I am using Staad Pro Advanced Connect Edition.
I am trying to analyse a plate with multiple holes. To accomplish this task I am using the structure wizard
module for polygonal plate with holes under surface or plate models. I have successfully created the model and
after several failed attempts at transferring this item into the Staad.Pro via the 'merge Model with Staad.Pro
Model' under the file menu, I've saved the .stp file for later access. After selecting the merge command, I am
prompted whether I would like to merge this prototype with my current STAAD.Pro model. After clicking yes,
however, the module disappears but the 'Paste Prototype Model' dialog box which is outlined in the tutorial never
appears. Also Staad.Pro remains inactive and an error is given that it is occupied by another application.
As earlier mentioned, I have saved this .stp file and attempted a work-around by now importing this earlier created
file into Staad.Pro directly via the Import/export command in the file menu of Staad.pro. This also failed at
the Cis2Link dialog with an error stating "PART/21 file does not contain an analysis model. Terminating
import..."
I should also mention that I have successfully loaded the .stp file within the Structure Wizard module and viewed it as originally created with no apparent issues.
Please advise on best course of action for executing an import of this. I can provide the file(s) if needed for your
examination.
Thanks in advance for you attention.
Hello Sye,
I am also facing the same issue as disscussed above by Mr. Tirrell Day.
Just in case the above issue is resolved by you could you please help me out with the same.
I can prove you the necessay info required.
Early response is expected.
Thank You
Hello Sir,
I am facing the same problem as you discussed above. Just in case you have resolved your issue then it would be a great help if you help me out with it.
Hello Ajinkya, I can't say I have a resolution but at one point it began working. I first attempted opening and importing using V8i. This was successful. After this, subsequent edits in connect version mysteriously began to work. Don't know if related however. If you are on Skype I can assist you live
I am using Stadd. Pro V8i SS6 software.
do you have Skype or teams?
