Dear All,
I hope you are all doing well. I am in the middle of a crucial assignment for which I am doing Response Spectrum analysis using custom spectrum.
Base Shear and load sign.txtSeismic Spectrum.xlsx
Client has provided the Ct and x values only. I am having the below queries.
1. The base shear value i am getting is too low for the structure.
2. I want to know if the signs for loads in Definition of loads are correct.
3. Also, i would like to know if the scale of 9.81 is correct? (I am always confused about it ). I have attached the spectrum calculation - Note the Ao term has a g term (0.4g) hence, Sa/g is calculated for spectrum
Thanks a lot in Advance.
Best Regards,
PNP
Gentle reminder. Any lead to previous forum queries/blogs would help.
