question about base plate and welds
hi communities, I have 2 questions that I hope that you can help me
The first one is if in the program you can place another type of weld that is not fillet (example in a base plate), and the second would be on a base plate, try to put brackets to stiffen with plates but it does not let me change the configuration of the plates, there is some way to change it?
hola comunidad, tengo 2 preguntas que espero puedan ayudarme
la primera es si en el programa se pueden colocar otro tipo de soldadura que no sea de filete, y la segunda seria en una placa base intente ponerle cartabones para rigidizar con placas pero no me deja cambiar la configuracion de las placas, hay alguna forma de cambiarla?
