When running my model, I noticed I was getting column design strips widths smaller than the width of my beam. I changed my settings in the strip generation tab to column strip width calc for "Code T-beam" and checked the box "design column strip for column + middle strip resultant" still no luck. What could I be missing in the settings? I attached an image as well.
Best,
Skylar Calhoun
Either program can work. If you prefer to treat the beams as linear beam elements and design them based on the tributary load from one way deck, then I suggest Ram Concrete beam. If you want the slab to act in a two-way fashion or if you prefer to use a meshed plate model then Ram Concept.
