Floor Diaphgram and Moment Release
0245.struc.STD
1) After applying floor diaphgram i am getting following warning
*WARNING- ZERO STIFFNESS IN DIRECTION 2 AT JOINT     32 EQN.NO.     188
***WARNING -  INSTABILITY AT JOINT   980   DIRECTION = MY
2) Have i applied the moment release correctly . I do not want any torsion in main beam due to secondary beams
3) I am getting this error
 WARNING:Reinforcement % exceeds maximum limit
even after increasing size the size of column to 300 X 700 mm. and if I correct 1 column by increasing its size then other designed column fails
4) Is my wind application is correct
Parents Reply Children
