251 4071 4107 4108 4072;5252 4072 4108 4109 4073; 5253 4073 4109 4110 4074; 5254 4074 4110 4111 4075;5255 4075 4111 4112 4076; 5256 4076 4112 4113 4077; 5257 4113 4149 4150 4114;5258 4114 4150 4151 4115; 5259 4115 4151 4152 4116; 5260 4116 4152 4153 4117;5261 4117 4153 4154 4118; 5262 4118 4154 4155 4119; 5263 4119 4155 4156 4120;5264 4120 4156 4157 4121; 5265 4121 4157 4158 4122; 5266 4122 4158 4123 4087;5267 4087 4123 4124 4088; 5268 4088 4124 4125 4089; 5269 4089 4125 4126 4090;5270 4090 4126 4127 4091; 5271 4091 4127 4128 4092; 5272 4092 4128 4129 4093;5273 4093 4129 4130 4094; 5274 4094 4130 4131 4095; 5275 4095 4131 4132 4096;5276 4096 4132 4133 4097; 5277 4097 4133 4134 4098; 5278 4098 4134 4135 4099;5279 4099 4135 4136 4100; 5280 4100 4136 4137 4101; 5281 4101 4137 4138 4102;5282 4102 4138 4139 4103; 5283 4103 4139 4140 4104; 5284 4104 4140 4141 4105;5285 4105 4141 4142 4106; 5286 4106 4142 4143 4107; 5287 4107 4143 4144 4108;5288 4108 4144 4145 4109; 5289 4109 4145 4146 4110; 5290 4110 4146 4147 4111;5291 4111 4147 4148 4112; 5292 4112 4148 4149 4113; 5293 4149 4185 4186 4150;5294 4150 4186 4187 4151; 5295 4151 4187 4188 4152; 5296 4152 4188 4189 4153;5297 4153 4189 4190 4154; 5298 4154 4190 4191 4155; 5299 4155 4191 4192 4156;5300 4156 4192 4193 4157; 5301 4157 4193 4194 4158; 5302 4158 4194 4159 4123;5303 4123 4159 4160 4124; 5304 4124 4160 4161 4125; 5305 4125 4161 4162 4126;5306 4126 4162 4163 4127; 5307 4127 4163 4164 4128; 5308 4128 4164 4165 4129;5309 4129 4165 4166 4130; 5310 4130 4166 4167 4131; 5311 4131 4167 4168 4132;5312 4132 4168 4169 4133; 5313 4133 4169 4170 4134; 5314 4134 4170 4171 4135;5315 4135 4171 4172 4136; 5316 4136 4172 4173 4137; 5317 4137 4173 4174 4138;5318 4138 4174 4175 4139; 5319 4139 4175 4176 4140; 5320 4140 4176 4177 4141;5321 4141 4177 4178 4142; 5322 4142 4178 4179 4143; 5323 4143 4179 4180 4144;5324 4144 4180 4181 4145; 5325 4145 4181 4182 4146; 5326 4146 4182 4183 4147;5327 4147 4183 4184 4148; 5328 4148 4184 4185 4149;START GROUP DEFINITIONELEMENT_PILE 73 TO 108 145 TO 180 253 TO 288 361 TO 396 469 TO 504 577 TO 612 685 -686 TO 720 793 TO 828 901 TO 936 1009 TO 1044 1117 TO 1152 1225 TO 1260 1333 -1334 TO 1368 1441 TO 1476 1549 TO 1584 1657 TO 1692 1765 TO 5328MEMBEREND GROUP DEFINITIONELEMENT PROPERTY263 TO 280 371 TO 388 479 TO 496 587 TO 604 695 TO 712 803 TO 820 911 TO 928 -1019 TO 1036 1127 TO 1144 1235 TO 1252 1343 TO 1360 1451 TO 1468 -1559 TO 1576 1667 TO 1684 1775 TO 1792 1811 TO 1828 1847 TO 1864 -1883 TO 1900 1919 TO 1936 1955 TO 1972 1991 TO 2008 2027 