Query about openstaad properties function
Hello ppl,
 I am trying to get beam geomerical properties (specifically width and depth) through Openstaad feature (specifically GetBeamProperty) and so far failing.
When i run the corresponding VBA code i get result as either "TRUE" or "1" or not at all. Please check out the VBA code and see what needs to be rectified ?
Any help would be deeply appreciated.
Sub bea_len()
 With Sheets("Tabulation")
 Dim objOpenSTAAD As Object
 Dim BeamNo As Long
Dim Width, Depth, Ax, Ay, Az, Ix, Iy, Iz, pro(0 To 7) As Double
'Get the application object --
 Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
 BeamNo = 44
     'Get geometrical properties of  Beam
 For i = 0 To 7
  pro(i) = objOpenSTAAD.Property.GetBeamProperty(BeamNo, Width, Depth, Ax, Ay, Az, Ix, Iy, Iz)
  Cells(i + 4, "C").Value = pro(i)
Next i
Set objOpenSTAAD = Nothing
End With
 End Sub
  • I am not sure what value you want to extract as pro(i) returns the execution status of the function only, not the property values. Now about your code, all the property values are extracted as 0 as the variable types are mentioned incorrectly. The following line indicates that you have defined pro() array as double, rest of the variables are not defined.
    This should be modified as --
    Dim Width As Double, Depth As Double, Ax As Double, Ay As Double, Az As Double, Ix As Double, Iy As Double, Iz As Double, pro(0 To 7) As Double
    Also I am not sure why you introduce a loop with same beam number. I have tested the following macro which works fine --
    Dim BeamNo As Long
    Dim p As Long
    BeamNo = 1
    p = objOpenSTAAD.Property.GetBeamProperty(BeamNo, Width, Depth, Ax, Ay, Az, Ix, Iy, Iz)
    Answer Verified By: Surojit Ghosh
Reply Children
