Hello all, Is it possible to provide me with the datasets (STAAD models and ISM files ) for Transitioning from STAAD.Pro V8i to STAAD.Pro CONNECT Edition learning path : https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=112344I am intrested in - Using the STAAD.Pro Physical Modeler in your Workflow trainig Dataset files & Sending Model Data between STAAD.Pro CONNECT Edition and ISM training Dataset and file , It would be really helpful for me to get those files if it is possible, kind regards .
Thank you for your question. I sent you an ISM and STAAD.Pro model via email.
In addition, per our conversation, I would recommend RAM Concept for the design of concrete slabs for a building structure that was modeled and analyzed in RAM Structural System through the direct link between these products. For more information on this workflow, please see the "Integration between RAM Concept and RAM Structural System" training course: https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=110076
Answer Verified By: Saed Al-Halteh
Thank you Sabrina, Much appreciated.