TO 2044 -2063 TO 2080 2099 TO 2116 2135 TO 2152 2171 TO 2188 2207 TO 2224 -2243 TO 2260 2279 TO 2296 2315 TO 2332 2351 TO 2368 2387 TO 2404 -2423 TO 2440 2459 TO 2476 2495 TO 2512 2531 TO 2548 2567 TO 2584 -2603 TO 2620 2639 TO 2656 2675 TO 2692 2711 TO 2728 2747 TO 2764 -2783 TO 2800 2819 TO 2836 2855 TO 2872 2891 TO 2908 2927 TO 2944 -2963 TO 2980 2999 TO 3016 3035 TO 3052 3071 TO 3088 3107 TO 3124 -3143 TO 3160 3179 TO 3196 3215 TO 3232 3251 TO 3268 3287 TO 3304 -3323 TO 3340 3359 TO 3376 3395 TO 3412 3431 TO 3448 3467 TO 3484 -3503 TO 3520 3539 TO 3556 3575 TO 3592 3611 TO 3628 3647 TO 3664 -3683 TO 3700 3719 TO 3736 3755 TO 3772 3791 TO 3808 3827 TO 3844 -3863 TO 3880 3899 TO 3916 3935 TO 3952 3971 TO 3988 4007 TO 4024 -4043 TO 4060 4079 TO 4096 4115 TO 4132 4151 TO 4168 4187 TO 4204 -4223 TO 4240 4259 TO 4276 4295 TO 4312 4331 TO 4348 4367 TO 4384 -4403 TO 4420 4439 TO 4456 4475 TO 4492 4511 TO 4528 4547 TO 4564 -4583 TO 4600 4619 THICKNESS 0.0250644620 TO 4636 4655 TO 4672 4691 TO 4708 4727 TO 4744 4763 TO 4780 4799 TO 4816 -4835 TO 4852 5015 TO 5032 5051 TO 5068 5087 TO 5104 5123 TO 5140 -5159 TO 5176 5195 TO 5212 5231 TO 5248 5267 TO 5284 5303 TO 5319 -5320 THICKNESS 0.025064253 TO 262 281 TO 288 361 TO 370 389 TO 396 469 TO 478 497 TO 504 577 TO 586 -605 TO 612 685 TO 694 713 TO 720 793 TO 802 821 TO 828 901 TO 910 -929 TO 936 1009 TO 1018 1037 TO 1044 1117 TO 1126 1145 TO 1152 1225 TO 1234 -1253 TO 1260 1333 TO 1342 1361 TO 1368 1441 TO 1450 1469 TO 1476 -1549 TO 1558 1577 TO 1584 1657 TO 1666 1685 TO 1692 1765 TO 1774 -1793 TO 1810 1829 TO 1846 1865 TO 1882 1901 TO 1918 1937 TO 1954 -1973 TO 1990 2009 TO 2026 2045 TO 2062 2081 TO 2098 2117 TO 2134 -2153 TO 2170 2189 TO 2206 2225 TO 2242 2261 TO 2278 2297 TO 2314 -2333 TO 2350 2369 TO 2386 2405 TO 2422 2441 TO 2458 2477 TO 2494 -2513 TO 2530 2549 TO 2566 2585 TO 2602 2621 TO 2638 2657 TO 2674 -2693 TO 2710 2729 TO 2746 2765 TO 2782 2801 TO 2818 2837 TO 2854 -2873 TO 2890 2909 TO 2926 2945 TO 2962 2981 TO 2998 3017 TO 3034 -3053 TO 3070 3089 TO 3106 3125 TO 3142 3161 TO 3178 3197 TO 3214 -3233 TO 3250 3269 TO 3286 3305 TO 3322 3341 TO 3358 3377 TO 3394 -3413 TO 3430 3449 TO 3466 3485 TO 3502 3521 TO 3538 3557 TO 3574 -3593 TO 3610 3629 TO 3646 3665 TO 3682 3701 TO 3718 3737 TO 3754 -3773 TO 3790 3809 TO 3826 3845 TO 3862 3881 TO 3898 3917 TO 3934 -3953 TO 3970 3989 TO 4006 4025 TO 4042 4061 TO 4078 4097 THICKNESS 0.023734098 TO 4114 4133 TO 4150 4169 TO 4186 4205 TO 4222 4241 TO 4258 4277 TO 4294 -4313 TO 4330 4349 TO 4366 4385 TO 4402 4421 TO 4438 4457 