Hello all, I have a tension only members and I am trying to run a Direct analysis, and these two warnings pops up, my question is If I am using the direct analysis method then the tension only specification will be ignored ? Is there is a way to get rid of these warnings ?
You may check for the answer here: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/31879/direct-analysis-and-member-tension
Answer Verified By: Saed Al-Halteh
Much appreciated
