Wind load not generating with area that have more than 4 members
I am updating an existing warehouse and the wind load generator does not seem to be applying where there is more than 4 members making an enclosed space. Please see the picture for reference. Any assistance would be appreciated.
  • Couple of things to check.
    1. There are no overlapping beams or duplicate beams at these panels.
    2. The intermediate nodes are not out of plane
    If the above are not an issue try using the YRANGE, XRANGE, ZRANGE options to break up the wind load generation into multiple commands ( all of these commands will be part of the same wind load case). That often helps in situations when the wind load generation fails to load all panels which are otherwise correctly modeled.
    Answer Verified By: Xuan Nguyen
