Member Release with Spring Specification
I have a question about Specifications for Beams
I have a model of Base Plate using FEM, Bolts are assumed to be members then I place a release with spring specification.
My question is, Is the member will behave as spring? or my total assumption for the bolt is wrong.Also the inputbox for spring value is locked and unchecked after I reopen sa specs window.
I'm not sure if this is a bug.
Please see attached files.
BP_Conn2.STD
