Hello I am importing a structure from Revit to RAM SS. I created an ISM depository from revit. In the previou looks very good, including slabs columns and walls. The problem is when make a new file in RAM SS from a ISM depository the beams are not exported. Only columns and floors.
What it could be the solution or the problem?
It could be that the beams are not associated with any story in Revit, or a problem of some unsupported material. If you send the Revit file or Ism.dgn I might be able to confirm.
Secure File Upload
Hello Seth, thanks for your answers, i uploaded the files, but i do not see any confirmation. Can you see them?
I looked at the file 20012_1100 E. 5th_R20_LEVEL 6.ism.dgn,which has one level of framing, beams with sections (note the columns stick up above this level). I imported that into a fresh RAM SS file, version 17.00.01.09, all default options. The beams are imported though many of them are interpreted as cantilevers because the beams are segmented in both directions. If one of the beam directions is supposed to be continuous then a single longer span beam should be used.
