RAM and Revit Worksets
Is there a way to make the RAM/Revit Link import the RAM changes on the proper Revit Worksets? When importing an updated RAM model, every thing is placed on the current Revit workset. This means that you have to manually change the workset for everything that was revised in RAM (can very very time consuming). I am using RAM/Revit Link v2.4.2.0 and Revit Structure Suite 2009 build 20081118_1045.
Thanks, Michael
