Hello everyone,
In my model, I want to run a connection check (not through the RAM Connection module, but just through RAM Beam Design) for both beam-to-beam and beam-to-column conditions. I have a separate table of values for each condition (I edited different .CON files). The reason why they're different is because I've accounted for coped flanges in the beam-to-beam condition and analyzed it independently whereas the beam-to-column condition are based off of AISC's table values. When I run the check, I am only allowed to select one table at a time.
My question: Does RAM recognize whether a beam is supported by another beam versus a column? If so, is there a way to adjust the program (i.e. edit files) so that I would only need to run one table that would account for the two types of end condition it's seeing? This way, I would only need to output my results once. I also avoid having to go through the failed cases in one condition only to find out that it works when I run the second condition (saves time).
Thank you!
Since Tables are editable we install them here by default: C:\ProgramData\Bentley\Engineering\RAM Structural System\Tables
You can confirm the location via Ram Manager - Criteria - Master Steel table or reading the ramis.ini file.
That was it.. .my mistake. Looking in ProgramFiles instead of ProgramData.
Hi Seth, Thanks for the example connection check table. Do you have one for LRFD? I have my code set to LRFD but when running the connection check it provides values as "unfactored reaction". Do you have to change something in the .con file to get it to read out LRFD? Thanks, Brian
The .con table specifies this in the header. Here's a clip from the RamManager.pdf manual:
