ASCE 7-16 Cs Factors
Why doesn't the program calculate Cs per equation 12.8-5 ? Cs used is calculated from Eq 12-8-3. If calculated per 12.8-5 the Cs=0.044xSds=0.046 (which is the minimum Cs value to be used) is greater than 0.034.
