I wanted an excel VBA programme by which i can get the plate corner moments/stresses for a particular group of plates. If anyone could share an excel with VBA code then it will be helpful as it saves lot of time.
I can find an example in help file. Check if it helps.
file:///C:/Program%20Files/Bentley/Engineering/STAAD.Pro%20CONNECT%20Edition/Help/OSAPP/group___plate_rlt.html#ga2ee9f974e72eec15760b7e6da620d7c8
You can access the open staad help from File> help> Open STAAD help.
Hello Abhishek,
Thank-you for your response. but im new to VBA, so it would be helpful if someone writes me a code for it and shares the excel. It will be helpful.
