Hi, is there an option to add fe275 rebar on column design? I found that there is an option on this on beam design but not on column. Anyone can help?
Best regards,
DM
There is option to add materials in RCDC. You can go to Column module and then do the following steps. Let me know if this helps.
Thank you for your quick response Sir! Problem solved!
