Resisting beam torsion with only shear connections - modeling
I have a tube with a torque on it. I'd like to resist this torsion through beam framing into each side (perpendicular to the main beam with the torsion on it). However, the connection will only transfer shear forces. What are my options for modelling this?
My first thought is that I could add a dummy member extending from the beam with Torsion equal to half the width of the beam. Then use a release between the dummy member at the perpendicular member. Do i have other options here?
See image below:
Parents Reply Children
