I have a project which is located at site class E. As it is site specific the check box is off for site class E and then I get this warning below:
What is the solution to this?
ASCE 7-16 Seismic loads implementation in Ram Frame
So, only Dynamic Response Spectrum analysis is permitted.
Thanks for the reply.
But based on the code we should be able to do ELFP for the exceptions, but RAM does not allow that?
Only that first exception is in the program. You can always use a user defined story force if you need to.
