RAM Elements - Thermal Loads - Elongation due to Temperature Changes
Does RAM Elements calculate the elongation of steel beams and steel bar joists due to temperature changes? I'm working on a project that has a High Temperature of 93F, a Mean Temperature of 58F, and a Low Temperature of -2F. The Temperature Difference would be 35F or 60F. Would I need to create two models - one model having Temp.1 = 35F and the other model having Temp.1 = 60F? Where may I find the elongation results?
Thank you for your help.
