Basak Framing V4.rar
Attached herein is my analysis of a 2-Storey House in Staad Pro; the problem is that when i used this file in RCDC 6.3 to design Column, the result is all failed. It seems like the program wants me to increase the dimension of column with many rebars. Please refer below for the info:
1. Concrete = C21
2. Rebar =fy275
3. Ductile Special is selected
4. Joint Check option is selected
5. 25mm clear cover
6. preferably 16mm diam bar for main reinf & 10mm on ties
7. Location = Philippines
8. Design Code = ACI 318M-2011
9. Column dimension is (Footing to 2F Level = 200x450mm / 2F Level to Roof Beam = 200x350mm)
Hope anyone could assist me on this. Thanks in advance.
Up!
Hello Sir,
We would request you to check this issue in our latest version of RCDC 9.2.0.32 and let us know if you are facing the same issue . After the 6.3 version there are a lot of changes being done in column design and many more features have been incorporated. Please check and let us know .Meanwhile you can even upload your file to investigate at our end. .
Thanks ..
Thanks for your quick response Ma’am. I will upload the RCDC file and i will also check the 9.2.0.32 version.
hi i encounter this error also, i tried to change larger section but still doesnt pass the design, am using 8.0 rcdc
Hi Marlon ,
I would recommend you to upgrade your RCDC to the latest version of V9.04.00.128 and check if this helps you resolve the issue. There are lot of enhancements being done after the V8.
