COLUMN/PEDESAL DESIGN - REINFORCEMENT LAYOUT - STAAD PRO CONNECT SERIES
I AM USING STAAD PRO CONNECT SERIES FOR COLUMN/PEDESTAL DESIGN USING ACI-318-14. I HAVE GIVEN THE REQUIRED PARAMTER TO DESIGN THE COLUMN, BUT AFTER RUNNING THE ANALYSIS, BY DOUBLE CLICKING ON COLUMN, IT'S DOES NOT SHOW REINFORCEMENT LAYOUT. WHILE IN STAAD PRO. V8I VERSION, ITS SHOWS THE RINFORCEMENT LAYOUT.
IN LATEST VERSION - CONNECT SERIES, THIS REINFORCEMENT LAYOUT IS REMOVED OR MAYBE I AM DOING SOMTHING WRONG.
PLEASE ADVICE
I HAVE ATTACHED THE FILEDrain vessel fdn-dv - staad iCONNECT.std
