I am using STAAD connect edition update 3.
I'm using macro to get selected plate numbers, but the function seems to give wrong results quite often. Some times it gives correct result.
Attaching screen shot of selected plates and the plates displayed while using the function.
kindly advise if any problem with syntax or alternate way to correct it.
I have investigated this and noticed that this is a bug. The problem is limited to following condition –
At this moment there is no alternative except using sorting option as 1. I have already informed this issue to the development team and they will fix the issue in the upcoming build.
