steel member design in staad pro
I have attached  a simple 2D design of a steel structure.In one design i have broken the beam into some segments and the member is passed.Then i wanted to check the entire beam as one member with the same section and same loading.This time the beam is not passed.how to solve the problem? thanks in advance.
01-design with member breaking.std
02-design without member breaking.std
Parents Reply Children