TO 4474 -4493 TO 4510 4529 TO 4546 4565 TO 4582 4601 TO 4618 4637 TO 4654 -4673 TO 4690 4709 TO 4726 4745 TO 4762 4781 TO 4798 4817 TO 4834 -4853 TO 4860 5005 TO 5014 5033 TO 5050 5069 TO 5086 5105 TO 5122 -5141 TO 5158 5177 TO 5194 5213 TO 5230 5249 TO 5266 5285 TO 5302 -5321 TO 5328 THICKNESS 0.0237373 TO 108 145 TO 180 4861 TO 5004 THICKNESS 0.05DEFINE MATERIAL STARTISOTROPIC STEELE 2.05e+08POISSON 0.3DENSITY 76.8195ALPHA 1.2e-05DAMP 0.03ISOTROPIC CONCRETEE 2.17185e+07POISSON 0.17DENSITY 23.5616ALPHA 1e-05DAMP 0.05END DEFINE MATERIALCONSTANTSMATERIAL STEEL ALLSUPPORTS2 TO 37 FIXEDLOAD 3 LOADTYPE None TITLE LOAD CASE 3JOINT LOAD3763 FY 03764 FY -299.5563765 FY -590.2473766 FY -862.7963767 FY -1109.163768 FY -1321.923769 FY -1494.483770 FY -1621.483771 FY -1699.413772 FY -1725.593773 FY -1699.413774 FY -1621.483775 FY -1494.483776 FY -1321.923777 FY -1109.163778 FY -862.7963779 FY -590.2473780 FY -299.5563781 FY 03782 FY 316.1553783 FY 622.9533784 FY 910.6043785 FY 1170.623786 FY 1395.173787 FY 1577.293788 FY 1711.333789 FY 1793.573790 FY 1821.213791 FY 1793.573792 FY 1711.333793 FY 1577.293794 FY 1395.173795 FY 1170.623796 FY 910.6043797 FY 622.9533798 FY 316.1553763 FY -97.62353764 FY -97.62353765 FY -97.62353766 FY -97.62353767 FY -97.62353768 FY -97.62353769 FY -97.62353770 FY -97.62353771 FY -97.62353772 FY -97.62353773 FY -97.62353774 FY -97.62353775 FY -97.62353776 FY -97.62353777 FY -97.62353778 FY -97.62353779 FY -97.62353780 FY -97.62353781 FY -97.62353782 FY -97.62353783 FY -97.62353784 FY -97.62353785 FY -97.62353786 FY -97.62353787 FY -97.62353788 FY -97.62353789 FY -97.62353790 FY -97.62353791 FY -97.62353792 FY -97.62353793 FY -97.62353794 FY -97.62353795 FY -97.62353796 FY -97.62353797 FY -97.62353798 FY -97.6235PERFORM BUCKLING ANALYSISFINISH
PERFORM BUCKLING EIGEN works fine in the most recent STAAD.Pro CE version 22.03.00.28. If you are not using this version yet, please upgrade and try again.
I am using 21.00.02.43 and don't have access to an upgrade (or at least I can't work out how to get one through my company).
Therefore unfortunately upgrading doesn't appear to be an option. Therefore if anyone knows a way to see the buckled shapes in Staad Pro Connect Build 21.00.02.43 it would be greatly appreciated.
Go to Analysis -> Define Commands -> Perform Buckling Analysis, select the Eigen Method and click add. If you don't see the Eigen Method option, add general buckling command.After the analysis, go to the Postprocessing workflow and click on Layouts -> Buckling in the Dynamics icon group.
