PHYSICAL MODELER; How to include Dead Load, part of Live Load in Seismic weight, under Seismic definition using IS 1893-2016?
UNDER PHYSICAL Modeller
I am unable to add a load Group e.g a Dead Load Group  (which is a Reference load case in analytical modeling) and say 30% of Live load in calculating seismic weight in seismic definition using IS 1893-2016 .
Kindly guide workflow/ Commands in Physical modeler to include above; without Droping Physical Modeler!
Attaching screenshots:
1) Physical modeler load case to point out a self weight in this model (having Beam-Column only) as 990 KN,
2) Output file indicating Base shear as fraction of this 990 KN itself.
3) A Self weight load case to get only self weight of members load case no. 5
4)  a Dead loads under a "Load Group" , which are supposed to be included in Seismic weight calculation
and a Staad file too.
Thanking you.    Test_Sesimic_IS1893_Nil load item to define.STDTest_Sesimic_IS1893_Nil load item to define.STDP
Parents Reply Children
