MSTower Section Library
Hi All,
I am trying to add some new sections to model a monopole in MSTower through File>Configure>Edit Section Library etc... however, when I build the model the build report suggests it can not find the sections in the library. I have noticed that the files in the MSTower program folder are not updating, so believe this is the issue, however when using MSTower any new sections I add are still there when I go to edit.
Attached some clips to help explain the issue more clearly:
Build Report        The sections in the library                                                           Program files not updating
Note: I am trying to edit the UKJB library, which hasn't updated since February 2019!
Any help would be appreciated,
James
Parents Reply Children
