Hello everybody.
Now I am working in staad y want to design whit direct analysis. How can I create notional loads and repetitive loads in the physical modeler?
As of now physical modeler cannot generate notional loads. This is something that is going to be made available in future versions.
You can create REPEAT LOADs if you go to File > Options and check the following option. The combinations will then be created as REPEAT LOADs.
Wanted to mention here that the ability to add notional loads inside the physical modeler, will be part of the STAAD.Pro CONNECT Edition Update 5 which is scheduled to be released in a week.
Hello. Now that notional loads can be applied in the Physical model... how is that accomplished?
The process is explained in the STAAD.Pro Physical Modeler Help section Applying Loads > Working with Load Combinations > To add a notional loads.
