Dear,
Auto Load Combinations as per AISC 360 - 2010 code, is it actualy combination rules as per ASCE 7-10?
What about ACI 318 - 2002?
The automatic load combination AISC 360-2010 in STAAD.Pro refers to the combination rules as per the ASCE 7-05. If you are looking for the ASCE7-10 combinations, you may choose the IBC-2012 automatic load generation option instead. The ACI 318-2002 refers to the load combinations mentioned in the ACI 318-2002 code.
Does it mean that design as per AISC 360-10 is compatible with loads and load combinations as per ASCE 7-05?
